Sky InsuranceBadger5
    7
    S3 Starting problems
    hey everyone recently brought a s3 after much looking and though i found a good one but....
    been fine until yesterday and when i got home from work when to go out in it and it just kept on turning over pluged it in no fault codes then the battery went flat so jumped it off another car and it started straight away drove it for a bit 20-30 miles came home turned it off and it started again straight after so just thought it was being funny
    today tho came home again and wont start again tryed jumping it off other cars checked for faults nothing
    its only about 3 degrees anything to do with it??
    any one got any idea as i really am stumped and help would be great
    not fun having a s3 and not being able to drive it!!!!
    Thanks!!!
    golf's Avatar
    ***** rent boy
    Jan 2007
    London
    1,553
    Could be crankshaft sensor. Were there any warning lights on the dash?
    leshkin's Avatar
    Speeding in reverse gear
    Sep 2006
    Northwood
    678
    Battery going flat maybe? Seeing as there are no errors on VAG-com...
    A friend was having a problem jump-starting his 4.2 V6 A4 using a Nissan Almera and it would not start. We then tried my S3 with a brand new Bosch battery and it started without a problem.
    You can find out if your battery is not holding it's charge by looking at the voltage supplied using the climate control on-board diagnostics - http://www.wak-tt.com/tt/climatecontcodes.htm
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,499
    I would say knackered battery, the S3 need cranking power, all the electrics and coilpacks needs juice to fire it up!
    Sep 2009
    worcester
    1,097
    when you drove the car it wouldnt of put much charge back into the flat battery, so either its just flat and needs charging properly, or it is indeed kaput and you need a new one!
    if i were you id charge it for a good 12 hours first seeing as this is free compared to buying a new battery, see how it goes
    7
    wasnt the battery changed it today found fuse 27 blown changed it blew again so looks like its the fuel pump
    anyone know the best place to get one and how do you get it out tryed everything and no luck!!!
    thanks
