Hi Guys,
After 1 year of pain from issues with the Parrot mki9200 and my iPhone 4S I scrolled the endless internet for a better device. I then stumbled acroess the Pioneer SPH-DA100 (which is currently at £199), so I reserved it. I then spent about an hour searching through old threads of fitting a double din unit. A bit of background, I have a 2001 AMK S3 with Digital Climate Control.
I realise that I have to remove the cubby (piano black flap) storage and move the climate control down after shaving some plastic off! How much plastic would I need to shave off, Is it an easy job? I know '1animal1' is the guru for this kind of install and I was after a bit of information to see whether it is worth it.
Also, I need to find a double din fascia adapter plate off an A4 and retro fit it for the S3, is this an easy task?
Then I read that I'd have to buy a cage, is this necessary?
Then once you are able to get the stereo in you have to try and connect the audio up, and I have a BOSE install which means extra faffing. I do have a Connects2 module, am I able to use that or do I need a whole new wiring adapter kit?
Thank you for your help btw, always much appreciated!
Coop
Coop
