Monster MotorsportEM Tuning
Results 1 to 27 of 27
Like Tree3Likes
  • 1 Post By superkarl
  • 1 Post By Sandra
  • 1 Post By Goubo1
Thread: S3 apy engine rebuild help
    Dec 2011
    609
    Going to try get my engine sorted out over the weekend,my mate that's going to be doing the work has asked me to find out if its hydraulic lifters ??
    he also said while the engine is out about doing the conrods and pistons what are the best conrods and pistons to go for on the apy engine ? anyone know where I could get some for Friday ?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,025
    Rods = Bill.... and yes, hydraulic lifters in 20vs... make sure your mechanic FOLLOWS the instructions for fitting them... ARP bolts aren't the same as the OE ones...
    <tuffty/>
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,025
    Why pistons???... replace the rings and do a hone for sure but no need for pistons...
    <tuffty/>
    Dec 2011
    609
    <tuffty/>
    does bill have them in stock tuffty ?,is their a guide for fitting them with the bolts or a thread on here ?
    if all goes well the work will be getting started on Friday night
    Dec 2011
    609
    <tuffty/>
    its just incase there is damage to the ones I have tuffty
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,455
    Rod bolts just follow a different torque sequence thats all. 3x 50lbs.
    Dec 2011
    609
    is that 50lbs then slacken back to 50 slacken and back to 50 Karl ?
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,040
    If your planning on changing pistons to anything other than OEM ones you will need to completely strip the block and rebore it
    I found ETKA and Elsawin really helpful software to have on your computer and can be had on many download sites
    Power & Torque 335bhp 285ftlb
    0-60 4.64 1/4 mile 13.02
    My GTX3071r Build Thread
    http://www.audi-sport.net/vb/a3-s3-f...ld-thread.html
    Dec 2011
    609
    Quote Originally Posted by StaceyS3 View Post
    Cheers for that mate,would pistons from euro parts be ok or best of going audi dealer ? It's just incase the pistons are have been damaged with what's happend
    Dec 2011
    609
    Is there a guide to a list of parts to what else to get when doing rods ?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,025
    Quote Originally Posted by Goubo1 View Post
    I use 55ftlbs and yes, tighten then slacken, tighten then slacken and tighten for the last time... and by that I mean tighten both bolts on each rod then slacken both bolts on each rod in turn..
    No tutorials as such... this is engine building... your guy will hopefully have some idea... I have gone into it a bit of detail in my build thread before...
    Pistons won't need changing unless you have put a hole in them... if the valves have impacted them all you need to do is carefully flatten off the sharp edges to prevent hotspots from occurring and causing pre-ignition...
    New rings need to be gapped correctly and you NEED to hone the bore to bed them in... you will also need to run mineral oil for at least the running in period of 100 miles or so before dumping it and putting fully synth back in
    New shells needed too... Bill will have those... you will also need to check the small end clearance on the gudgeon pins... you may need to hone them a little... the pins need to slide in the small ends... if they bind then no oil can squeeze past to lubricate the pins or bush and you will end up with small end rattle...
    Also advised is a new oil pump and pick up pipe..
    ... but then hopefully your guy knows this...
    <tuffty/>
    Dec 2011
    609
    <tuffty/>
    thanks for the pointers tuffty,I will have a good look threw your thread mate
    is there any special tools required or would a garage have most of the tools needed ?
    the plan is to replace as much as possible like all gaskets,oil pump pick up pipe and such while the engine is out that's why the rods are getting done to as it would be a shame not to when the chance is there
    i will give bill a ring tomorrow and explain what's getting done and he will know the parts I need to order from him
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,455
    Do you have a budget btw?
    I did mine on a bit of a budget, i say a bit because its still bloody expensive.
    I sourced oem 9.5 comp pistons for mine, and all the rest that goes with it.
    Had i another 5-600 quid, id have loved to taken the block to 83mm and got some high comp CP pistons or similar.
    Something to consider.
    Dec 2011
    609
    I could go to 2k but that's leaving me on the skin of my arse but desperate to get it back on the road mate,am I right in thinking its only rods that's needed for 400bhp ? As I would like to do it so I have some head room for further mods
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,455
    Are you utilising your current turbo? K26??
    Im not sure i follow with that question? Only rods needed for 400?
    What i meant by my previous post is that, if your going to do it, even only rods, which will be atleast 1k, and thats assuming your mechanic is v friendly. Then you may aswell do what ever you can, its an investment in your hunger for power, so what you do with this build, can help you in the future should you want more power and change turbo.
    Hell, ive not even finished mine and i kick myself for not going 83mm pistons, just so its done ready for anything else i might want to add years down the line. I.e. Stroker crank.
    See What i mean.
    If you just want your car back on the road asap with rods so you can enjoy what youve got, sure go ahead and do the basic minimum.
    Dec 2011
    609
    See What i mean.
    It will be with the k26 for now mate ,what I mean if the engine gets sorted and get the rods done would be enough to support 400 with the right turbo injectors etc etc
    Yeah I see what you mean mate but with the rods done the and with the k26 all else I would plan on doing is a custom map and leave it at that as I couldn't afford anything else for a long time
    im wanting to do the basic minimum but also do what's sensible to while the engine is out like oil pump and pick stuff like that as tuffty said
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,455
    With rods, bearings, rings and all the pumps n gaskets and what no then the motor should easily take 400hp and similar torques.
    so you can be confident that what youre doing should last you. And of course will be a great basis should you ever change the k26 for something bigger.
    Good luck with it anyway. Im sure everything will be sweet.
    Goubo1 likes this.
    Dec 2011
    609
    cheers pal,fingers crossed it will be all good :-)
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,040
    May be worth dropping dan (beachbuggy) a line and getting him to work his magic on yours as could probably extract a reasonable amount more out of it with a billet wheel and of coarse its cheapest and easiest to do whilst it's already out
    Dec 2011
    609
    as much as a would love to mate I couldn't afford it just now by the time I buy all the parts I need and hoping to have it back running for Monday morning fingers crossed
    Dec 2011
    609
    Got the car looked at today and one of the pistons has a hole in it my mate recons it's either melted a piston or dropped a valve part of the plug was smashed and metal from the plug has went into the cylinder,so I'm going to try get another engine
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,455
    Sounds like youre as lucky as me
    Stuart35205's Avatar
    Apr 2013
    Telford
    108
    Not the best news to find out if you want it bk by Monday , good luck anyway mate
    2000 A3 1.8t sport AUM
    18 BBS LM , coilovers , strut brace , poly bushed f/end , S3 front discs , S3 rear lights , wrapped roof , face lift front lights , Forge tip , cone filter & heat shield , forge 007 DV , DV relocation kit , n249 bypass , n112 removal, SAI removal , scorpion back box , ECS shallow sump , ECS single mass clutch conversion.
    Dec 2011
    609
    Quote Originally Posted by Stuart35205 View Post
    it won't be back for many Mondays now mate
    Dec 2011
    609
    its a total pisser mate so it's back to the drawing board now
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    14,336
    Sorry to hear about the car Robert. Im sure you will get it sorted out real soon, it be a shame not to see it running again. Drop me a pm when your up and running and i will give you some details of a very local meet with some of the others in our area that im going to organise. Fingers crossed for you. Will be strange when im passing by and the car nit sitting in its usual spot. x
    superkarl likes this.
    Smaller (Local) Events
    Audi-Sport.net online magazine.
    To find Audi-Sport-Net members with VCDS check out the MAP.
  28. #27
    Dec 2011
    609
    Quote Originally Posted by Sandra View Post
    it will be back eventually just keep a look out x
    Sandra likes this.
  1. Help with spec on S3 8P 2007 engine Rebuild
    By Aidens S3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th July 2012, 16:18
  2. Help With Fault Code 00562 - Oil Level - APY Engine
    By darreng1983 in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th October 2010, 17:43
  3. Engine rebuild options, 2.1 conversion? ( Badger help? )
    By Andrew@A.L.D in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th December 2009, 18:57
  4. New and need help - any contacts for an S4 engine rebuild
    By grgh in forum The Welcome Section
    Last Post: 14th March 2008, 19:30
