Results 1 to 27 of 27
    Defratos's Avatar
    You’re Dethpicable!!
    May 2004
    London....Relocated to the Mid East
    2,230
    Question How to remove the front headlight
    Hi guys, just wanted to check how to remove the front headlight, I Know I've seen a guide on here somewhere but I can't find it. I also know there are 3 screws to remove for the headlight to come out but what tool do I need for the bolts? Cause the ones I have don't fit, and I'm not sure what the tool is called.
    2002 S3 BAM | Jabba Re-Map | Uprated Haldex | Koni adjustable coilovers | Neuspeed ARBs | Powerflex Bushes | ECS tie-bars | Dog bone | Eibach spacers | TTDA | T'Dynamics DV | Dieselgeek short shift | Toyos | MIJ Custom Exhaust | Sound system | Security Tints |
    Audi S3-BAM
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,854
    Is it called a big hammer and chisel?
    Nov 2006
    Aberdeenshire
    111
    Probably torx bits that you need?
    2007 Ibis white S3.
    Nov 2004
    103
    I seem to remember a while back that someone wrote that the bumper had to come off - not a quick job. It is a Torx though for the bolts.
    See if you can get to this - its for an A4 but must be similar because I'd kept the link from ages ago -
    http://www.audi-forums.com/attachmen...front-rear.pdf
    jcs356's Avatar
    Brum brum
    Jun 2004
    Englandland
    2,681
    YEah, bumper needs to come off. If your car is a facelift that means roughly the following (based upon Haynes manual)
    Front wheels off
    Remove front wheel arch linings
    Undo bumper screws behind front wheel arch lining
    Undo bumper screws on bottom of front wing
    Undo bumper fixings across top/bottom of front slam panel
    Pull bumper forwards remembering to unplug foglight/headlight washers
    I haven't done it myself but Haynes reckon it is a fairly easy job to do - just time consuming.
    Edit: Sorry, once the bumper is off you can then get to the headlight mounting screw behind the bumper.
    Jason
    2001 Nogaro S3 (daily driver)
    1958 replica Porsche 356 Speedster (summer posing)
    1997 Seat Cordoba SX 16v (track day toy) replacing (t)rusty 1994 Seat Ibiza GTi RIP
    Defratos's Avatar
    May 2004
    2,230
    Thanks for the feedback guys, but I was gong to remove the bumper anyway (guess I didn't make it clear in the earlier post). It is an easy job I've done it more than I can count and the wheels can stay on if you've got the right tools to get to the screws behind the front wheel arches. The front wheel arch lining does NOT need to be removed just the first 5 screws and the remaining one at the bottom for the wheel arch lining. Thanks anyway, will try and buy the torx bit
    Audi S3-BAM
    Defratos's Avatar
    May 2004
    2,230
    Quote Originally Posted by RGS3
    WTF it doesn't allow me to view this page, even after I've made a membership it says you do not have premission to access this page?? what the hell?
    Audi S3-BAM
    Nov 2004
    103
    Try this link...
    http://www.audi-forums.com/attachmen...achmentid=4733
    if not, PM me your email address and I'll see if I can send you the pdf.
    Defratos's Avatar
    May 2004
    2,230
    the link doesn't work but it's cool, I got around to removing the headlight today, but had to use a flat head screw driver for the 3rd screw located in the most retarded position, anyway thanks for the help
    Audi S3-BAM
    sitrials's Avatar
    Mar 2007
    Stamford, Lincs
    866
    i don't have to take my bumper off to get my headlight out is that because its not a facelift?
    S3 - Gone but not forgotten!
    Defratos's Avatar
    May 2004
    2,230
    not sure, all I know is that your lights come off in two sections. you probably could remove it without the bumper but you'll still have the wire connected to the xenon box thing?
    Audi S3-BAM
    sitrials's Avatar
    Mar 2007
    Stamford, Lincs
    866
    no what i mean is mine does come peice of piss as i had to fit a new range motor the other day to pass its MOT! its out in 5mins.
    Defratos's Avatar
    May 2004
    2,230
    well in that case I dont think they're similar
    Audi S3-BAM
    jesters3's Avatar
    The Shire's
    1,516
    Quote Originally Posted by Defratos
    Looking to attempt this at the weekend to fit my other Samco Hoses. as a result need to get the headlight out; where abouts are the screws/bolts located?
    Also you mention that you did not need to take the wheels off if you have the correct tools, whoch tools would they be?
    Jester
    "On my second S3 and loving it. RS3 here I come!!!"
    Defratos's Avatar
    May 2004
    2,230
    humm ok sorry for the late reply for one, lol just saw the reply. Ass for the screw, the first two are easy to see, they sit on top of the headlight, they look like to big torx screw type bolts. (Might be able to get some pics up later on tonight), the third screw is a bit hard to see. The only way I could access it is through a small hole to the outside edge of the car depending on which side your on. Its weird to explain and hard to see, but it looks like all the other bolts. My torx screw extension thing wouldn't fit through the hole (which sucked because it would have made it much easier) instead I got a long thing flat head screw driver which thankfully locked onto the torx screw, and then it was just a matter of un-screwing and trying to catch the bolt before it fell into the abyss that is the engine bay.
    Hope this helps
    Audi S3-BAM
    Defratos's Avatar
    May 2004
    2,230
    here you go mate, go around to taking a pic:
    This is the tool I used, bought it from halfords but I don't think they stock it anymore.
    Here's the diagram showing wherethe 3 bolts are located, hope this clears things up:
    You might wanna zoom in a bit
    Audi S3-BAM
    Nov 2006
    Aberdeenshire
    111
    Good idea Halfords selling smokes these days. DIY spannering get quite stressful at times
    2007 Ibis white S3.
    Defratos's Avatar
    May 2004
    2,230
    lolyeah, I was using it as a means of comparison
    Audi S3-BAM
    jesters3's Avatar
    The Shire's
    1,516
    Outstanding work Defratos. I reckon my dad has one of those so will have to nab it off him. Thanks again.
    Jester
    jesters3's Avatar
    The Shire's
    1,516
    Question.
    After removing and refitting the bumper my headlight is 'jutting out' and not flush like the other side and I can't push it in. Has anyone got schematic of the headlight so I can see if I have missed a clip or something when refitting it in? Checked vagcat but nothing on there. Cheers all.
    Jester
    1animal1's Avatar
    The Clar!! it mouves!!!
    Dec 2007
    Sheffield
    9,990
    i was considering doing the mod where you spray the chromey bits black in the headlight...think ill pass if its this much hassle
    Xbox 360 gamer ID : Timffy
    Grey Triumph Sprint 1050 ST
    jesters3's Avatar
    The Shire's
    1,516
    To be honest; it wasn't much hassle getting the bumper off or back on. The only issue I had was refitting the headlight, the third bolt uses a weird clip to hook it onto a bit of plastic to hold the light in and that took a couple of attempts to get it right. It wasn't until I finished screwing it all back up that I noticed the headlight jutting out. - typical!
    Jester
    Jacko4130's Avatar
    Goodie Gum Drops
    Dec 2007
    mansfield
    839
    Took me around 2 hours from start to finish to remove my bumper and headlights and put it all back together.
    Torx keys are all thats used if i remember...
    Black S3
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,318
    I've had my bumper off now so many times sorting out my fmic now, that I can get my car from fully road going, to front bumper off, and both headlights out, in around 5 minutes, No joke.
    The front bumper is just 3 torx each side in the arch liner, 2 screws underneath, and 4 plastic rivets along the top edge.
    Headlights are a T30 (I think) torx key, I dont see how it could ever be possible to remove the head lights without removing teh bumper, as the lower outer torx bolt is below the line of the bumper
    Jun 2011
    75
    this is a great thread. i will taking mine off very soon. do you think anyone has a got a step by step picture diagram of removing headlights and bumper? this would be very useful if anyone has this stored
    bhavin1986's Avatar
    BBP
    Mar 2008
    Leicester
    461
    There's a thread on audifans which shows how to do a headlight conversion. It does mention how to remove the front bumper and headlights, although its pretty easy. here's the link:
    A3 Facelift Headlamp Upgrade - Audifans.net
    Hope that's of some use.
    17" BBS RS Reps, JOM Coilovers, TT ARB, Facelift Front & Rear Lights, Aero wipers, LEDs all round, 6000K HIDs, Blacked out Grill & Rings, De-wipered,
    12" 1000w FliTrap Sub, Colour Coded Lowers & Skirts...
  28. #27
    AviatorRichards3's Avatar
    Oct 2012
    Hertfordshire
    48
    Hi guys, I know its a few years to late but I thought ide add my story as it may help someone down the line.
    Now what I've done is taken what I wrote on another thread and copied certain parts in here that are relevent to this.
    Ive got an 2002 S3 8L and strangely when I purchased it, one headlamp looked brand new, and the other had the cloudy/rough deterioration to it.
    So today I decided to clear it up, and I followed this link: 3 Ways to Repair Oxidized Cloudy Headlights with a Headlight Cleaner
    I actually found is very straight forward to remove the bumber, as there are 4 plastic lugs under the bonnet which following what I had read on here, screwing a small hook into them. In order to pull them out worked a treat.
    now when I got to the light, I realised that the lense could be unclipped from the light unit, which made my life easier as I wouldn't have to faf around trying to get the whole light out which looked to be a pain as I couldn't even find one out of the two bottom screw locations.
    Now regarding the lense, I found it took me a while to get through the sticky foam glue stuff which obviously acts as a sealant as well as to ensure the lense stays in place (as well as four clips)
    Now i know its already been said but i will stress again as i wasnt told how delicate the chrome finish is on the inside of the lamp unit and on that little bit of plastic trim that comes off inside the lamp. So I decided to wipe the inside with a damp cloth and window cleaner to bring back the chrome look, and low and behold, it came off in my hand....the window cleaner literally dissolved it. Luckily I had only used it on the plastic trim piece and not the actual headlamp unit, as I can just purchase another or spray paint it...but I guesse it requires a very light touch otherwise it comes straight off.
    Ive followed all the steps in the link I provided, which was wet n dry paper, polish, and a extremely good buff up with a electric buffer, and it made it much butter (i couldnt see all the diagonal lines on the lamp before and now they are there as clear as day) but its still not good enough as the drivers side one looks like new, which makes the car look uneven....
    So I am going to buy a new lens for me light and if anyone is interested in the passenger side lens, let me know...
    Conclusion: it can be done and you can take the lamp to bits, its tricky, requires lots of levers and patience and you have to break the seal.
    Since posting my days work on a mother thread, someone told me to use a heat gun on the foam part which will release it easier. I'm assuming a fairly powerful hair dryer would do the same trick? As I don't have access to a heat gun.
    moreover I never actually managed to get the whole light out (not that I tried that hard) but it would be nice to remove the whole thing.
    does anyone know what I could use in place of the foam sealant as when I buy the new lens, ill want to seal it in there with something. I was thinking a kind of silicon gel?
