Did a bit of a fluid change yesterday, (coolant, engine oil, haldex oil, brake fluid.)
After doing the first brake went to lock up the bleed nipple and the caliper bleed nipple threads had stripped so got a new caliper today and fitted it, bled the caliper and now when i pump with the engine turned off i can get some sort of feel but wont pump up solid (but then it never did before).
When the engine is turned on the brake pedal is extremly soft and does not get harder at all. the brakes work though as the caliper will lock the disc.
Did a VAGCOM check and there is an ABS fault that is (AWD system no comms) which needs to be sorted but i cant see it being the problem with the brakes.
Cant find a leak anywhere. just gona have dinner and then bleed the whole system.
I read about assisted bleeding using computer software?
Any ideas?
Callum
Any ideas?
Callum
