Volks AutosEM Tuning
Results 1 to 8 of 8
    willh92's Avatar
    Jul 2013
    Portsmouth/Rushden
    156
    Revo stage 1 remap. Other mods required?
    Hi all,
    looking at getting my '99 S3 remapped by revo to the stage 1 level in the new year. Was wondering if there are any other mods you guys recommend getting done at the same time, for example new clutch or brakes upgrade. Or if simply the cars standard internals are up to the job of 265bhp running through ?
    will
    S3 - APY silver
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,915
    A health check is recommended,usually a remap will speed up an existing fault.
    What mileage ?
    willh92's Avatar
    Jul 2013
    Portsmouth/Rushden
    156
    Just had a health check at audi, all that was found was slight oil leak from the cam cover and cam chain adjuster gasket. Which I found confusing as I thought these motors were cambelts? Which on my car was changed (apparently) 3000 miles ago. It has covered 79500 miles serviced every 6k at audi. Ive owned it for 3 months, not had any issues.
    S3 - APY silver
    sean_s3's Avatar
    May 2009
    West Yorkshire
    264
    They have both a belt and chain mate. Boost leaks are common on these cars and a health check won't highlight them all , ideally the system needs to be pressurised to find them. Where are you based? People may be able to advise where best to take the car for a remap close to you.
    S3 Big Turbo
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,592
    Quote Originally Posted by willh92 View Post
    They run a cambelt on one side onto on sprocket on one camshaft, and a cam chain on the other which links the 2 cam shafts.
    Lewis583's Avatar
    Mar 2010
    872
    The 20vT is cam belt from crankshaft up to the exhaust cam pulley. Then at the other end of the exhaust camshaft is a chain that link the exhaust and inlet camshafts together.
    The engine internals should be fine at stage 1 power.
    If the clutch isn't slipping/flywheel still quiet then I wouldn't bother with touching them.
    Brakes all depend on how hard you are on them. If you drive it quite hard then maybe uprated pads and a brake fluid change would be a good start.
    Make sure you fill her up with V-power (or other higher octane fuel)
    2008 E92 BMW 335i M-sport
    1990 Golf GTi w/ a 20v heart BUILD THREAD
    Full VCDS
    2006 A3 2.0T quattro S-line R.I.P. You will be missed.
    ** Breaking - 8L 1997 Audi A3 1.8T. **
    willh92's Avatar
    Jul 2013
    Portsmouth/Rushden
    156
    oh right I see, forever learning! Is the cambelt what you can see on the left side of the engine as you look at it under the bonnet? And i assume the cam chain should last the life of the engine.
    I am based in Portsmouth mate.
    Would fitting a turboback exhaust require a remap?
    S3 - APY silver
    sean_s3's Avatar
    May 2009
    West Yorkshire
    264
    Thats right , belt on left and chain on right if looking from the front.
    If going to the trouble of fitting a complete exhaust system then yes you would want a remap to make the most of it.
    You would want a custom map though.
    Would be a bit of a drive for you but Badger 5 in stonehouse gloucestershire gets the thumbs up from me.
    S3 Big Turbo
  1. REVO stage 1 additional mods?
    By Johnnyb in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th November 2009, 17:09
  2. revo stage 2 remap mods 2 do before
    By bansheeboyo in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th June 2009, 08:18
  3. remap... without other mods?
    By S3Matt in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th February 2009, 16:53
  4. Revo'd plus other new mods!
    By S3 Big Andy in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th September 2008, 21:00
  5. Remapping without any other mods & Ebay
    By S3MHT in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th March 2007, 22:12
