AH FabricationsSky Insurance
Results 1 to 23 of 23
Like Tree1Likes
  • 1 Post By Andrew@A.L.D
Thread: prop shaft broke,,,,,
    Jul 2012
    59
    another S3 problem has appeared......couple of weeks ago whilst driving i came to a long corner with a load of loose mud and gravel so i though yeah ill give it some beans get it all a bit loose turned the esp off i planted my foot , wheels were spinning when i left the dirty tarmac there was a load bang from what sounded like rear diff.pulled over checked underneath make sure i didnt hit a rock and smash the diff casing but all was fine so i set off and then i had a noise which i can only describe as that horrid noise you get when you open the back windows down on a hatch back and the air gets trapped and makes you ears go funny,,,but obviously it was a vibration causing it. So being pissed right off with my constantly broke s3 i gave it a right good thrashing after a few miles the noise went to only being there beetween 30-40 mph ,but now the noise has been replaced by a clonk clonk clonk clonk road speed related coming from under centre of the car. So i put the car up on axle stands span the wheels nothing but a rubbery squeel from the U/J on the prop so i bent the heat shield out the way to have a closer look and what seems to be happening is the 1st section of prop shaft is spinning inside the U/J joint gearbox end.... so does anyone know of how the U/J is attatched to the shaft ?? with splines/pressed or a spring clip like the cv joint? or shall i just get another prop?. ive searched but havent found this before.
    cheers all for your help!
    .Ben.'s Avatar
    Nov 2012
    Guildford, Surrey
    114
    Just get another shaft from a breaker, IMO.
    TL;DR: I thrash the hell out of my car, treat it like a b*tch and it keeps breaking... Why isn't my car indestructible?
    Jul 2012
    59
    i thought it was just my one thats a complete lightweight......was gonna go BT monster but i reckon it will be a can of worms.shame i really like the car .so many trick little mods you can do to make it your own but it keeps breaking! haha
    Andrew@A.L.D's Avatar
    Cylinder Head Master
    Jun 2009
    Leeds
    3,352
    510+bhp in mine and not a problems with props and shafts?
    Was 531bhp 8L S3 thats going to break the 600+ bhp Club then break something else. Lets see what this OD HTAGT3582r can do
    My S3 Twists Drive shafts for fun.
    FOR SALE
    Sparco Torino 2 sport seats
    Adjustable FPR from 1-5 bar, 2 sets of Unused ARP 3/8 2000 rod bolts
    , relentless 200 cell cat pipe, Std AGU Crankshaft. Ported & Reconditioned Cylinder head service.
    Jul 2012
    59
    510 bhp hell yeah!!!!!!! got any videos of it???
    Jun 2009
    Leeds
    3,352
    Not yet but will do
    Goubo1 likes this.
    FOR SALE
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,637
    Quote Originally Posted by Andrew@A.L.D View Post
    Yeah that 800hp one (that greek blue one) uses stock shafts and haldex apparently!
    Handling mods++. GTX30 soon-ish. Hiding parts from the mrs since 2011. Build thread
    shariain's Avatar
    May 2004
    Glasgow
    1,170
    Just out of curiosity have you checked your rear cv joints and drive shafts and also wheel bearing. The reason I'm asking is I had a similar problem not to long ago via same reason, basically both cv joint and wheel bearing on the passenger side broke causing the cv joint to move about in the back of the hub assembly. Might be worth a look.
    S3 1.8t Ming blue with ivory leather & 18"tt alloys
    Jun 2009
    Leeds
    3,352
    Quote Originally Posted by Sam_ View Post
    That one is on a performance blue Haldex like me.
    Floor it on the wet and the back end can step out
    FOR SALE
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,637
    Yep, ditto I have the same setup. Would be even better with the peloquin rear diff. I never fitted mine, I sold it on
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,637
    Nice willy waving signature Andrew
    Jul 2012
    59
    Quote Originally Posted by shariain View Post
    yes mate ive checked,clear as day the prop is turning inside the gearbox end side of the u/j,found another complete prop on ebay,£40 happy days ,knowing my luck with this car the exhaust will disintergrate whilst trying to remove it..........
    Jun 2009
    Leeds
    3,352
    FOR SALE
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,055
    Not just a willy wave.... it sounds awesome!...
    Jun 2009
    Leeds
    3,352
    Bangs a bit to much for some lol
    Anyway you shouldn't be having any problems with props and shafts with your power level so there must be a problem else were to cause you your problems
    FOR SALE
    Jul 2012
    59
    is there kind of allignment thats out of adjustment beetween gearbox prop support and diff????
    Jul 2012
    59
    Managed to swap broke over. The fault was in the join, can only describe it as a cv joint connecting the shafts together. The races that hold the bearings together had collapsed and mullered the end of the shaft!!oh well onto next tho g that will surely break !
    colicabcadam
    most probably caused by the stupid edl
    Jul 2012
    59
    Pardon ???? Edl???
    Jul 2012
    59
    Quote Originally Posted by colicabcadam View Post
    Ohhhhh that EDL....... Hasn't happened to anyone else though??
    colicabcadam
    very common problem on the s4 and rs4 b5's with lots of power, lauching does it
    it's only a guess that that caused it, because at the end of the day, reallistically you only have around 50bhp on each wheel and that's with the haldex at 50/50 and 50 horses on its own would not brake a component like that imo, i bet the individual wheel braking did that !
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,354
    I didn't think helldex equiped cars had EDL. only torsion ones like the A4
  1. A3 2.0 TDI Quattro: Prop Shaft Issue
    By N_Okey in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th July 2010, 05:57
  2. S3 Prop Shaft
    By Welly in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th April 2010, 17:38
  3. Puzzled - Possible Prop Shaft Query
    By brettp in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th March 2010, 20:41
  4. Help!! Anyone know where I could get a Prop Shaft?
    Last Post: 2nd March 2010, 14:44
  5. Wanted...Avant 2.5 Quattro Subframe and Prop shaft
    By ims1 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 9th November 2004, 00:50
