I have a 1.8tqs with a 5 speed box in it, I can just about hit 50-55 in 2nd at the red line. Does the 60mph in second only apply to s3's with 5 speed boxes? With that in mind does that mean theres two types of 5 speed boxes for the 8l 1.8t's?
My S3 used to rev to only 6,800 and did about 56ish in 2nd, now it revs to 7,350, it will do 60 in 2nd. (The speedo shows 62 but I reckon in real speed it's 60). I think the 5 speed on the early TQS will do it easily. Not sure on the others.
My 0-60 time (however Accurate it really is) of 4.8 required 3rd on my S3. ****** PITA.
Are you sure mate? I reckon you hit 60 in 2nd for under 5 secs, my best is 5.9 in my car requiring third, would like my rev limiter increased though.
Doesn't really answer the OPS question does it Paul?
That pictures getting a bit boring I think you need to get out there and update it!
that picture just reminded me, whats that little black rounded bit of plastic that sits in the middle of the windscreen demist vents? if its just design, then its a wierd bit of styling...
It's one of the alarm sensors.
Its a temp sensor for the aircon..
<tuffty/>
SENSORS
The sensors that control the climate control unit are the sun sensor and cabin temperature sensor. The sun sensor is the dome shaped unit located in the middle of the defrost vents on top of the dash. This adjusts the climate control system to compensate for the hot sun glaring into your car. The cabin air temperature sensor measures the cabin temperature by the small vent that is located above the climate controls.
yes I do believe 4.6 is very easily achieved but not recommend on std clutch to be fair I never intended to do a timed run but my nagging brother (mk4 golf gti turbo owner) kinda pear pressured me in to it on the way back from the shops. and he was gob smacked he wouldn't show me the stop watch but I seen it 4.63 so wasn't planned other wise id of shed that weight well before and it never slipped before that so I was not to know but I quickly dipped it as soon as I felt it slip so maybe took a few k of the clutch, got no idea when it was last replaced just got the car 7 weeks ago. and Tuffty gz on the 4.2 that's amazing I bet you spent some money to get that. Regards Doug.
im not disappointed my brother was in the car and a socket set and im over joyed with the result its all about getting a a good start and and good changes and some people are better than others at achieving this...... Regards Doug
tuffty that's amazing what mods do you have. Regards Doug
Tuffty that is one big *** turbo surly you'd want the boost at around 1.5 bar with the uprated IC im running 1.37 bar on the k04 on standard IC I think you could very easily take your car 3.8 seconds bring it over to me and ill update your map for the extra boost Regards Doug
