Chris NottSky Insurance
Results 1 to 12 of 12
Like Tree1Likes
  • 1 Post By 16Klappe
Thread: How much boost could K04 puff, if K04 could puff boost? :-)
    Nov 2010
    Newmarket, Suffolk
    71
    LOL I have an '03 S3 and I've seen the thread on the K03 but I was wondering can I get 300bhp out of my K04? I have a FMIC setup, I just ordered a Badger 5 Tip and Neuspeed P-flo filter. I am going to do a full exhaust (turbo back decat) and then a stage 2 tune. Will I be able to reach my goal of 300bhp out of this setup? If not what will be the limiting factor? I would think the K04 would run out of puff but not sure.
    I would do a search of the forum but the search is screwed up right now so does this justify me in asking flaming questions?
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,523
    have a peek at Westys build thread for ideas, suffice to say 300 is possible if you want it hard enough
    beachbuggy's Avatar
    Surrey
    1,746
    exhaust manifold is the limiting factor
    phil miller's Avatar
    Sep 2012
    Devon
    843
    As above you will need a healthy ko4 and engine, a relentless manifold, relentless 3in dp and after market exhaust, b5 tip, wmi, 440cc injectors, 3in inlet and outlet fmic, Jetex cone, heat shield for cone, n249 delete, catch tank then you will be close to 300 bhp, mines off to be mapped in 3 weeks I'm hoping for 290 with a similar set up
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,533
    To answer what you said, weld the wastegate shut and find out
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,789
    No where near as much as the newer K04 clearly
    Handling mods++. HTA3582 stroker soon-ish. Hiding parts from the mrs since 2011. Build thread
    beachbuggy's Avatar
    Surrey
    1,746
    Quote Originally Posted by phil miller View Post
    where you off to for the map? You should easily see 290bhp
    Nov 2010
    Newmarket, Suffolk
    71
    Miller what do you think of the Relentless manifold? How does the build quality look and feel?
    I have to be skeptical of the quality of something from ebay ... especially tubular manifolds.
    16Klappe's Avatar
    Princess Slayer
    Crazy Closet Champion, Curveball Champion, Ping Champion, Snakeman Steve Champion, UFO Shoot Out Champion, Typing Test Champion, Smack the Rabbit Champion, Rabbit Hunter Champion, Mosquito Kill Champion, Mini KickUps Champion, KickUps Champion, Disc Dash Champion
    Sep 2008
    Basingstoke
    5,082
    Visit 16Klappe's Instagram Channel
    Relentless is the best.
    Phil is going to R Tech.
    Read Westys thread, IMO that is the most complete K04 setup I have ever seen.
    Westy likes this.
    I quite often say I'm going to do things.
    Then never do them.
    Reesy's Avatar
    East Sussex
    3,604
    Quote Originally Posted by 16Klappe View Post
    Once you have all the necessary mods, the limiting factor will be your turbo. Westy made 300bhp on a very low mileage turbo and had WMI, as well as one of the first TIV maps around..
    I made 290bhp, then 290 again with a large port head, large inlet mani and 70mm TB. The turbo wouldn't flow anymore. With more timing 300 may have been achievable.
    What I am saying is just because you have the mods required, the turbo does have a limit.
    Nov 2010
    Newmarket, Suffolk
    71
    That's about what I figured. I have been sifting through Westy's thread but 84 pages is a lot to go through. The search is fixed now so that will help some. I could be happy with 290 bhp. I didn't want to spend the money on a turbo but maybe someday in the future.
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,283
    Quote Originally Posted by AFDanHef View Post
    Start from the last page and work back mate. It's all a bit slow at the start of my thread
    I still think I could squeeze a bit more out of my setup with a bigger TB and inlet manifold.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
  1. How much boost can a stock 710N valve hold? 22 psi?
    By 88mu88 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 30th November 2010, 23:23
  2. How much boost and how to get it?
    By Oranoco in forum A4/S4 forum(B5 Chassis)
    Last Post: 2nd May 2009, 22:24
  3. How much could i get for my RS4 rep?
    By Andy.B in forum A4/S4 forum(B5 Chassis)
    Last Post: 1st April 2008, 12:49
  4. 1.8 t 150bhp how much boost ?
    By AUDI@WRC in forum A4/S4 forum(B5 Chassis)
    Last Post: 8th February 2007, 11:22
  5. 2.5 v6 tdi boost-how much?
    By dan1 in forum Diesel forum
    Last Post: 26th July 2006, 18:39
