Chris NottSky Insurance
Page 1 of 2 12 LastLast
Results 1 to 40 of 44
Like Tree2Likes
Thread: Can some one tell me how to adjust fuel !
    Sep 2012
    West midlands
    368
    I'm running a bit rich on idle and overall I want too turn 5% fuel down over the whole rev range I have fitted a 4 bar fpr too help my injector duty cycle block 001 shows -13 I have unisettings?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,046
    Why have you fitted a 4bar FPR???? the ecu will adapt it out again... there is no realistic reason to fit a 4bar FPR... and the only place to change it is in the actual map...
    <tuffty/>
    vanilla_ice likes this.
    www.badger5.co.uk
    May 2004
    nr Glos
    6,952
    you have logged your previous duty cycles to KNOW what they ran previously yea? BEFORE adding a 4bar fpr...
    yea / no?
    Check out the ever Growing eBay Shop>
    http://stores.ebay.co.uk/Badger-5-LTD?_trksid=p4340.l2563
    bill@badger5.co.uk
    Sep 2012
    West midlands
    368
    yea / no?
    ive done 10/15 logs ,lamba ect fuelling, boost, duty cycle, load, I have 10 dyno runs from midland vw as I went for a custom code map as I'm unaware of my current map but he advised low compression and 10 percent turbo so he was right actuator and low compression so all fixed and pcv delete -10 lamba at 6000rpm???? Idle hunts very slightly pistons were black withsootwhen replaced rings had only done8000 miles on them well say 10000!!??spark plugs brown pump pressure ok!!when I bent rod spark plugs were white!!I appreciate any help bill ive spent a lot more than I can afford at the Moment and was told by the chap at midland vw Jodie, there wasn't much at all he could do for me on map side anyway car was ok on dyno puling air, fuel, spot on boost was a tad low and he said low compression/worn rings in turn he was correct too give him his due!!
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,046
    I think its about time you reminded us all of the spec of your car? I seem to recall its not standard anymore...
    <tuffty/>
    [Dave B]'s Avatar
    Rrrrrrrr-tech
    Manchester
    1,972
    English?
    > S3 225 (03) - OEM+
    > 205 GTI (90) - Limited Edition Miami Blue with full leather - 1 of only 300 made
    > Clio v6 255 (05) - Lethal Weapon
    View: My S3 diary
    Sep 2012
    West midlands
    368
    Pmsl English lol k04hybrid stage 2 turbo dynamics 3inch down pipe 2.75 back pcv delete n249 delete forge 007 green spring 1 shim, big intercooler 2.5inch pipe work kandn air filter 3inch tip uprated rods bearings!
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,046
    So... basically you need a custom map...
    <tuffty/>
    Sep 2012
    West midlands
    368
    <tuffty/>
    a custom map is what I thought so I have been told by a tunning company there's not much more he could do so what is a custom map going too do for me??? I'm seeing max boost requested for a k04 hybrid at low rpm ie 25000rpm we both now they won't do that!!! im getting too much fuel so for 350 pounds what I'm I going too gain no power!!!! Egts are ok inlet temps good,so I can't justify that money at the Minuit that's why I'm asking for help what's your opinion?? Water meth manifold then a custom map for me!!, i will be using u and bill you have my word you are both very helpful hear on ther forum so out of exsperienced and loyalty for all the help but as for now I'm just want too turn my fuel down a tad even with 3 bar reg I'm seeing -10 at 6000rpm cfs are 3, bump timing up 1.5 and cfs are 6 only. On high rpm do I See any cfs , after 5600rpm my vvt was dodgy then ill do my logs with both regulators today and post results if you told me I have a stage 1 map I'd happily pay 350 but I've already been told its a good map??
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,046
    Just because the tuning company you have used say they can't do anything else doesn't mean somebody else can't mate... no need to name the company here but I have personally seen maps from reputable tuning companies that quite frankly are awful...
    Dunno where you are based but I would personally say book it in with Bill as I know for a fact he has loads of experience with this setup and mapping hybrids... even if you just get booked in for a health check initially at least he will be able to tell you whats going on...
    <tuffty/>
    www.badger5.co.uk
    May 2004
    nr Glos
    6,952
    who told you the map was good? the people who installed it? << see where I'm going with this?
    If its fueling incorrectly, and by that I mean not doing whats its told OR its doing what its told and thats just being told incorrectly??
    Lobbing in a 4bar regulator will bump up fuel delivery around 15%, so you would look to adjust this down with unisettings etc OR via the map.. The reason however why you Need to bump up fuel delivery 15% is my question. If the maps been declared "ok" then why would you want to add more fuel. Most common reason to want to up the fpr is to gain more fuel from the injectors as they may be maxing out their duty cycles.. (block 002) Was This the Case with you?
    Aribtrarily adding a 4bar fpr will make the pump work harder.. It has to produce 4bar + boost pressure fuel delivery. Tired pumps can often delivery Less... so be aware of this.
    There may be issues you are unaware of which is causing you to have fuel trim issues.. Leaks.. etc... Has it been smoke tested to see? Very Very revealing test. (I do it all the time)
    I dont recall all your previous logs.. but if requested boost (whatever it was) is being met (and not 2550mb), airflows, CF and fueling are all there then it may help spot something. post them below (so in a single thread and not scattered over ASN)
    You may have hardware issue, and equally software issue on this "custom map".... It happens.
    bill@badger5.co.uk
    Sep 2012
    West midlands
    368
    the map is unknown too me not the company I went too they didn't map it either I have done some logs what block do you need ie 001 11 8 031? My boost is these are with 4bar rg
    Sep 2012
    West midlands
    368
    I want to remove fuel not add by the way
    RobinJI's Avatar
    Jul 2012
    Chard, Somerset
    142
    Please start using punctuation properly. Your posts are really hard to follow because there's zero structure or punctuation to them, and it makes them difficult to read or understand. Putting a little more effort into writing the posts would probably get you more help and faster.
    I'm also kind of confused as to what you're actually trying to fix/achieve. It comes across that you don't seem to understand the complexity of how engine management works and what effects it's operation. It also seem as if you're maybe a little confused/mislead as to what you're wanting to achieve from the management. Sorry if that's not right, but it's how it's come across.
    There's a few questions that answering would help us all understand the issue a little more:
    What's the history of your engine?
    What spec was it when your current map was put on it?
    What's changed about the spec since then?
    1.8 20v turbo converted '88 Scirocco - ASN Build Thread
    Sep 2012
    West midlands
    368
    car when i got it had the current map im running unknown?????car had standard setup i have since fitted a front mount intercooler,3inch down pipe with 200cell race cat 2.5inch miltek back non resonated,uprated rods,bearings,3inch tip,airfilter,k04 stage 2 turbo dynamics!!!
    Friday 28 December 2012 21:58:30:10074 VCDS Version: Release 10.6.4 Data version: 20110418
    8N0 906 018 BH 1.8L R4/5VT G01 0001
    Group A: '020 Group B: '003 Group C: '115
    Idle Stabilization Idle Stabilization Idle Stabilization Idle Stabilization RPM Mass Flow Load Ign. Timing RPM Load Absolute Pres. Absolute Pres.
    TIME TIME TIME
    Marker STAMP °KW °KW °KW °KW STAMP /min g/s % °BTDC STAMP /min % mbar mbar
    0.01 0 0 0 0 0.29 2160 17.89 11.4 30 0.59 2200 44.4 980 1020
    0.9 0 0 0 0 1.2 2280 28.94 18.8 27 1.5 2360 69.2 1040 1100
    1.81 0 0 0 0 2.11 2520 35.25 19.6 26.3 2.41 2560 70.7 1040 1220
    2.71 0 0 0 0 3.01 2720 36.92 19.6 27.8 3.32 2800 70.7 1030 1240
    3.62 0 0 0 0 3.92 2960 74.72 100 21.8 4.22 3120 139.8 2390 1600
    4.52 0 0 0 0 4.83 3480 145.61 100 4.5 5.23 3840 191.7 2280 2350
    5.53 0 0 0 0 5.83 4200 159.67 100 12 6.13 4400 191.7 2390 2190
    6.43 0 0 0 0 6.73 4800 181.72 100 13.5 7.04 4960 191.7 2370 2270
    7.34 0 0 3 3 7.65 5400 202.86 100 12.8 7.94 5560 191.7 2400 2220
    8.24 0 3 3 3 8.55 5920 216.75 100 16.5 8.85 6080 186.5 2330 2140
    9.15 0 3 3 3 9.45 6400 218.17 100 15.8 9.76 6560 167.7 1630 2040
    10.06 0 0 0 0 10.36 5680 0.78 7.8 36.8 10.66 4840 126.3 2160 1350
    10.96 0 0 0 0 11.26 5080 188.56 99.2 14.3 11.56 5160 191.7 2090 2250
    11.86 0 0 0 3 12.17 5320 191.14 99.2 11.3 12.47 5400 191.7 2130 2120
    12.77 0 0 3 3 13.07 5280 0 4.3 6 13.37 4840 12 980 1240
    13.67 0 0 0 0 13.98 4160 17.06 14.5 35.3 14.28 4080 45.1 980 1070
    i have deleted sections of this log too make it fit!!!
    4 January 2013 16:18:14:10074 VCDS Version: Release 10.6.4 Data version: 20110418
    Group A: '115 Group B: '031 Group C: '118
    RPM Load Absolute Pres. Absolute Pres. Lambda Factor Lambda Factor Bin. Bits Bin. Bits RPM Temperature Load Absolute Pres.
    TIME TIME TIME
    STAMP /min % mbar mbar STAMP STAMP /min °C % mbar
    128.84 3360 191.7 2400 2150 129.16 0.914 0.852 129.45 3720 17 83.9 2390
    129.75 3960 191.7 2370 2350 130.05 0.821 0.836 130.35 4240 15 83.1 2280
    130.66 4400 191.7 2440 2320 130.96 0.821 0.828 131.26 4720 15 88.2 2380
    131.56 4880 191.7 2400 2350 131.86 0.828 0.821 132.16 5160 16 77.6 2340
    4 January 2013 16:20:46:10074 VCDS Version: Release 10.6.4 Data version: 20110418
    TIME TIME TIME
    89.02 3080 60.9 1010 1150 89.32 0.984 0.992 89.62 3120 17 0 1150
    89.92 3120 94.7 1440 1280 90.22 0.992 0.992 90.53 3240 18 80.8 1770
    90.83 3320 188 2290 2050 91.13 1.008 0.953 91.43 3520 16 83.5 2340
    91.73 3600 191.7 2340 2350 92.04 0.86 0.875 92.34 3800 16 83.5 2280
    92.64 3880 191.7 2320 2280 92.94 0.844 0.844 93.25 4080 16 83.1 2240
    93.65 4200 191.7 2350 2240 93.95 0.836 0.828 94.25 4400 17 88.2 2270
    94.55 4480 191.7 2390 2310 94.85 0.821 0.821 95.15 4680 18 86.7 2380
    95.45 4720 191.7 2360 2380 95.76 0.828 0.821 96.06 4840 18 60.4 2390
    96.36 4880 12.8 1010 1760 96.66 0.867 0.93 96.96 4120 16 0 1150
    107.22 3280 73.7 1160 1050 107.52 0.914 0.984 107.82 3320 20 30.2 1420
    108.13 3360 139.1 2360 1510 108.43 0.891 0.914 108.73 3480 20 81.6 2250
    109.03 3560 191.7 2340 2400 109.33 0.844 0.852 109.64 3640 18 83.1 2290
    109.94 3680 191.7 2330 2270 110.24 0.836 0.844 110.54 3800 18 82.7 2270
    110.84 3840 191.7 2320 2260 111.14 0.844 0.836 111.45 3960 18 80 2260
    111.75 4000 191.7 2310 2280 112.05 0.828 0.828 112.35 4080 18 83.1 2260
    112.65 4160 191.7 2330 2300 112.96 0.821 0.86 113.26 4160 18 0 2000
    113.56 3800 12 1010 1340 113.86 0.821 0.938 114.16 3440 17 0 1080
    Sep 2012
    West midlands
    368
    Friday 4 January 2013 17:05:10:10074 VCDS Version: Release 10.6.4 Data version: 20110418
    Group A: '002 Group B: '001 Group C: '031
    RPM Load Inj. On Time Mass Flow RPM Temperature Lambda Bin. Bits Lambda Factor Lambda Factor
    TIME TIME TIME
    Marker STAMP /min % ms g/s STAMP /min °C % STAMP
    42.03 1000 24.1 3.06 8.39 42.33 1120 93 0 1100011 42.64 0.891 0.992
    42.93 1280 79.7 6.46 21.83 43.24 1360 93 -17.2 1101011 43.54 1.101 0.992
    1 43.85 1440 42.9 3.74 12.58 44.14 1520 93 0 1100011 44.45 1.047 0.992
    44.75 1800 91 7.82 33.78 45.04 1960 93 -4.7 1101011 45.35 0.914 0.914
    45.66 2440 116.5 9.52 57.03 45.96 2680 93 -7.8 1101001 46.26 0.914 0.914
    46.56 3280 181.2 13.94 127.78 46.87 3680 93 -8.6 1101001 47.17 0.953 0.93
    47.47 4480 191.7 16.66 171.31 47.77 4880 93 -8.6 1101001 48.07 0.945 0.953
    48.38 5480 145.1 10.54 187.89 48.67 5280 93 0 1110001 48.98 1.086 0.961
    2 49.28 4440 12.8 1.36 6.17 49.58 4280 93 7 1100001 49.88 0.821 0.93
    50.18 4200 174.4 15.3 158.39 50.49 4360 93 -10.2 1101001 50.79 0.883 0.852
    51.09 4760 191.7 19.72 188.06 51.39 4960 93 7.8 1101001 51.69 0.836 0.828
    51.99 5360 191.7 21.42 212.92 52.31 5520 93 14.1 1101001 52.6 0.828 0.821
    52.9 5880 191.7 21.42 221.64 53.2 6040 93 17.2 1101001 53.51 0.844 0.938
    53.8 6080 18.8 1.36 0 54.11 5560 93 0 1110001 54.41 0.977 0.953
    54.71 4480 12.8 1.36 7.67 55.01 4440 93 0 1110001 55.31 1.991 1.047
    55.6 4360 12.8 0 10.44 55.91 4360 93 0 1110001 56.22 1.991 1.047
    56.51 3960 12 0 9.36 56.82 3520 93 0 1110001 57.12 1.991 1.047
    57.42 3320 18 2.04 12.28 57.73 3360 93 0 1100001 58.03 0.883 0.961
    58.33 3400 172.9 13.26 130.33 58.63 3440 93 -9.4 1101001 58.93 0.805 0.984
    59.23 3440 12.8 1.36 2.33 59.54 3440 93 0 1110001 59.83 1.991 1.047
    60.13 3400 12.8 0 7.31 60.44 3360 93 0 1110001 60.74 1.991 1.047
    61.04 3320 12.8 0 8.33 61.35 3280 93 0 1110001 61.65 1.991 1.047
    61.95 3240 12.8 0 8.33 62.24 3240 93 0 1110001 62.55 1.991 1.047
    62.85 3160 12.8 0 8.08 63.16 3160 93 0 1110001 63.45 1.991 1.047
    63.76 3120 12.8 1.7 7.56 64.06 3080 93 0.8 1101001 64.36 0.969 0.945
    64.67 3080 30.8 3.06 18.94 64.97 3080 93 -1.6 1101001 65.27 1.047 0.992
    65.57 3040 13.5 1.36 7.94 65.87 3040 93 0 1110001 66.16 1.991 1.047
    Sep 2012
    West midlands
    368
    Wednesday 5 December 2012 10:54:27:10074 VCDS Version: Release 10.6.4 Data version: 20110418
    8N0 906 018 BH 1.8L R4/5VT G 0001
    Group A: '001 Group B: '002 Group C: '115
    RPM Temperature Lambda Bin. Bits RPM Load Inj. On Time Mass Flow RPM Load Absolute Pres. Absolute Pres.
    TIME TIME TIME
    Marker STAMP /min °C % STAMP /min % ms g/s STAMP /min % mbar mbar
    9.96 2920 86 -1.6 1101001 10.26 3040 105.3 10.54 62.89 10.56 3200 107.5 2370 1280
    10.86 3320 86 -3.9 1101001 11.16 3480 112.8 11.56 74.25 11.46 3600 111.3 2320 1320
    11.77 3760 85 -4.7 1101001 12.07 3880 113.5 11.56 86.17 12.37 4040 116.5 2370 1330
    12.67 4160 86 -5.5 1101001 12.97 4320 121.1 12.24 100.06 13.28 4480 124.1 2430 1420
    13.58 4600 86 -7 1101001 13.88 4760 129.3 12.92 121.42 14.18 4920 138.3 2390 1600
    14.48 5080 86 -8.6 1101001 14.78 5160 159.4 14.96 167.22 15.08 5080 13.5 980 1620
    15.39 4640 86 0 1110001 15.69 4080 18 2.72 19.06 15.99 3920 101.5 1940 1190
    16.29 3960 86 0 1100001 16.59 4040 118.8 11.56 93.69 16.9 4120 119.5 2350 1380
    17.2 4160 86 -3.9 1101001 17.5 4240 123.3 12.58 100.44 17.8 4320 124.1 2380 1460
    18.1 4400 86 -6.3 1101001 18.4 4480 132.3 13.6 114.64 18.71 4560 130.8 2360 1580
    19.01 4640 86 -5.5 1101001 19.31 4720 136.8 13.94 125.22 19.61 4800 142.9 2370 1660
    19.91 4880 86 -6.3 1101001 20.21 4960 155.6 15.64 150.61 20.52 5040 162.4 2340 1860
    20.82 5120 86 -7.8 1101001 21.12 5240 177.4 17.68 178.58 21.43 5320 185.7 2340 2030
    21.72 5440 87 -7.8 1101001 22.02 5520 191.7 19.38 204.89 22.33 5640 191.7 2350 2160
    22.63 5720 87 -7 1101001 22.93 5800 191.7 19.38 214.69 23.23 5920 191.7 2340 2120
    23.53 6000 87 -10.2 1101001 23.83 6080 188.7 19.04 221.72 24.15 6080 165.4 980 2270
    165.94 4400 88 -4.7 1101001 166.25 4560 126.3 12.92 110 165.64 4240 119.5 2410 1380
    166.85 4840 88 -5.5 1101001 167.15 5000 142.1 14.28 141.33 166.55 4680 125.6 2390 1540
    167.76 5320 88 -8.6 1101001 168.06 5480 173.7 17.34 187.81 167.45 5160 153.4 2410 1680
    168.66 5840 88 -6.3 1101001 168.96 6040 188.7 19.04 218.17 168.36 5680 186.5 2390 1980
    169.58 6360 88 -8.6 1100001 169.87 6520 176.7 18.02 222.19 169.26 6200 185 2310 2120
    170.47 6040 88 0 1110001 170.77 5560 12.8 1.7 8.58 170.18 6560 126.3 990 2370
    171.38 4880 87 0 1100001 171.68 4920 120.3 11.22 118.19 171.07 5120 16.5 990 1110
    172.28 4840 87 0 1110101 172.58 4880 12 1.36 12.56 171.98 4920 130.1 990 1500
    2 173.19 4760 87 0 1110001 173.59 4680 12 0 10.33 172.88 4800 12.8 990 1100
    174.18 4600 87 0 1110001 174.48 4560 12 0 10.75 173.89 4640 11.3 990 1030
    175.1 4480 86 0 1100001 175.4 4520 114.3 10.88 103.06 174.79 4520 14.3 990 1020
    176 4640 87 -3.9 1101001 176.3 4680 130.1 12.92 117.5 175.7 4560 119.5 2330 1420
    176.91 4800 86 -6.3 1101001 177.21 4840 147.4 14.96 138.92 176.6 4720 133.8 2340 1600
    177.81 4960 86 -7 1101001 178.11 5040 168.4 17 166.03 177.51 4920 157.1 2360 1760
    178.72 5200 86 -5.5 1101001 179.02 5280 188 18.7 191.14 178.42 5120 173.7 2330 1950
    179.62 5440 87 -5.5 1101001 179.92 5520 191.7 19.72 204.86 179.32 5360 191.7 2340 2070
    180.53 5680 87 -5.5 1101001 180.83 5760 191.7 19.72 214.69 180.23 5600 191.7 2340 2180
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,372
    So you have put a 4bar fpr in to add 15% more fuel, then the car is removing 13% of that, and for some random reason( s=despite you saying fueling is ok) you want to add 5% more fuel with unisettings??
    And you would gain from a custom map as it'd have all the the load settings and interventions adjusted, also the timing and fueling will be adjusted to suit the car based upon many things making sure its as good at idle as it is at WOT, which is something a generic map won't have
    Sep 2012
    West midlands
    368
    Quote Originally Posted by Byzan Pics View Post
    no I want to remove fuel so I want to remove 13%not add!!my idle was 720rpm I can raise this in unisettings but not sure on fuelling ?primary fuel -how many??you say percent so I take away how much?? I'd rather some one explain than me do and log ect as I don't have a dyno lol!!my fuel is ok in logs as you say too much???
    beachbuggy's Avatar
    Surrey
    1,727
    222grams is about 270bhp.
    From those logs its pretty poor to be honest!
    You Definately don't need a 4 bar fpr
    it needs proper mapping! Unless its got a funny clipped stock turbine hybrid there's no reason why it shouldn't perform better.
    Lewis583's Avatar
    Mar 2010
    836
    Well if you want to remove fuel, before you mess with Uni-settings. Fit a 3bar fuel pressure regulator back in and see what the fuel trims are like then.
    beachbuggy likes this.
    2008 E92 BMW 335i M-sport
    1990 Golf GTi w/ a 20v heart BUILD THREAD
    Full VCDS
    2006 A3 2.0T quattro S-line R.I.P. You will be missed.
    ** Breaking - 8L 1997 Audi A3 1.8T. **
    Sep 2012
    West midlands
    368
    Quote Originally Posted by beachbuggy View Post
    it is a standard clipped turbine not stage4 spec!!221gs at 6000rpm is poor???i am not hitting my requested boost still in 2nd 3rd gears it rises the higher the gear???pcv delete venting too atmosphere??my clutch started slipping in 5th and 6th gears and I get the pull and boost I got before engine blew but can't seen too get it in 3rd more actuator preload???or is it my n75 I'm going too fit a boost controller ???
    Apr 2004
    12,372
    remove the 4 bar FPR that will remove 15%, job done
    Sep 2012
    West midlands
    368
    Quote Originally Posted by Lewis583 View Post
    yes I think I will put my 3 bar reg in tmorrow turn up the boost too we're it use too go if I can with some more preload and see how I go!! If not I'm back too the boost creep!!!!
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,046
    Adding a 4bar FPR adds around 15% fuel as Mark has already said... why don't you just go back to the 3bar FPR and then thats fixed... assuming you haven't changed the injectors you can't just do this kind of thing on ME7 as it will adapt it back out again anyway... you will prob find LTFT's will head towards -15% anyway after a while as the ECU adapts...
    Fitting a 4bar turns the std 370cc injector into just over 420cc injectors (theoretically) but the map will still be setup for 370 cc... using unisettings isn't tuning dude, its a sticky plaster... I use unisettings to make global changes, log then adjust the map to dial the injectors in... the map has several other maps that need tweaking to get fuelling right too...
    In unisettings in you need to take 13% fuel out then you do just that in primary and secondary but in all honesty its not a method I can recommend considering the the current unknown state of you setup... you have a hybrid that probably capable of 300hp on an unknown map on std injectors...
    13% fuel adjustments is well within the ECU adaption range but if it was doing that on anyone else's car it would be classed as a problem... LTFT's in block 032 is where you need to look... don't look at lambda adjust in block 001 too much at this time as you need to get base fuelling right and sorry to say but proper mapping is what you need...
    Your logs are not very clean runs so its tricky to see whats actually going on... a proper logging run will be 2k rpm to redline in third gear foot to the floor... there is normally enough resolution in a run like that to get an idea of whats going on...
    Whats block 032 saying?
    <tuffty/>
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,046
    Quote Originally Posted by darren t View Post
    If you are not hitting requested boost then thats a hardware issue... actuator preload maybe the issue but don't over do it plus all hybrids I have ever work with need a stronger actuator anyway... typical preload is 3 turns from where the gate is held shut...
    No need for a boost controller at all... the map you have isn't asking for loads of boost tbh and its not the N75 thats the issue I don't think...
    TBH I don't think there is much more that can be done over a forum... if you are sure you hardware is setup ok and your 'map' is ok then you are missing something somewhere and ideally need to get it to someone that knows these engines inside out... if your previous tuner couldn't find the issue then I would suggest taking it elsewhere...
    <tuffty/>
  28. #27
    s33nyboy12's Avatar
    May 2012
    East midlands
    1,292
    Go to bill @ badger 5 or niki @ r tech and get a custom map...... From reading your thread it's got to be worth it's weight in gold to you????? You will know what map you have and your car will be running how it should !
    Sean
  29. #28
    Sep 2012
    West midlands
    368
    0.8 and -10.2 so I'm removing 4bar tmorrow ill pop the 3bar back in again and my boost in the logs tuffty is my n75 duty cycle ok???as I can't make boost in lower gears well I'm going too adjust preload but I've noticed in the logs I have in 4th and 5th gears I get more boost???
  30. #29
    Sep 2012
    West midlands
    368
    Quote Originally Posted by s33nyboy12 View Post
    Sean
    manifold,clutch,water meth and bills my man!!!!oh and probably a fuel pump by then all hopfully ready June/July think I'm going too go there for a smoke test soon!!
  31. #30
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,046
    0.8 and -10.2 so I'm removing 4bar tmorrow ill pop the 3bar back in again and my boost in the logs tuffty is it my n75duty cycle ok???as I can't make boost in lower gears well I'm going too adjust preload but I've noticed in the logs I have in 4th and 5th gears I get more boost???
    0.8 STFT's is nothing.. -10 LTFT's is the ECU adapting out your 4bar... swap it back as you said to the 3bar, do a fault code clear in VCDS (even if there are no fault codes) as this will reset fuel trims... make sure any unisettings to do with fuel you may have adjusted are back to defaults and run it a few days to see where fuel trims land...
    N75 duty is difficult to say on the logs you have... seen an 88 in there... most maps are capped at 95%... would expect to see this a little lower if the actuator was 0.8bar as it should be on a hybrid... stiffer actuator will give more duty cycle head room...
    <tuffty/>
  32. #31
    cecilthesausage's Avatar
    ...It's Never Finished...
    Jul 2010
    Teesside
    933
    I'm no officianado mate but it seems to me that you know a little about what you are talking about, but not a lot about what you are talking about......lol And if you have a car running all them mods with an unknown map and then some mush in the garage at the corner of the road saying everything's ok that wouldn't be good enough to me...... I would be taking it to someone to give if a full health check to make sure everything is running as it should.... My own personal opinion...
  33. #32
    Sep 2012
    West midlands
    368
    Quote Originally Posted by cecilthesausage View Post
    everything is running okay ish!!!look at logs !!!no lean running hear lots of boost its not ready for another remap yet as I say a few more mods and ill see what I can get!!!
  34. #33
    www.badger5.co.uk
    May 2004
    nr Glos
    6,952
    it does look to be achieving requested boost when it see's sufficient load.. and has plenty left in the n75% to do more..
    the airflows are meh... but its only a stage 2, so dont expect to get big numbers from that spec.. Hardly more than a stock k04.
    forget boost controller.. get it mapped properly once you have fixed the known issues, and then take it to a specilast who may find you have other issues you dont know about. it will save you angst and money overall I imagine.
    bill@badger5.co.uk
  35. #34
    www.badger5.co.uk
    May 2004
    nr Glos
    6,952
    eh?? what are you on about??
    no creep on the logs
    bill@badger5.co.uk
  36. #35
    Sep 2012
    West midlands
    368
    [QUOTE=badger5;1752866]eh?? what are you on about??
    no creep on the logs[/QUOTE would the (load)be affected by a slipping clutch?as I was able too boost 1.6bar in all gears excep 1st gear now I can only reach that boost with 4th 5th 6th???ill run another log on actuator pressure and see what's happening I thought I sorted this out!!!
  37. #36
    www.badger5.co.uk
    May 2004
    nr Glos
    6,952
    yep, slipping clutch will drop load on engine
    clutch slip i would expect in higher gears not 1st however..
    bill@badger5.co.uk
  38. #37
    Sep 2012
    West midlands
    368
    So what can cause me insufficient boost in 2nd and 3rd gear and then higher boost in 5th/6th??as I see in logs it makes 2400mbar then drops then back up????
  39. #38
    Sep 2012
    West midlands
    368
    the boost in 5th hits were it did before in this gear and clutch slips why can't I boost this in 3rd gear anymore???? Pcv delete so can't see any leaks forge 007p green spring?
  40. #39
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,046
    Get it on a dyno dude... an hour of Bill's time will probably answer all these questions.... until you can say for sure that you have no hardware issues you are going to be chasing your tail on this.. trust me I have been there on more than one occasion... its getting impossible to help diagnose the issues you are having without knowing for sure that your hardware setup is working as it should...
    The map is requesting the boost and the hardware is not making it by the looks... there could be any number of reasons this is happening including air leaks, incorrectly set actuator or even a damaged turbo...
    <tuffty/>
  41. #40
    www.badger5.co.uk
    May 2004
    nr Glos
    6,952
    load! + "unknown" map
    get it looked at by someone who knows fella.... Dyno, logged, smoke tested etc etc etc All that has been already suggested
    I cant add anymore than already said...
    you are just poking and hoping otherwise
    FIX YOUR CLUTCH before proceeding.. No one can tune a car with slipping clutch = pointless
    bill@badger5.co.uk
  1. can some 1 tell me how to remove the lighter socket
    By sean3794 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th November 2010, 10:37
  2. Can some-one wire up my Recaro's please?
    By A3_Turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th October 2008, 09:28
  3. Can some one help me please?
    By Ash B in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd August 2008, 15:41
  4. vag can some one put it in simple terms for me
    By imported_my_audi_is_brok in forum VCDS (formerly VAG-COM) forum
    Last Post: 14th October 2005, 18:22
  5. Can some one fit a DV on my 225
    By taj in forum TT/TT-S/TT-RS Forum
    Last Post: 7th July 2004, 09:31
