Volks AutosSky Insurance
Results 1 to 30 of 30
Like Tree1Likes
  • 1 Post By Spatula
Thread: Water in passenger foot well
    Spatula's Avatar
    !.8T AGU
    Jan 2013
    North West
    185
    Hi all,
    I've got a problem that I've had for awhile. My passenger foot wells (front and back) are always really wet.
    They're wet enough that when you press the carpet with your finger you can make a puddle appear.
    Does anyone have any idea where the water is coming from? I don't have a sunroof, and I don't think it's coming from door/window seals or anything. It's a 3 door 98 1.8T.
    Also, it's been happening for awhile now (maybe 3 months or so) and the car doesn't smell at all. ?
    Nilz's Avatar
    Defo worth the wait :)
    Apr 2006
    9,640
    If you do a search, it has been covered plenty of times.
    Common issues are scuttle panel not fitted properly, missing grommets, water lines blocked, so water comes into the car.
    Hope that helps.
    Spatula's Avatar
    !.8T AGU
    Jan 2013
    North West
    185
    Sorry, yeah I did a search after posting the thread, and found a whole bunch of useful information.
    I'll give them all a go when I have a little free time.
    Cheers anyway
    Nilz's Avatar
    Apr 2006
    9,640
    No worries mate, hope you get it sorted.
    Feb 2012
    Pie eating land
    871
    Follow ruffrida On Twitter Visit ruffrida's Youtube Channel
    Yeh very common fault this, most likely the sunroof drainage holes are blocked, or the pipes have come loose !
    B6 1.9tdi Quattro Avant Sport,
    Full zenon bulb kit, Plug and Play chip @165bhp, EGR Delete pipe, Chrome Mirrors, Chrome side repeaters, wind deflectors, Front center arm rest, LED number plate bulbs (when they work), Rear tints, De-Badge Rear, 19" BBS LM's,De-Wiper
    Coming soon -35mm Springs, De-cat pipe.
    Wish List; FMIC, BV43 turbo, Bigger Remap, Fat Clutch, Stereo upgrade, Full Stainless with twin exit !
    Chuck it in & pin it out, nothing better than doing it in the dirt !!
    Spatula's Avatar
    !.8T AGU
    Jan 2013
    North West
    185
    I don't have a sun roof. Took door panel off and no signs of leak?
    I looked at the skutter* plate (plastic plate that goes under wiper blades) and theres a pretty big gap on passenger side between that and the window. Is this normal? I think I can see juice underneath but the gap looks too big for it to be sealed?
    Hmm...
    Feb 2012
    Pie eating land
    871
    Dont sound normal to me that, if i remember rightly mine was tight against the screen as the was a groove piece of palstic it sat/locked into. Dont hold me on that though!!
    Spatula's Avatar
    !.8T AGU
    Jan 2013
    North West
    185
    There is definitely a gap, probably around 2 or 3mm.
    Any ideas what I can do?
    Feb 2012
    Pie eating land
    871
    Quote Originally Posted by Spatula View Post
    Defo not normal that fella!!
    Spatula's Avatar
    !.8T AGU
    Jan 2013
    North West
    185
    should that lip sit under or over the seal that runs vertical down the windscreen?
    Spatula's Avatar
    !.8T AGU
    Jan 2013
    North West
    185
    Do you think it'll be okay to use silicone sealant on the scuttle cover?
    S3 Paul's Avatar
    Oct 2006
    2,759
    I was thinking the same... mine isnt bang flush but i was unsure about silicone to fill the gap.
    Noggy Blue 2001 S3
    Feb 2012
    Pie eating land
    871
    The only way i would use silicone is if it could not be seen after, such ugly stuff makes everything look so tacky!!
    I would be having a look why the is a gap in the first place, fully remove it first make sure the is nothing causing the gap, dont forget they are really flexible so if it sits wrong on 1 end, i am pretty much certain it will be wrong somewhere else, you may not have even seen it.
    If i ever removed mine, i always made sure it was firmly up against the screen first before fully re-fitting!
    Spatula's Avatar
    !.8T AGU
    Jan 2013
    North West
    185
    I'm not even sure how I take the wipers off? Someone did a thread about removal and used a special tool to remove the wipers? Why can't they just be pulled off? Do I need to remove the bonnet or anything?
    Feb 2012
    Pie eating land
    871
    EH?? Special tool???????
    13mm socket and a screwdriver fella!
    Really simple, flip the cover up, undo the nut and pull !! That simple.
    Just make sure you dont damage the splines when removing and replacing. No need remove bonnet at all, just needs go up and down a few times so you can get the tools on right. Bout it fella.
    Once the are removed the scuttle panel should just pull of, can remember if the is a couple of screws holding in on or not, not that i can think of anyway, but remember they are only thin plastic so pull to hard and it will snap!!
    Spatula's Avatar
    !.8T AGU
    Jan 2013
    North West
    185
    Yeah I read a thread on here yesterday where someone had bought something from Halfords that looked like something out of Alien. I'll just pull that bad boy off.
    I'm getting excited at the concept of having a dry cabin..
    Nilz's Avatar
    Apr 2006
    9,640
    Good luck, let us know how you get on
    S3 Paul's Avatar
    Oct 2006
    2,759
    I took mine off at dinner time...
    The groove was full of dirt, i cleaned it all out but the trim still doesnt sit in... from about the middle of the screen about a foot towards the passenger side is raised. About 3 mill i would say. it pushed down but just slowly comes back up.
    I think some silicone sealer in the groove may be my next option... but i will need to clean it all properly first.
    Noggy Blue 2001 S3
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,169
    Id say new scuttle panel paul. Easier and will look better.
    Spatula's Avatar
    !.8T AGU
    Jan 2013
    North West
    185
    I'm having huge problems getting my door panel back on. :-/
    I just looked at my scuttle thing and as s3 dave said; I'm seeing big gaps too
    Spatula's Avatar
    !.8T AGU
    Jan 2013
    North West
    185
    S3 paul* posting from app on phone
    Feb 2012
    Pie eating land
    871
    Quote Originally Posted by S3 Paul View Post
    Yeh mine was minging, loads of crap in there, a real good clean of the scuttle panel and everything around it & it went back on nice and flush, all depends how many times some 1 has had it of & on, with most thin plastics it will only take so much !!
    Feb 2012
    Pie eating land
    871
    Or go with Dani_B19 idea save all the hassle / cleaning!!
    Spatula's Avatar
    !.8T AGU
    Jan 2013
    North West
    185
    Does anyone know the part number so I can call TPS and they can take my pants down?
    vfr800's Avatar
    Feb 2012
    Melting Beans
    740
    You need to clean the recess out very well, but perhaps the scuttle panel has been deformed because it's been in the wrong way for such a long time. A new one should work.
    I had to have a windscreen replaced once because it sagged on one side and dropped down so the scuttle panel would not fit in - every time it rained I got a wet foot well.
    Liam
    S3 AMK 2002. Only 203 BHP left in my poor little engine, currently searching for the 7 missing horses.
    Mods: Powerflex bushes at the front and rear, 710P DV, ambient light module, Badger5 V3 TIP, S2000 Filter.
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,169
    Its in a recent thread as I had a similar problem mate.
  28. #27
    steve
    Sep 2007
    norfolk
    73
    Bit late on but hey ho. I had exactly the same issue after having my windscreen replaced. There is no doubt a small section of the scuttle panel fixing missing on the R/H side as you look at it. The result of this is that water is allowed to flow into the gap which conveniently sits above the pollen filter.
    This allows water to seep in and exit via the passenger footwell. More noticeably when washing the car you'll probably have a pool of water every time.
    Best option is to buy a new scuttle to guarantee a good fit to the windscreen and also that the recess where it fits to the windscreen is intact.
    Hope this helped
  29. #28
    Spatula's Avatar
    !.8T AGU
    Jan 2013
    North West
    185
    I've just had a quote for an OEM part from Audi.
    Part number: 8L2819415B 01C
    Price: £45.79
    I think I'll probably go for that.
    Dani_B19 likes this.
  30. #29
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,063
    I have this issue at the moment too, and it's BAD!
    My scuttle is cracked right above the pollen filter, and it's filled the heater up to the point where my heater motor has packed up, so I now can't warm up the inside to dry the car out!
    Fecking nightmare.
    New scuttle is being fitted as soon as I get a dry day to do it!
  31. #30
    Spatula's Avatar
    !.8T AGU
    Jan 2013
    North West
    185
    Oh dear, that sounds bad. Are you ordering a new one OEM, or getting on ebay or something?
  1. Golf mk4 drivers foot well water ingress
    By aky20 in forum Volkswagen and other VAG
    Last Post: 26th November 2011, 17:12
  2. Rain water in all foot wells!
    By nick4501 in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th October 2010, 13:39
  3. Water in the foot well?
    By S3 Paul in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th March 2010, 20:59
  4. Water In Rear Foot Well A6 Avant
    By zpage in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 2nd February 2010, 19:04
  5. Water in rear passenger side foot-well !!!!
    By CO11K9 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 14th December 2008, 17:51
