Unknow Dash Warning Symbol
thegrouch
NULL
Had a light come up on the driver info display (not within the clocks) at the top where the media info usually is, never seen it before and its not listed in the book so wondered if anyone can help? It looks like the "fault in brake system" or the "brake light failure" symbol in as much as its an orange circle within what looks like two brackets except that theres no exclamation mark (brake system fault) or bulb symbol (brake light) just a blank circle??
Any help would be great!
It's your front brake pads warning sensor.
Worth a quick visual check as sometimes the wires to the sensors break.
can you draw it
Nice1 JCS its no5 on the list! do u know if its just the fronts that have the sensor as I know the rears are shot - actually got new 1s waiting to go on! Hope the fronts dont need doing as well, will check in the morning.
The sensor is on the front only on one side think the passenger side
sorry to resurect another old thread but im not having any joy identifying this symbol
IMG 1206
Ive had No 5 and 6 come up as in jcs356's post but cant make out what the symbol in the centers supposed to denote .
OOOOH THATS A BIGGUN !!
Anyone else seen this ?
A6 avantTdi
thats number 6 brake light failure but just with a pixelated dis im afraid mate
Hello there desperately need some help! I have the number 13 light come up on my a3 8l 1.8t but everything is working fine? Researched that this is break failure but there is nothing wrong with breaks or fluid. Tried unplugging the main break sensors and checked all over the calliper and can't see no problem . Any way I can get this warning light off without using a computer. Cheers
Holy thread revival can someone help me identify this light I'm guessing either brake light failure or pad failure will check on the light being out later just want to find out if it's mega or a little job
Gotta love the nackered dash display also!
lol!!!!
well if you get the screen fixed you will know what it is... otherwise do it manually
visual inspections of everything that the yellow warning symbol could be because who the hell knows what that could be!
Reactions: Keefo13
Hell that is one heavily pixelated dis
Reactions: IPG
Sorry to jump on this thread guys, I had a warning light come up:
A circle with MPH in the middle and a small number one at the '10' (on a clock) position.
I assume this is a speed warning indicator...
it came on after changing from 1st to 2nd, so not a great speed at all.
Sensor issue? Any info appreciated!
Beef (Keefo13).
Mate
Have a look at this thread...
http://www.audi-sport.net/xf/threads/quick-warning-light-help.293241/
Links to the warning symbols and sequence, if you count which one is yours you should be able to match it with mine...
http://vid281.photobucket.com/albums/kk220/yehnoyehno/MOV_0287_zps4mlhxk2z.mp4
Mate that worked a treat thanks. Ok I watched your vid and the MPH with the one came up (not the 2). So what does it actually mean? Sorry, I'm a noob, just bought the S3 and doing it up...I'm learning
Mine scrolled through just like yours did. It came up at number 7....hope this makes sense.
Cheers for reply!
Not sure myself mate but just found this on a TT forum,would have thought it is the same for the S3...
http://www.ttforum.co.uk/forum/viewtopic.php?f=2&t=168881
To remove
Speed limit 1 is
Press the 'test' button for at least a second when car is moving above 5mph and it will clear
Speed limit 2 is
Ignition off, press 'test' button for 2 seconds, then with warning showing on DIS press and hold 'reset' button
Reactions: hydro s3
To remove
Speed limit 1 is
Speed limit 2 is
Hey, yeah been out fiddling and reading the manual haha! So got all that. I'll give it a go next time I go over 5mph :D
Loving these forums. Been a big help thanks man!
Reactions: IPG
No worries mate,only had mine since Feb'16 so still learning myself and getting help from others here.
Reactions: Keefo13
I use the car daily and need it for work so can't have my car out of action for a week whilst it's fixed but yea it's pretty nackered! Either way the light went away I think it was the fluid or pads as I checked everything an it's fine now
787
