Volks AutosSky Insurance
Results 1 to 10 of 10
    Nov 2007
    caster/camber plates for my audi
    i've already installed pss9 with powerflex bushes to my audi s3, waiting for whiteline arb's. I would like to add some more negative camber to my car - right now its -1 degree by side.
    I've found 2 products applicable to audi s3 8l:
    http://www.2bennett.com/body_tt.html(i believe whole suspension in s3 is the same as in audi tt so it should work)
    http://k-mac.com/pages/newprods/vw/vw_audi.htm some guys that already have it at vortex forum's claim it is of bad quality
    are there any better options that u may suggest?
    I am thinking about ordering the first one, what do u think?
    ANDYTQ's Avatar
    Oct 2003
    Caerdydd, Cardiff, United Kingdom, United Kingdom
    951
    I have the same issue but don't know what to get.
    06 A4 AVANT QUATTRO 2.0T S-LINE SE,GARNET RED, RS4 REAR ARB,SPACERS ALLROUND,H & R SPRINGS,B5 PERCHES,A6 V8 RIMS.PORSCHE CAYENNE TURBO S SIX POTS .REVO ST2 MAP ,MILLTEK CATBACK EXHAUST,PANEL FILTER,034 INTAKE PIPE.
    Stewart's Avatar
    Feb 2005
    Blackpool, UK
    696
    With 10mm spacers and pulling the balljoints right out, you can achieve just over 2 degrees negative on the front, more than enough for track work.
    Rarrrr! I'm not Lesdyxic!
    There are three kinds of people in the world, those who can count, and those who can't.
    Clicky Here!
    Nov 2007
    how will 10mm spacers affect handling of my car?
    I would need to get rims with diffrent offset to get things right?
    Right now balljoints are fully out and i get -1.0 by side, 10mm spacers will make it up to -2?
    For me it's too complicated to fully understand how spacers affect handling of a car - there are too many variables to consider and understand...
    Jul 2007
    60
    Maciek, I have PSS installed and I am now running -1.5deg at the front. Try playing with the ride height a bit unless you don't want to go lower.
    By the way, how is your rear spring looks like at the rear when the car is sitting on the ground? Did it looks like fully compressed?
    Quote Originally Posted by Maciek_s3 View Post
    Nov 2007
    right now its lowest possible setting of pss9 and we couldnt get more than -1.1 per side
    yep rear spring looks fully compressed with that lowest possible setting of pss9 - it was the first thing I noticed when I picked up my car with pss9
    ANDYTQ's Avatar
    Oct 2003
    951
    I can only get 3/4 deg neg on mine,with the later slotted arms adjusted to the max,surely spacers don't make that much difference?I'm stuffed for spacers on the front really,unless i fit the wider s3 wings to match the wider track arms that i fitted.
    Jul 2007
    60
    Don't know if this H&R triple C system works on our car.
    http://www.h-r.com/index.php?inhalt=...t-f&sprache=en
    Nov 2007
    unfortunatly the suspension mounting is diffrent so the triple c system is useless
    ANDYTQ's Avatar
    Oct 2003
    951
    KW do some neat top camber mounts but you have to have their coilovers to fit.
