EM TuningBadger5
Results 1 to 11 of 11
Like Tree1Likes
  • 1 Post By Gordie_S3
Thread: 1.8t Forge Actuator ?
    Gordie_S3's Avatar
    Feb 2013
    Melbourne, Australia
    78
    Has anyone here fitted one? I'm really keen to try it out on my s3 (stage 2) but I'm worried it will cause my harm then good?
    Thoughts?
    FMACVAG01 - Forge Motorsport Alloy Adjustable Actuator - VAG K04 1.8T | eBay
    basil brush likes this.
    Stage 2 S3 8L + other mods
    beachbuggy's Avatar
    Surrey
    1,746
    uprated actuators are good and certainly have their place, mainly n the fact they are replacing old 12 year old stock ones, which are weak and likely to not hold boost.
    You will need the map tweaked to accommodate the new actuator but that should be easy enough for the tuner.
    I believe forge did or do 2 types, one with a plastic grommet in it and one without or a metal one, Go with the metal one and ideally you need it to be about 12-14psi equivalent... I think they have different springs to adjust the tension..
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,621
    Problem with Forge ones tends to be the lack of travel... don't know if they have changed the design recently but all the ones I have seen have limited travel...
    As Dan has said you will need map tweaks to accommodate the increase in baseline actuator pressure else it will be producing boost spikes and potentially bring on limp mode...
    <tuffty/>
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,542
    iVe heard frankenturbo actuators are really good...lol
    Gordie_S3's Avatar
    Feb 2013
    78
    My tuner said it won't be a issue tuning it and tweaking it. Will the lack of travel have a effect on anything?
    Will this actuator help hold the boost on higher rpm? What exactly is its roll?
    My current boost levels drop to 14-15psi near red line.
    RIP S3dave
    May 2004
    nr Glos
    7,199
    stronger actuator... (std is 5psi) will hold boost longer providing the compressor is still keeping up..
    12-15psi is the range for uprated ones, but n75 duty cycle control WILL have to be changed to avoid the thing spiking boost to the moon and windowing your block.
    I think forge have a piston actuator now.. Not used one myself, used their diaphragm ones before.. The plastic bush (blue thing) can melt in k04 environment, but they can do a phosphor bronze one also... Check with them which they will build as std... and if not std, ask for it. Travel is less (or was less on the diaphragm one) than an OE actuator, so choose the correct spring rate and dont rely on adding much preload to it as it will rob the already reduced travel. The piston one I dont know, so cant comment to its travel. I may ask for one to chuck on lupos hybrid to see.
    check that your mapper can accomodate a wastegate x3 stronger than stock for the n75 control.
    NEW NEW NEW eShop now LIVE>
    www.badger5.biz
    bill@badger5.co.uk
    Gordie_S3's Avatar
    Feb 2013
    78
    Gavin from Custom Code is my tuner, will have to discuss with him a bit more in regards the n75 duty cycle.
    Is this actuator a piston actuator ? - Forge Motorsport Audi TT MK1 Alloy Adjustable Actuator 225Hp 1.8T Engine Only FM - Motamec.com
    Will the standard ko4 be able to manage? Also std fuel pump/injectors be okay aswell?
    S3quatt's Avatar
    Flat Oot like a ducks Foot
    Jan 2007
    Sunny Scotland
    595
    I have one on mine, but it was on there when I bought the car. Fitted & mapped by Star.
    I cant really comment on a comparison as i've no frame of reference, but it's been reliable for the past 6 years.
    The only issue I've had with it was a split diaphragm which ended up causing spikes.
    Took ages to figure out as I never knew it was there.
    ...... Now this one's MUCH better!...
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,641
    Beach buggy actuator here! Car is perfect!
    Jul 2013
    Definatly worth it as i should think your standard one is weak anyway, i cheated a bit and just used an external spring hooked over the end of the actuator arm and on the lip of the actuator. Tryed a few different ones and then settled on one that started cracking at 11psi, map will definatly need changing otherwise it will boost to the moon lol i personaly run a mbc in parallel to the n75 set at 25psi to hold down the spikes.
    Knock knockWhos there?Con-rod!!!
    Jan 2012
    128
    Quote Originally Posted by Gordie_S3 View Post
    Thoughts?
    Gordie if your getting one let me know, ill get one as well
    Ive read the thread on vortex i think i might swap over to the forge
  1. Forge actuator.....
    By Dani_B19 in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th December 2012, 09:16
  2. Forge Actuator for RS3 & TTRS
    By AwesomeMike in forum RS3 Forum
    Last Post: 14th November 2012, 05:13
  3. Forge Actuator for RS3 & TTRS
    By AwesomeMike in forum TT/TT-S/TT-RS Forum
    Last Post: 13th November 2012, 16:17
  4. Forge actuator brand new to fit 2.0tfsi
    By nil538 in forum For Sale/Wanted - Audi Parts
    Last Post: 22nd April 2012, 18:51
