Chris NottSky Insurance
Page 1 of 2 12 LastLast
Results 1 to 40 of 49
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,061
    Rear Tie Arm Replacement-too adjustable camber arms "How To"
    Guys dont know if its been done? but here is a how too for those who dont know..... (s3 8l )
    First take a look at the pic, the car has not been lowered much, maybe 25mm (thanks jojo) and you can see the camber!!
    These adjustable arms combat the camber....
    So lets get started, i am fitting my camber link (in pic) they are also available from forge awsome etc....
    I am doing one side at a time...Start by undoing the wheel bolts slightly, then jack up the car, and secure on an axle stand... remove wheel and this is what you see..
    Ive opted for doing the top link, as i think it puts less stress on the driveshafts... it is the roundish looking thing...
    you can just see the other end in this pic...
    now you need an 18mm socket and an 18mm ring spanner, just saves it getting chewed up, and undo the big rose joint...
    Now you need to get you head in the wheel well, or you can get it from underneath, and undo the inboard mount, you may have to take the subframe mount bolt out, as there just is not enough room for the bolt to pass.. mine came out suprisingly easy tbh....
    Next get a large screwdriver and manipulate the outer arm over the rose joint....easy
    It should just pull out now from the inner joint saddle.... smile your half way there...on this side,...
    NOW what i did was line the holes up on the new one with the old one, (just so you know it is going to end up as you started, before adjustment), and the adjustable ones could be miles out...in transportation etc.
    Get your new adjustable arm, and feed it into the inner saddle and line the holes up, if it is tight just spray a bit of lube around the saddle...put the bolt in and put the nut on.. dont tighten at this stage, put the subframe bolt back in and torque it up.
    Next put the outer bracket on to the rose joint, put the bolt in and tighten the nut (not overly tight just so it is nipped)
    Tighten the innerbolt the same (just nipped) then replace wheel , and lower to the ground, torque your wheel bolts, you can now rejack on the suspension or put some blocks under the wheel and rejack, and let it down on the blocks, and tighten the bolts to the specified torque, (if you have access to a ramp or pitt it is easy and you dont need to raise it again....)
    The adjuster is accecable for your wheel alignment guy or yourself and is very easy ..to adjust and lockup
    I pulled my camber back by eye until i get an alignment done, but its up to you of course, if you ligned it up with the old one it should be no better or worse than when you touched it ...
    Have a cuppa/cig and then get cracking on the other side.....
    Remember safety first, these bolts can be tight so please dont rely on a crappy side jack !!
    any comments/critisism welcome,
    tools requiered
    1 x 18mm socket
    1 x 18mm ring spanner
    large screwdriver
    lube
    jack and stands
    coffee
    ciggies (if you smoke)
    Regards Dave
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,846
    Topman Dave, let me know when you start to take orders for these, as I'm definitely having a set.
    You've got to have a laugh!
    Chugger
    North Devon
    2,716
    does anybody have the torque settings needed for the bolts? 50nm as a guess???
    57 A3 2.0 TDI Sportback (140)
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,061
    i did them 60nm think i read it somewhere...
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,846
    Mine arrived today!
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,355
    Nice write up,
    Chugger
    North Devon
    2,716
    Got mine fitted, going to let them settle then adjust them tomorrow. Decided to use nutlock on the locking nuts, just to be sure they dont work lose.
    A3Tom's Avatar
    Smell my finger.
    Mar 2009
    Solihull
    3,509
    Good stuff
    2000 Audi A3 1.8T Sport - Custom Code Phase 1 remap / Custom Stainless Catback Exhuast / MKII 18" RS4 Reps / Wietec Ultra GT40mm / KW ARB's / Forge TIP / Forge 007 / Green Panel Filter / EBC Greenstuff pads / 312mm S3 front brake upgrade / Aero Wipers / LED Interior Lights / LED Side Repeaters / Face Lift Rear Lights and covered in Dodo Juice
    SamiG's Avatar
    On Boost, ish.
    Southampton, UK
    231
    My s3 pulls to the left slightly, took it to my local Supertracker and they alligned everything up but the camber is slightly out and the guy told me i need adjustable arms. Are these what i need to adjust my rear camber?
    If so where can i get them? Thanks
    P.S awesome write up by the way
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,846
    Quote Originally Posted by SamiG View Post
    The OP of the thread, s3dave sells them custom made, PM him for more details.
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,061
    pm me for details
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,061
    Quote Originally Posted by sportstractor View Post
    i was going to supply them with spring washers but was advised it will not need them has it is a left and right hand thread, so the effect is pulling on each other so they would not be able to work loose once tight
    we have closley monitored 4 cars with them on, every weekend each one is checked on the ramps at my place, no problems reported or anything loose
    Chugger
    North Devon
    2,716
    yeah i thought about a washer but they shouldnt move once fitted. Only thing is if you didnt line up so the hub side bushes wasnt sitting 'comfortably' then it would probably try and twist it. Would be irresponcible if i didnt keep an eye on them though. Made up a jig today and set the camber up to what i think is 0.5 degrees and is looking good, when i do get it professionally tracked will be intresting to see how accurate it is. Goota admit its a sexy bit of kit, shame it cant be seen by bystanders
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,061
    be carefull gypsies dont look ,stainless prices have shot through the roof...
    StevoS3's Avatar
    Aug 2009
    Glasgow
    216
    think u could snap me up a set of those bad boys mate? how much?
    Audi S3: BAM 225 Standard =]
    | Cupra Splitter | Forge 007P | KnN Panel | 40mm Koni's | Custom Tie's | HEL Lines |
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,061
    pm sent
    Chugger
    North Devon
    2,716
    Your price has gone up then. Dam those gypos, they have been trying to nick my scrap copper stash, have seen there scout in my back garden
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,061
    no price increase as i bought all the raw materials last month, we have a big problem with them here with my place full of stainless it is like an aladdins cave to them
    SteveBAM's Avatar
    Black '03 S3
    Sep 2009
    A, A
    180
    received mine yesterday, hopefully i have some time during the weekend to install them and post some pics..
    thanks Dave
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,061
    your welcome
    StevoS3's Avatar
    Aug 2009
    Glasgow
    216
    Got those bad boys fitted yesterday, handling is just top class now! So impressed for the money!
    Best mod bought yet! Cheers Dave
    SteveBAM's Avatar
    Black '03 S3
    Sep 2009
    A, A
    180
    i installed mine with a friend on his car and mine on the weekend, took the car for a wheel alignment and all i can say WOW WOW..
    the handling has improved SO MUCH and the car feels really different, much more responsive and accurate, the wheels sit nice and straight with very little camber...
    my only comment would be maybe to have something to lock the two nuts together just in case one of them in time decides to start loosening up, but apart from that quality is very good.
    THANKS Dave
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,061
    Quote Originally Posted by SteveBAM View Post
    THANKS Dave
    cheers steve, we did consider locking washers but speaking to another engineer for a second opinion, it is definatley not needed, as it is a left and, right hand thread so infact it would get tighter so once they are locked it has a pushing and pulling effect, we have a couple of cars under close supervision with them on, and all is good, one (tt) has done the rounds on a track too thanks for your input though
    Alex C's Avatar
    Lizard, Cornwall
    2,562
    cheers Dave, turned up today look pretty tidy. My first thought was how the hell did you squeeze those bushes in
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,061
    Quote Originally Posted by Cookstein View Post
    Thanks, you got them ok then, UPS rang me and said there are 2 houses called the same....??
    poly Bushes are pressed in with a tool...
    Alex C's Avatar
    Lizard, Cornwall
    2,562
    Hi Dave, yeah, I'm at Roskilly house, not Roskilly Farm where they sell ice cream to tourists for rediculous prices. UPS delivered it to the ice cream place but they kindly dropped it back here for us. You packed it well Dave, I thought I had received a severed limb in the post, lol.
    I'm amazed that the lip on the bushes aren't damaged when pushing them in, anyway they look great, thanks again
  28. #27
    Chugger
    North Devon
    2,716
    I thought that about the nuts to begin with, but they have been on for a while now and not budged. Finally took mine for professional alignment and they thought they were fantastic and asked me where I got them from, naturally I denied all knowledge.
  29. #28
    May 2010
    just sent you a pm dave
  30. #29
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,156
    Only just seen this thread now I've got a set of these arms. I'll get them on in the next 3 weeks. Cheers Dave
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
  31. #30
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,061
    Your welcome mate.....
  32. #31
    J B
    J B's Avatar
    Dec 2008
    Hants & Ox
    140
    Got my tie arms and bushes yesterday Dave cheers, fitted them today. What a twat the old bushes are to get out if you dont have a press! And you were right they are far too pretty to paint, ended up painting the other arms silver to sort of match!
  33. #32
    Westy's Avatar
    Dec 2008
    17,156
    Easiest way to get the old bushes out is to burn them out. Use a BBQ fire lighter and a couple of bricks to support the tie arm and they will fall out as the heat melts them.
    S3 Build Thread
  34. #33
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,169
    Pikey way FTW eh westle! Haha.
  35. #34
    Westy's Avatar
    Dec 2008
    17,156
    Pikey and easy. Plus, who doesn't like setting things on fire?
    S3 Build Thread
  36. #35
    J B
    J B's Avatar
    Dec 2008
    Hants & Ox
    140
    I just drilled the rubber through the whole way round, then hit it with a really big hammer LOTS!
  37. #36
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,169
    Haha so true, twisted fire starter and all that .
  38. #37
    Westy's Avatar
    Dec 2008
    17,156
    When the late night mechanics remove suspension springs like this:
    It seems boring to remove bushes using a press
    S3 Build Thread
  39. #38
    S3 TAM's Avatar
    Pocket now empty
    Oct 2009
    London & Hertfordshire
    621
    This is how i got mine out worked a treat.
    Revo Stage 2 with all the Gear
    BHP = 274 / Torque = 293
  40. #39
    Westy's Avatar
    Dec 2008
    17,156
    Haha, late night mechanics rule
    S3 Build Thread
  41. #40
    devan's Avatar
    Jun 2010
    117
    Are these tie arms still for sale Dave? I think i need some after lowering my car.
    And this may sound stupid, but ive only ever seen rear tie bars for sale, how do i adjust the camber on the front wheels?
    Cheers!
    _____________________________________2010 Audi A5 Sportback S-Line ____________________________________
Tags for this Thread
