AH FabricationsEM Tuning
Results 1 to 10 of 10
    reptor245's Avatar
    Jan 2009
    Torquay
    1,150
    Question: A3 Steering Wheel Removal?
    can anyone give me a heads up on how to remove the A3 Steering wheel and what tools are needed. Also how does the wheel attach. i mean is the column that is sits on on splines or a hexagon shaft. The reason i ask is that my wheel is slightly off centre and a 4 wheel alignment hasn't fixed the problem so i wonder if its possible to pull off the wheel and put it back on straighter.
    Audi A3 1.8 Turbo, Wietec Ultra GT 40mm kit, 3" Full Custom Stainless Steel Exhaust, Custom Code stage 1 remap, 17" RS4 Alloys, Whiteline ARB
    May 2008
    68
    you need to turn the wheel a quarter turn and remove the two allen bolts that hold the airbag on. re-centre the wheel then disconnect the airbag.
    you will need a multi spline bit to remove steering wheel bolt in think m12 is the size you need
    it looks like this:
    once the wheel is off, make sure you dont move the steering angle sensor. (with the wheel centred you should see a yellow dot in the small 'window'
    HTH
    Kevin
    reptor245's Avatar
    Jan 2009
    Torquay
    1,150
    hi, thanks for the reply. is it possible to move the wheel very slightly or is it a case of big movements. what i mean is i only want to move it a matter of millometres and not like an inch out of line.
    RichA3Turbo's Avatar
    ...Watching you!
    Earlsfield, London
    5,087
    yep its a splined bar, so you can move it a couple degrees at a time.
    BTW - You will likely need ALOT of force to undo the centre nut. On mine it took a 24" breaker bar to shift it the first time.
    IHI-VF34 + RACELOGIC + Parada SpecII = Who needs Quattro?! 0-60 5.1s @ Inters '06
    Thought of the month: People need to understand what is meant by 'Build Thread'...
    reptor245's Avatar
    Jan 2009
    Torquay
    1,150
    thanks for the replys guys. :-)
    anyone no were i can get a m12 from?
    Ross_S4
    Aug 2009
    Dundee
    718
    Can this not be adjusted out down at the track rod ends? although i understand this would screw your wheel alignment...
    reptor245's Avatar
    Jan 2009
    Torquay
    1,150
    Quote Originally Posted by rossbrownlee View Post
    oh trust me, this is the only answer for me. its alway been out and pulled slightly to the left. ive had a full susspension kit fitted, new whiteline roll bar and ive had 2 laser wheel alignments done. no one can sort it. Its much easier just to move the wheel to make it straight again.
    were can i get the m12 from?
    ...Watching you!
    Earlsfield, London
    5,087
    try just-off-base-tools.
    Sep 2009
    50
    got exactly the same problem mate, and came to the same solution, let me now how it goes as i might do it too.
    although, when you drive does your car pull slightly to the direction its turned, mine does, so i was thinking that maybe re centering it is only gonna mean that the wheel is straight when its turning, and your gonna have the same problem but in the other direction :/
    Audi A3 97' 1.6 Midnight Blue | Standard as of yet |
    reptor245's Avatar
    Jan 2009
    Torquay
    1,150
    well i removed the steering wheel using the M12 and just pulled it off and re-attached it in the right posistion. feels great now. its amazing how anoying the wheel is when its not in line :-)
