Hi.
Good question on this, i can Shed light on anything
lol
i can supply D2S projectors, they would use the same holder i am having made up aslong as the S3 xenons are the same as the facelift halogen projector headlights?
For Shrouds you wont need any as the shroud in the 8l projectors is the casing, the proctor sits on brackets on the rear so you would just need the projector if you want to keep it looking stock from factory.
have you tried to adjust your main beams manually?
once the projector is fitted as long as you have manual adjusters and they are working you can start setting the beam up, making them higher so they shine further, as long as the light when you drive past someone and the light is not in their face you wont blind or dazzle them which is the most important thing.
have a look at this cutoff i got from a retrofit i did 2 weeks back.
These where tuned to shine further on dipped beam, went for a few drives and perfect, not dazzzling any on coming drivers.
i got the mrs a cooper S back in march and thats fitted with xenons from the factory, the cut off on this after market projector is ALOT sharper than hers and they where a £450 option! so for less than half the price you have a better setup than OEM if done correctly.
Trups
