Badger5Chris Nott
Results 1 to 18 of 18
    seen_'s Avatar
    Midlands
    44
    Is it safe to have wheel spacers together??
    At the moment I have got 5mm wheel spacers on the front two wheels. But the inside of the tyres are still rubbing against the suspension twist nuts.
    I am thinking to add 3mm spacers to the 5mm spacers to equal 8mm, is this safe or not? the reason i don't want to buy 10mm wheel spacers is because i don't want the wheels to catch on the arch.
    The wheel nuts I am using are standard, i've heard if you get 3 or more turns on each nut its fine.
    Is it ok to have 2 or 3 long nuts and the rest standard or does this affect the wheel when turning?
    Sorry for all the question but I am in need on some guidance.
    Thanks in advance
    Mpathe's Avatar
    1st gear
    Aug 2009
    manchester
    394
    yes would be safe to use the 2 spacers together but as for the bolts i wouldnt risk the chance, for the sake of 25-50 quid its not worth it, to think how much damage it could do if 1 wheel comes off.
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,863
    as for the spacers you could always tack em together, by gas, mma, mig or tig welding em
    Ronburgandy's Avatar
    Taking it back OLD SKOOL
    Oxfordshire
    15
    I would go for new bolts too mate,
    with all the questions asked from the Edition38 and Golf forum the general 'sensible' answer is you need to accomidate for what your changing, if you think you will nearly be taking 1cm from the bolt lenght and thats a bit worrying when you look at the length of the bolts
    You also need to think are they HUBCENTRIC spacers as the general weight of the wheel is on the centre bore of the hub where as the bolts are literally to hold the wheel on the centre bore!
    if your spacers arent HUBCENTRIC all the weight is on the bolts and you will def be asking for probs!
    Is the ET on your wheels really high?
    Ad
    A3Tom's Avatar
    Smell my finger.
    Mar 2009
    Solihull
    3,509
    From an engineering point of view.....one spacer will ALWAYS be better than 2 stuck next to each other.
    Now sorry for sounding harsh...BUT
    Lashing 2 sets together and tacking them IMO is bloody stupid unless you know what you are doing and you can get them TOTALLY lined up and straight. Doing them by eye isnt good enough. You have to make sure you get them in line and butted up correctly, tacking them together...I wouldnt.
    As for only using 2 long bolts, why oh why would you do that??. For the sake of the extra cash just buy a full set of bolts!!.
    How the wheels attach to you car is quite important, if one falls off then you're in the sh*t so you should make sure that if you're doing anything wheel related you DONT cut corners and do it properly.
    I'd enquire about getting some spacers made rather than using 2 sets.
    T
    2000 Audi A3 1.8T Sport - Custom Code Phase 1 remap / Custom Stainless Catback Exhuast / MKII 18" RS4 Reps / Wietec Ultra GT40mm / KW ARB's / Forge TIP / Forge 007 / Green Panel Filter / EBC Greenstuff pads / 312mm S3 front brake upgrade / Aero Wipers / LED Interior Lights / LED Side Repeaters / Face Lift Rear Lights and covered in Dodo Juice
    Lemon S3's Avatar
    Alex
    Sep 2009
    Bicknacre, Essex
    1,314
    Quote Originally Posted by Ronburgandy View Post
    Mine aren't hubcentric n I haven't had any probs, they've been on for quite a while. I am using 12.9 grade bolts though. When I have money, I will evetually get some hubcentric ones, it's just the 20mm hubcentric spacers are quite pricey.
    I do advise you to get longer bolts like all the others are saying.
    1999 APY S3 Imola Yellow
    PS3: Broady_11
    sportquattro's Avatar
    Sep 2009
    Ivybridge, United Kingdom
    741
    I imagine your insurers would have something to say if a wheel came off due to you not using longer bolts, there's an old saying,"if in doubt, there is no doubt" and IMHO the very notion of using too short a bolt to hold your wheels on is just asking for trouble. In other words I'd get the right spacer and the right bolts, anything less is dangerous and irresponsible. Sorry if that sounds harsh.
    1999 Audi S3 Superchips remap, Forge 007p, Phatnoise, Black Diamond Discs & DS2500 pads, N249 Deleted, Badger 5 TIP, Poly dogbone bush, Bilstein B8's and Eibach Springs.
    1986 Audi Coupe Quattro 2.2 restoration project
    seen_'s Avatar
    Midlands
    44
    Hey guys...thanks for your responce!!!
    You lot are right...will probs get new spacers and longer bolts! will probs try and get hubcentric ones but can't find any that are 8mm-10mm.
    Btw if i wanted to get spacers made where could i get them done from?
    S3Steve's Avatar
    Sep 2005
    Peterborough
    1,588
    H&R do 8mm hubcentric spacers mate, you can get them from DPM
    http://www.dpmperformance.co.uk/whee...2207_2868.html
    2007 A3 TDI 170 S Line
    Sold - 2002 S3
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,572
    Generally speaking you won't get hubcentric on anything less than 15mm spacers as the chamfer to the spigot will be too thin... that said I do have hubcentric 10mm spacers but they will only fit certain wheels like OEM for instance as aftermarket wheels differ on the chamfer from the mounting face to the hole in the middle.
    While H&R spacers may well do hubcentric 8mm spacers, they may not allow your particular wheel to mount flat on the hub/disk which is...... bad.....
    <tuffty/>
    seen_'s Avatar
    Midlands
    44
    my wheels are rs4 replicas so they must be aftermarket
    so my best bet i guess is 8mm normal spacers and longer bolts?
    A3Tom's Avatar
    Smell my finger.
    Mar 2009
    Solihull
    3,509
    Yep, you got it.
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,511
    Quote Originally Posted by P5SND View Post
    Wouldn't this effect the balancing of the spacer?
    DPM
    DPM's Avatar
    Jun 2006
    Newcastle/Durham
    4,291
    Personally I'd say get 8mm spacers and don't use 5mm + 3mm and always get the correct length bolts.
    Damian @ DPM Performance
    DPM Performance
    W: www.dpmperformance.co.uk
    T: 01207 561606
    E: sales@dpmperformance.co.uk
    RIP S3dave
    May 2004
    nr Glos
    7,175
    get 10mm hubcentric.. so you have a hub to hold the wheel..
    if you use plain flat or stacked spacers like you are, you have little or no hub engagement in your wheel, allowing for the chamfer lead in the wheel itself.
    longer bolts mandatory.. and no 3 turns is not sufficient.. 3 x 1.5 pitch is only engaged 4.5mm on an M14 bolt.. Unsafe what you are currently doing
    NEW NEW NEW eShop now LIVE>
    www.badger5.biz
    bill@badger5.co.uk
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,572
    Quote Originally Posted by jojo View Post
    ...not to mention potential for heat distortion upsetting the flat mating surfaces...
    <tuffty/>
    seen_'s Avatar
    Midlands
    44
    thnx evry1!
    just curious?!? has anybody just got spacers at the front of the car and none at the back? or is it best to have spacers on all wheels? because my rear wheels are fine! just need to get my front wheels away from my suspension slightly!
    A3Tom's Avatar
    Smell my finger.
    Mar 2009
    Solihull
    3,509
    I dont have any on mine
