Results 1 to 10 of 10
Like Tree1Likes
  • 1 Post By <tuffty/>
Thread: No lifter in ext valve???
    Nov 2013
    84
    Hello
    i opened my vc to change chain tensioner
    for my surprise I found this:
    Why there is is no lifter there?
    A3 1.8T
    decat stage 1 206 HP
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,594
    Because its worn away... that (to coin a phrase) is fu*ked... new cam and new follower(s) required at the very least
    <tuffty/>
    Nov 2013
    84
    Should I replace intake cam too?
    A3 1.8T
    Nov 2013
    84
    And what about the valve is he ok?
    A3 1.8T
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,594
    Quote Originally Posted by aviel131 View Post
    If its not damaged then no need...
    Can't tell without stripping it but personally I would be looking to get a replacement head off another engine to be sure as there is no telling what other damage has happened...
    <tuffty/>
    Nov 2013
    84
    <tuffty/>
    what damage can be happened?
    A3 1.8T
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,594
    follower bore could be damaged and would potentially cause this to happen again... valve could have damaged the valve guide... etc... This looks like an oil starvation issue so its difficult to tell exactly whats wrong from a picture...
    Basically you will need to strip the head and inspect it for damage and make a decision from there... 1.8t engines are fairly cheap to buy though while a full head rebuild can be expensive...
    <tuffty/>
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,594
    Looking back through your posts dude I am thinking you may need to consider an engine re-build or replacement engine at the very least...
    low engine compression (50PSI)
    Engine clicking noise (this one will most likely be the lifter rather than the tensioner tbh)
    <tuffty/>
    Nov 2013
    84
    you mean bottom end rebuild too?
    maybe the compression problem came from the valves?
    A3 1.8T
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,594
    you had 50psi on all cylinders didn't you? it could be the valves but... like I said you will need to strip the engine to see...
    You could take the head off, rebuild it and see if the problem goes away... if it doesn't it means stripping the engine again to rebuild the bottom end too which is time and another headgasket/headbolts set too...
    Based on the issues you have had and the evidence you have presented I would be considering a full engine rebuild or trying to source another engine from somewhere... either way you will have to take the engine apart to confirm the problems...
    Its your choice at the end of the day... you could change the bits you think are the issue and get lucky or throw more and more money at it and end up with a worn engine that runs... or you could do it properly and rebuild or replace the engine..
    <tuffty/>
    s3dave likes this.
  1. N75 Race Valve
    By S3DBW in forum General Technical / How To
    Last Post: 22nd July 2003, 12:29
  2. Blow off valve or Dump valve ?
    By K212 in forum A4/S4 forum(B5 Chassis)
    Last Post: 17th July 2003, 19:18
  3. Diesel Diverter Valves
    By simmolee in forum Diesel forum
    Last Post: 10th April 2003, 17:22
  4. Dump valves
    By waynehiscock in forum General Technical / How To
    Last Post: 28th March 2003, 18:15
  5. Diverter Values/ Dump Valves
    By Banwell in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th January 2003, 23:50
