edward_harris
s3 gone now a shiney red evo 6
Whats the deal with uprated ecu's ie apexi? Alot of people talk about them but whats the real advantages?
edward_harris said:Ah so theres not really any power gains to be had then! Not worth the money! by the time its been mapped etc all over again!
ant123456 said:A stand alone ecu setup correctly will produce much better results the a remapped ecu fact. At the end of the day it's about the ££££. If you have it, do it. When it comes to the safety aspect. Again, aslong as it's setup correctly there will be no issues. If you are worried about fuelling air ratios etc, get a knock link installed and a air/fuel ratio gauge fitted.
Ryanc said:I run autronics in my evo which didn't cost too much.It allows me to eliminate the maf and run a map sensor
