After asking for a few details about your set up, I read a couple of times the phrase "lead lag" i think it was, and how using the drivers side SMIC along with a FMIC would give this, But i havent been able to find what exactly this means and why i would want it...Could you please help?
Lead-Lag is maybe a bad term...it's an industry term we use at work so I was probably just being lazy referring to it like that.
Maybe pre-cooler, cooler?
Basically, I was using the SMIC as a cooler to do some work, then using the bigger surface area of the FMIC to drop the rest.
The SMICs are actually in good places, relatively high pressure and lots of air flow...so I used the standard SMIC to take the first chunk of heat out of the charge air, which gave the FMIC less work to do.
I then changed the std SMIC to a deep, higher capacity Forge unit to see if it would make much difference...it didn't really.
Why would you want it?
You wouldn't specifically.
My FMIC wasn't the biggest, as I wasn't prepared to loose foglights or cut the crash bar...and there was always a thought that it was actually slightly undersized...so trying the uprated SMIC would give me a change to try something different.
Maybe, in the set up I had, the std SMIC was doing more work than people think...maybe they are more efficient than we give them credit for...or maybe the FMIC was just big enough to be effective and none of the design failings really mattered on a K04'd S3?
One for you bright sparks out there haha... Is the size of the forge cooler a "good size" or simply the easy option for fitment? I looked at some intercoolers with the inlet and outlet in the middle of the end tanks ( to aid flow i beleive) but am unsure if there realy is enough room behind there to fit a bigger or center in/outlet type.
I looked into different designs and couldn't see how a FMIC significantly different in shape could be mounted whilst keeping things like the towing eye facility, foglights, standard grilles on the bumper etc....mine had to have the inside of the bumper trimmed to suit the FMIC I had, as it was.
In all honesty...I really can't see the sense if getting bent out of shape over the design...if you can come up with a kit that will fit easily, with bottom in/out and the (potential) compromises it brings, prove it drops the inlet charge significantly and sell it at a decent price, I suggest it's worth buying - compromises and all.
Or, make a kit that utilises the standard drivers SMIC in series...that's proven to work too. My fear was that it would blow the end cams off the plastic SMICs...but even at 1.85+ bar they were fine.
The bottom line for me, is finding something that fits behind the standard bumper without distorting the shape of the bumper skin, doesn't have silly polished pipes on show, doesn't need the removal of the foglights and drops the inlet charge down effectively.
I really couldn't give a toss if it's not a particularly good design, or not deemed 'perfect' as long as it's proven to work.
If you can do that, at a fraction of the price of the alternatives, I'd suggest everyone with an S3 buys one.
Oh, can you have it anodised black too?
Stealth / anti-bling. It's the future.
