JMB RetrofitsSky Insurance
    May 2012
    Barry, Vale of Glamorgan, United Kingdom
    55
    s3 8l revs slow to drop on gearchange
    Hi all.
    i have a 1999 s3 8l and the revs seem slow to drop, is this normal? i have also noticed its got worse on fuel, getting about 22 mpg.
    temp gets to 90 and stays there,
    any ideas?
    thanks.
    Vex182's Avatar
    Guess what I drive...
    Apr 2012
    Hinckley
    886
    Add Vex182 on Facebook
    Not to sure on all your questions but the temp should stay at 90 when the card warmed up so that sounds normal anyway.
    Silver 2002 Audi S3 225 (BAM) since March 2011.
    Mods: Badger5 2.2 TIP, Jetex filter, PCV delete, 710 DV, Standard N249 in use, R-Tech Stage 1 TiV Remap, Audi TT Pedals, Red Dogbone, Polybushed tie arms. All silicone boost pipes, Michelin PS3s, Red V6 coil packs, MK4 flat blade conversion, retrofited cruise control.
    Currently: 254bhp - 276lb/ft (174bhp/ton) as of 11/02/2013 On V-Power
    Essflee's Avatar
    Mar 2008
    2,007
    Quote Originally Posted by s3welshy View Post
    Hi all.
    any ideas?
    thanks.
    Need a new clutch switch by the sounds of it, common problem on our cars, the switch is located down by the clutch pedal. The temp is fine.
    revo'd
    Feb 2012
    Rutland
    132
    Quote Originally Posted by Essflee View Post
    Agreed. This thread may help as it can be a bit of a pain in the ass (took me a few goes).
    2001 s3 over rev
    2001 AMK S3 in Goodwood Green
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,594
    Dual mass flywheel is heavy and revs don't drop fast... clutch switch can be tested in VCDS and will throw a fault code if faulty anyway so check that before replacing...
    <tuffty/>
    May 2012
    55
    cheers all. just tryed in neutral and seems about the same. must assume its the dual mass flywheel as mentioned.
    thanks again.
  1. SMFW + Sachs Clutch - Slow change at high revs?
    By tobycruse in forum A3/S3/Sportback (8P Chassis)
    Last Post: 23rd December 2009, 18:02
  2. Revs drop ???
    By ex_scoobydoo in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th November 2009, 13:26
  3. Replies: 22
    Last Post: 16th August 2009, 14:11
  4. Momentary drop in revs at 82 MPH
    By Tim Stuart in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th March 2007, 07:24
  5. S3 revs not dropping!!!!
    By imported_prawnie5217 in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd September 2004, 00:13
