im wanting to fit facelift lights to my prefaclift a3 but will i be able to revert back to prefacelift lights after the wing has bee cut, just incase i wanted to go back?
dantheman1986 said:so the bit of wing thats cut of isnt need to mount the indicator to or anything? and yes i mean the fronts
dantheman1986 said:the reason i ask is becasue im fitting a pair of facelift xenons and incase the light pattern is blinding other drivers or i get pulled by the poilce or it fails the mot, I want to be able to revert back to my old lights.
rodenal said:It also wont fail the mot, never heard of anybody failing because of it - but anyway it should be possible just to put the originals back in, as its the small plastic clips that hold them in, attached to the rails on the main headlight unit - rather than the bits of wing - i can imagine they might be slightly rattly tho, not such a worry if its only for a day or two.
dantheman1986 said:the reason i ask is becasue im fitting a pair of facelift xenons and incase the light pattern is blinding other drivers or i get pulled by the poilce or it fails the mot, i want to be able to revert back to my old lights.
silver75 said:Good to see this kind of thinking
