8 and 9j tyre size
*P3nfold*
Billingshurst
Hi all,
I currently have 225/40/18 on the current 8j's on the fronts and dont really want the stretched look on the rears to match, I like having solid tyre walls.....
Could anyone recommend a tyre size what would match the fronts on 9j's please?
255/35/18 is nearer 225/40/18 for rolling radius.
True, but he said he wanted something that matched the fronts so I figured he'd want the same. :p They're wider not bigger diameter.
Cheers fella,
So thats
225/40/18 Fronts
245/40/18 Rears
Funny enough I was looking at a tyre size calculator at 235/40/18 for the rears, do you think there will be stretch?
A little by comparison to the fronts, but it won't be mental.. Like my 225/40 on 9.5J :)
Very important to get the rolling radius front and rear close as possible. Get it wrong and the ESP throws a fit and the haldex clutches eat themselves.
Routledge, profile is a percentage of the width so 245/40 has larger radius than 225/40.
Thanks you. :icon_thumright:
Whoops, I thought it was a percentage of overall diameter. So, what you're saying is that me running 225/40/18 all round with staggered fitment wheels 8.5 and 9.5 will mean my ESP will go mental and cost me loads?
I've not noticed any change :/
Same size tyre so difference is minimal. There is a tolerance built in to allow for say, 2 new tyres at the front and 2 worn out tyres at the back. I'd imagine yours would fall into this allowance as its so minimal.
You can't however run 225 40's at the front and 245 40's at the back.
245s fit a 9 quite well. I run them all round but 245/40/17:
Cheers Ben.
Do you think the s3 will look ok with 9j 255/35/18 on the rears with 8j 225/40/18?
Fair play. I'll go back to minding my own business then ;)
EDIT: I'm due to have you fix something actually.. So I expect I'll be calling you soon.
It will look fine, but squeezing 255s under the rear arches require the correct offset. What you could do is use 235/40R18 all round I guess?
ET on the rims are 35, I have a rear adjustable tie arm as well so I guess I can play round with that?
Not sure on the 235/40/18, I dont really want any stretch on the 9s.
humm this gets you thinking lol.
235 on a 9 will be fine mate. 255 is a little large for the arches IMO
Im running 225 on 9.5j and it looks fine
Yeah I reckon 255 would be ok on the rear but it'd be pretty crucial to get the offset spot on. I have a bit of space with 245s.
He doesn't want stretch, that looks stretched! Lol
Thanks milli
And so he did, I shall crawl back under my rock. Lol
Lol Cheers jojo
Thats too much stretch for me. I've been there and done the stretch tyres with sub 300 bhp, did not feel safe to me. So tyre on the tarmac is for winners and solid tyre walls.
So looking at the thread, so 235/40 on the 9s only will be fine? 1.26% is the difference between tyre sizes, so that equals 8mm diameter change.
old thread now but im stuck! just bought new wheels...
8.5j and 9.5j.... tires already on them 225/40 all round...
clearly back has stretch as photo above...
this setup ok on my s3 radius ok?
i dont know how you work it out :s any idea what tire size i could get for the rear 9.5j for a little LESS stretch!? bit much for my liking! :/ thanks in advance!!!! :)
235s or 245s are what you want really on a 9 or 9.5 unless you want scene points for "sik stretch". I'm getting new tyres on Monday (AD08Rs) and going for 255/40/17 rear and 245/40/17 front.
This is a good tool to compare sizes and rolling radius differences:
Visual Tyre Size Calculator | Kouki Tech
I don't pay too much attention to the visual representation of the actual tyre size as it's a little off.
If the tyre sizes are correct front and rear, then the rolling radius should be correct irrespective of stretch on the sidewalls?
Tryed reading up loads on if tonight but iv can sit the wheels next too each other and the front sits higher and it has less stretch so would of thought that would of made a difference?
Fair enough, I walkways thought the stretch was in the sidewalls, it cam compress the tread area aswell to reduce the rolling radius. Another reason for me to never go with stretched tyres, as they are clearly not designed by the manufacturer to be used in such a form.
Don't get me wrong, I have nothing against stretched tyres, but I just think I prefer my car, with it's 270odd horses to be unleashed on proper fitted tyres.
847
5K
12
4K
619
7
