EM TuningSky Insurance
Thread: esp fault
    Mar 2013
    7
    esp fault
    looking for some one in the ipswich sufflok with vcds vag com to check my faults.As esp is doing f all an car graping around corners can some one help
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,027
    Is your steering wheel on straight or on a slight angle?
    <tuffty/>
    Mar 2013
    7
    yes m8 just have done tracking then found that steering sensor at fault so replaced it.an then had it all reset still no esp.am now going to replace the latercel accelerater sensor and yaw sensor to see if that works ? .do you no if the esp is not working then i will not have ligth no dash.Because i have f all on dash even if i spin it up.was thinking that my consol it is not working as should do??
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    14,342
    Have a look on the vcds map for other members with vcds cable, off the top of my head there is illusion Paul and lukeb
    View Profile: Illusion-Paul - Audi-Sport.net
    View Profile: lukeb - Audi-Sport.net
    Smaller (Local) Events
    Audi-Sport.net online magazine.
    To find Audi-Sport-Net members with VCDS check out the MAP.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,027
    Grab yourself a cheap ebay lead and a copy of VCDS lite mate... scan for fault codes before changing stuff... could be something as simple as a wheel sensor..
    Links to leads ect is in my sig... or in the stickies at the top of the 8L section
    <tuffty/>
  1. S3 esp fault
    By Yonner in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd October 2009, 11:25
  2. Audi S4 4.2 V8 ESP Fault...HELP!
    By Reddwarffan in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 24th April 2009, 15:23
  3. ESP Fault on A6 (C6)
    By EddyH in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 2nd November 2008, 22:34
  4. ESP Fault, Steering Fault - Re Retro Fit Cruise! Help Please
    By J7-AUDIA3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th March 2008, 12:17
  5. ESP Fault code
    By Jay in forum VCDS (formerly VAG-COM) forum
    Last Post: 21st January 2008, 11:15
