Results 1 to 11 of 11
Like Tree1Likes
  • 1 Post By MexxT
Thread: Max's Audi S3 8L build
    Jul 2013
    31
    I have been reading and posting for a while on the forum, And I tought I should share my progress of my S3
    I'm from Holland, so don't be hard on the english haha.
    This is the car
    Done a few mods, such as; Big custom FMIC piping welded by myself :D
    Fitted a Spec solid flywheel, and a Sachs SRE Race clutch (550+nm)
    Inline Walbro 255lph
    A bilstein B16 PSS9 crossed my path, and fittet some brembo's
    The last owner emptyed te cats, and I made a rear silencer bypass, And fitted a powerflex dogbone
    As a final touch I did a wideband Lambda and ECU swap.
    In combination with some mapping it made a whopping 290HP and 480Nm! talk about rod lottery...
    I was driving around for months with that map, but after I found out about the torqe I tuned it down a little to limit the torqe
    No TIP, no 3'' Downpipe no manifold, so I think it was impressive for such a stock engine.
    Now the bad news. Last month it started to smoke when ideling, and under boost, I checked the turbo, and it had some axial play. So I think that is the end of it. Bought myself a cheap Golf 2 to drive around with. So I could fix the Audi.
    Bought some ebay rods (200 pounds is not much and worth a shot imo) and had them balanced. They were spot on to the gram from factory. So I let them make some more oil holes like the IE ones got. Costed me around 300 pounds total, so I'm happy.
    Also orderd a head gasket kit and some other stuff (T-belt etc), but still waiting til it gets here.
    The plans are:
    BBT k418T hybrid
    630CC Bosch injectors
    3'' Downpipe
    Renetless V3 manifold
    3'' or custom TIP
    I also have a rebuild AUQ head, with some AGN cams in it.
    I wil start in about 1-3 weeks with removing the head. First I need to get rid of my old Leon 1M chassis to make some space.
    Hope you like it
    Jan 2012
    16
    Hi mate, your car's looking very smart the pic of your exhaust looks interesting, do you have a valve in the silencer by-pass or is it just a bypass pipe?
    Jon
    Jul 2013
    31
    Thanks.
    No it is just a bypass.
    Sounds great imo :P
    Oct 2012
    birmingham
    245
    like the sound of that make me one?
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    So have you had the ebay rods rifled drilled then?
    Jul 2013
    31
    Nope, just 2 holes in the bottom.
    rifle is a good option, but not necessary.
    I know people who had engines without the rifle, and they still run perfect
    Jul 2013
    31
    Some other parts arrived today!
    Head gasket kit
    head bolts
    rear brake pads
    Oil filter
    Petrol filter
    Thermostat which opens a little earlier
    Full timingbelt kit
    Piston ring compressor
    Magnet
    and a socket for the connectingrod bolts.
    still need a turbo
    Injectors
    Manifold
    Downpipe
    Oil
    and maybe some other small parts.
    Jul 2013
    31
    It has been a while since the last parts arrived.
    But the last 2 weeks i have been working on the car again.
    so here is a big update. I try to clean everything as good as possible, and replace what is necessary.
    I jacked the S3 up, and started to remove the head. one bolt of the manifold was stuck, so we had to cut it and the manifold in pieces. But it is out now! Replaced thermostat, bit of cleaning, tested the rings with oil on the pistons, fitted modified PVC system, and temp sensor for the oil.
    1654246_10200611541730282_566197281_n.jpg 1517390_10200611539770233_2100132722_n.jpg 1912150_10200611541370273_174904855_n.jpg 1898112_10200611540250245_983379564_n.jpg 1939784_10200611511049515_635624794_n.jpg
    1743583_10200611511209519_855648832_n.jpg 1507947_10200611510689506_1236813087_n.jpg 1891034_10200611509889486_752769816_n.jpg
    And head off!
    Filled with oil to check the piston rings.
    Jul 2013
    31
    Next day!
    Checked the oil levels in the cylinders.
    Seems okay, only cil 2 a bit more, but i can live with that. I will clean and check the rings when the pistons are out.
    Did a bit of cleaning, and removing rubbish.
    1660625_10200611506889411_1752468664_n.jpg 1779825_10200611506129392_500857311_n.jpg 1780613_10200611505889386_543553908_n.jpg 1796642_10200611506649405_1440076723_n.jpg
    Yesterday I removed the pan, and the pistons. Prepared the conrods for fitting, cleaned the oil pump, and removed the carbon from the engine parts.
    Took me some time to get to this result...
    1797437_10200617921289767_1488357335_n.jpg 1900138_10200617921529773_1323182846_n.jpg
    Oil pump:
    1966811_10200617920929758_933826667_n.jpg 1969260_10200617920209740_548264870_n.jpg 1964793_10200617920569749_1308871750_n.jpg 1899955_10200617919569724_995561879_n.jpg
    Sadly the carbon was very stuck on the oilpump so i couldn't clean it more.
    Pistons out! Conrod time!
    The bearings are in awesome condition!
    And getting the rest done
    The reason I don't replace much, and prefer cleaning and repairing is that I sadly don't have a job at the moment.
    But the stuff that needs replacement will be replaced off course.
    s3dave likes this.
    Feb 2014
    136
    Nice engine
    CazzaVR's Avatar
    Sep 2013
    Gloucestershire
    161
    Looks like you're making fantastic progress- good work! Really liking the sound of the silencer bypass 8)
    2002 Avus Silver BAM S3::B5 v2.2 TIP::Powerflex::Superpro::Forge::RSTT::Random Remap!
  1. Max's Audi A3 2.0 TFSI Quattro S line
    By bootneck_max in forum A3/S3/Sportback (8P Chassis)
    Last Post: 3rd May 2012, 20:17
  2. Audi thinking of building a Q3 RS
    By h5djr in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th April 2012, 21:11
  3. My Audi TDI 170 build - RedDejavu
    By RedDejavu in forum A3/S3/Sportback (8P Chassis)
    Last Post: 4th October 2011, 13:33
  4. MAX POWER AUDI A4 LOL
    By billybravo in forum A4/S4 forum(B5 Chassis)
    Last Post: 23rd December 2007, 08:36
  5. Acceptable Audi build quality?
    By A3_TOBES in forum A3/S3/Sportback (8P Chassis)
    Last Post: 28th July 2006, 08:25
