Sky InsuranceJMB Retrofits
Results 1 to 22 of 22
Like Tree1Likes
  • 1 Post By QuestMS
Thread: S3 facelift headlights
    QuestMS's Avatar
    Jun 2013
    Romford
    66
    Follow QuestMS On Twitter
    Question S3 facelift headlights
    Hi all
    I need to replace both headlights on my 02 S3 as one has broken up inside and both have broken adjusters. I haven't had a price for new genuine headlights but I'm sure it will be ridiculously expensive. Has anybody found a cheaper option for replacing broken headlights? I can't seem to find aftermarket xenon units anywhere
    Thanks in advance
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,594
    QuestMS's Avatar
    Jun 2013
    Romford
    66
    Brilliant! Just had a quick read and sounds like you replace with the non xenon cheaper Depo headlights and just fit an aftermarket HID kit? Sounds like a fairly easy and effective alternative
    Thanks mate
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,594
    No worries but just be aware (as noted in that thread I linked you too) that adding a HID kit to halogen based projectors is technically illegal due to the cut off filter fitted to HIDs... an option maybe to use the internals of the xenon lights in the new headlights...
    This is a good read too
    Official B5 A4 / S4 Headlight and HID Thread
    Bi-xenon conversions are an option I am looking into as S3 xenons are rubbish tbh
    <tuffty/>
    QuestMS's Avatar
    Jun 2013
    Romford
    66
    I'm not overly fussed about the legality of it all tbh but thank you for pointing that out. The only part broken inside the passenger headlight is the retaining clip for the auto levelling motor. It may be an option to use the innards from my original xenon units inside the new non xenon housings as it won't have the auto levelling motor. Will there be codes logged as it will be a different setup? I take it the wiring is pretty straight forward as the car is already fitted with xenon as std? Apologies for all the questions lol
    Cheers again
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,594
    Quote Originally Posted by QuestMS View Post
    Cheers again
    http://www.audi-sport.net/vb/group-b...-a3-s3-8l.html
    Don't know if this guy is still doing anything with this particular group buy but I know he sells on eBay... maybe drop him a pm
    <tuffty/>
    Marshall878's Avatar
    Jan 2014
    March, Cambs
    134
    QuestMS's Avatar
    Jun 2013
    Romford
    66
    That would have been ideal if the manual adjusters weren't broken , haven't got a fix for those too have ya? LOL ....
    kwistof's Avatar
    South East Events Moderator
    Jun 2010
    SE Kent
    2,283
    Follow kwistof On Twitter Visit kwistof's Youtube Channel Visit kwistof's Instagram Channel
    Take the whole headlight out....give it all a good clean and put it back together.
    That's how my self levelling system sorted itself out as mine was also broken for a while- well only 1 side was anyway. Couldn't find a fix for the manual adjusters really so I was pretty lucky the auto levelling system sorted itself out as it caused an MOT failure for me.
    Please don't bodge it to become illegal though- there's nothing worse than a high performance/prestige car ruined by cheap HID lights that are incorrect for the car. Up there with adding DRL's to the older generation cars IMO
    2000 S3 APY
    18" BBS RSII with Michelin PS3s, 20mm H&R adapters, Relentless 3" DP and Sports cat, B5 V1 induction kit, cone filter+heat shield, Forge 007P, Awesome GTI SMF, AP coilovers, Facelift rear lights, Full Powerflex poly bush kit, R32 Rear ARB, SAI delete, N249 by-pass, Upgraded Engine mounts with Polytek, Stage 1 CC at Badger 5.
    May 2013
    Birmingham
    212
    I read something about replacing the little gears for the adjusters? Can't quite remember where though....
    But for the leveling motor clip I used and aluminum one off eBay for mine and it was spot on and shouldn't ever break!
    QuestMS's Avatar
    Jun 2013
    Romford
    66
    Quote Originally Posted by kwistof View Post
    I can't see the issue with it tbh Kwistof, plus the self levelling system only adjusts dipped beam not full beam so I'm still stuck with how to adjust that.
    They will look identical from the outside, be set at the correct level so they do not blind people, and I would be using a high quality HID kit which comes with a relay harness needed to stop the wiper motor from burning out (HIDS4U).
    I'm not a fan of bodging anything. I'm also not a fan of paying over £300 a headlight either : / .
    kwistof likes this.
    Relentless v3 manifold, custom 3" decat downpipe, custom 2.5" exhaust system, Forge wastegate actuator, Forge 007p DV, Badger5 3" TIP, ITG Maxogen filter, Draft44 catch can, Trackslag charge pipe, 2.0TFSI coil packs, n249 delete, FMIC, poly bushed, FK coilovers, adjustable rear arms, 19" RS4 style alloys,
    QuestMS's Avatar
    Jun 2013
    Romford
    66
    I was hoping someone would come back and say that such and such sell a direct replacement at a fraction of the cost but no such luck haha!
    May 2013
    Birmingham
    212
    http://bit.ly/LWVJe3 That's the repair clip I used if it's any use to you and here's what I read about the adjuster! Headlight adjuster screw/cog
    QuestMS's Avatar
    Jun 2013
    Romford
    66
    Thank you very much! I shall have a good read later after work and weigh up my options
    kwistof's Avatar
    Jun 2010
    SE Kent
    2,283
    Nah that's totally understandable- I was in the same boat and was weighing up my options.... £500 a piece for pre-facelift lights so I expect face-lift will be the same!
    Keep an eye out on the classified on here and ebay as people are often breaking S3s.
    Have a word with Trups (T8ups) on here about HID kits- his are very good value and comes with a warranty. That's where I ended up getting my replacement ballasts/bulbs.
    2000 S3 APY
    QuestMS's Avatar
    Jun 2013
    Romford
    66
    Oh my god £500 each?? Wow ......
    I've seen a few on eBay for around £75 each but what will you be buying? Merky lenses and broken clips etc .....
    That's why retrofitting HID's into a3 facelift lights sounded appealing, clear shiny new lenses with HID's that aren't pointing at the bumper/sky. My only worry is it will flag a fault in the ECU with regards to self levelling. Not that it would make any difference, just very fussy lol.
    Jan 2014
    March, Cambs
    134
    They will still be self levelling as you'll have the motor in the back of the depo units surely?
    May 2012
    RETFORD, NOTTS
    1,753
    I am planning on selling my oem xenons, just as soon as T8ups finishes my new headlight project :D I paid about 300 for them a year ago.
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
    Jan 2014
    March, Cambs
    134
    Headlight project? Do go on....
    sssline's Avatar
    Apr 2012
    Essex/London
    135
    Quote Originally Posted by @udi A3 View Post
    Any news from Trups? Last I heard he was waiting on a bracket...
    May 2012
    RETFORD, NOTTS
    1,753
    no news atm... no spoilers either... :D
    QuestMS's Avatar
    Jun 2013
    Romford
    66
    Quote Originally Posted by Marshall878 View Post
    Are the normal halogen headlights in the A3 self levelling also then? I thought it was just on xenons you had self levelling ....
  1. Facelift Headlights fitted...
    By RichA3Turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th January 2006, 12:54
  2. Facelift headlight guys....
    Last Post: 6th January 2006, 23:34
  3. facelift headlight alignment
    By ultramodz in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th August 2005, 23:44
  4. Facelift headlights
    By imported_highlander1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th October 2004, 13:09
  5. 225 facelift headlights
    By ravi in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th May 2004, 08:26
