Sky InsuranceVolks Autos
Results 1 to 7 of 7
    c_dog's Avatar
    Apr 2008
    Sussex
    99
    Play in steering wheel
    I have started to notice gradually more and more play in the steering wheel, but not enough to bother me. But today driving home there was a noticeable difference, needing maybe an extra 1/4 turn on the normal! Any ideas what this could be?
    2001 A3 1.8T TQS
    1998 A8 2.8 Auto
    cruising in 6th...
    Jan 2009
    26
    Sounds like your tracking may be out. Only 35-40 to sort out but make sure you get the 4 wheel set up done if its a Quattro. All those pot holes jar the wheels out over time. Mine was the same seemed to sag slightly one side in a straight line.
    c_dog's Avatar
    Apr 2008
    Sussex
    99
    It makes an electronic whirring when going from lock to lock, is this normal or am I being paranoid now? Worried if it's something like power steering going or something equally expensive...
    2001 A3 1.8T TQS
    1998 A8 2.8 Auto
    26,774
    It will make some noise given its PAS, have you checked fluids aswell & also as mentioned check tracking, but is the wheel straight when wheels are straight, if not then tracking would probably sort, if are then something amiss with rack or PAS system overall.
    c_dog's Avatar
    Apr 2008
    Sussex
    99
    Would any PAS problems get thrown up in VAGCOM?
    2001 A3 1.8T TQS
    1998 A8 2.8 Auto
    26,774
    Not sure on 8L mate, but when you say play, can you advise this is when you turn the wheel quarter turn but the wheels dont even move until after this quarter turn or you saying the wheels move left to right when turning at all times just the wheel isnt straight when the wheels are straight
    mattyboy199's Avatar
    Nov 2005
    UK
    1,678
    sounds like the steering column, had mine done a few years ago around 300
    2002 Dolphin grey S3 - Sym2+bose, heated leather, ally mirrors, R32 ARB's with superpro, Jabba stage 2 map, TFSI coils, Samco TIP, Forge DV & privacy glass
    2010 Green Kawasaki Ninja ZX6R - Akrapovic baffleless race can, LED cluster & HID's
    wanted for 8L S3:
    Unmarked grey rear bumper panel
    Milltek system
