Results 1 to 10 of 10
    Oxfordshire
    7
    Fog lights always on...
    Hi.
    I brought my S3 about 3 months ago and found out it had a few problems with it after the sale. The dealer was good enough to give me some cash back so i have now started to iron these out..
    Has anyone ever heard of the front fog lights being on in every headlight position apart from off??? Could this be a simple swith problem??? Please help, Maybe some more problems to come.
    A3Tom's Avatar
    Smell my finger.
    Mar 2009
    Solihull
    3,509
    The birds TT has this issue. I've been told it could be a wiring issue and removing the switch and refitting everything might cure it.
    Failing that I think its new switch time.
    T
    2000 Audi A3 1.8T Sport - Custom Code Phase 1 remap / Custom Stainless Catback Exhuast / MKII 18" RS4 Reps / Wietec Ultra GT40mm / KW ARB's / Forge TIP / Forge 007 / Green Panel Filter / EBC Greenstuff pads / 312mm S3 front brake upgrade / Aero Wipers / LED Interior Lights / LED Side Repeaters / Face Lift Rear Lights and covered in Dodo Juice
    Deanphoto's Avatar
    fell down the stairs :(
    Sep 2007
    Surrey
    95
    Although it sounds like a 'problem', it could be that a young boy racer type owned it before you and decided to hardwire them on when the side are on.
    Is it just the fronts?
    //deanphoto - Automotive photographer
    Oxfordshire
    7
    The boy racer theory had poped in to my mind. That is my worst fear. Yes it is just the front fogs.
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,520
    Its a switch issue, either dissmantle the switch and clip it together properly or put a new one in.I found its was because the mrs had twisted the knob to turn the lights off, without allowing the switch to kinda pop back in to turn the fogs off.
    Oxfordshire
    7
    Thanks a lot mark will try and take it to bits and see what happens. Fingers crossed.
    jackthelad's Avatar
    Oct 2009
    Banchory, Aberdeenshire, Scotland
    9
    I reacon its the switch aswell mate i bought my a3 about a month ago now and found myself stopped by police for having fog lights on and had no clue they were on. Being a tech I looked into it and found the switch is faulty. consulted a friend that works for audi and he says that it is a common fault.
    hope this helps
    Jack
    jcs356's Avatar
    Brum brum
    Jun 2004
    Englandland
    2,681
    I had this on mine. A small bit of the plastic clip holding it in had snapped and got stuck in the switch mechanism so when i twisted it ythe switch popped out a tiny bit turning the fogs on.
    I'd take it out and put the switch back in.
    Jason
    2001 Nogaro S3 (daily driver)
    1958 replica Porsche 356 Speedster (summer posing)
    1997 Seat Cordoba SX 16v (track day toy) replacing (t)rusty 1994 Seat Ibiza GTi RIP
    Oxfordshire
    7
    Cheers for the help chaps, will try it at the weekend.
    cabby86's Avatar
    Mar 2006
    Oxfordshire/Gloucestershire
    112
    My S3 has had this problem too, it was just a new headlight switch as others have said above.
    Chris
