JMB RetrofitsVolks Autos
Results 1 to 13 of 13
Thread: Is it worth it?
    Feb 2012
    Rutland
    132
    Is it worth it?
    Hi all,
    Have been an S3 owner for about 9 months now and do really like the car. So far I have changed oil pickup, new thermostat, temp sensor, shocks, top mounts, 4 wheel alignment, rust on roof rails sorted - may have missed some bits but all basic stuff that needed doing. Just before I bought the car (off an ASN member) it had a B5 tip fitted and was stage 1 mapped by RSD near Daventry. Apart from that it's standard and done 85k miles with good service history.
    Poor quality photo when bought:
    Only things worth noting are that the gearbox whines a little and is clunky from first to second (not bad) and as far as I know has never had a new clutch or flywheel. Logs I did a few months ago are as follows:
    Group A: '002 Group B: '031 Group C: '115
    RPM Load Inj. On Time Mass Flow Lambda Factor Lambda Factor Bin. Bits Bin. Bits RPM Load Absolute Pres. Absolute Pres.
    TIME TIME TIME
    Marker STAMP /min % ms g/s STAMP STAMP /min % mbar mbar
    0.01 2520 12.8 0 6.42 0.3 1.991 1.047 0.6 2440 12.8 990 1000
    0.91 2440 12.8 0 6.39 1.2 1.991 1.047 1.5 2400 12.8 990 1010
    1.81 2360 12.8 0 6.08 2.1 1.991 1.047 2.4 2320 12.8 990 1010
    2.72 2320 12.8 0 6 3.02 1.991 1.047 3.32 2240 12.8 990 1020
    3.61 2200 12.8 0 5.69 3.91 1.991 1.047 4.23 2080 12.8 990 1020
    4.53 2080 12.8 0 5.33 4.82 1.991 1.047 5.12 2040 12.8 990 1010
    5.42 2000 12.8 0 5.03 5.73 1.991 1.047 6.03 1960 12.8 990 1010
    6.34 1960 12.8 0 4.89 6.63 1.991 1.047 6.93 1920 12.8 990 1010
    7.24 1880 12.8 0 4.89 7.54 1.991 1.047 7.84 1840 12.8 990 1010
    8.14 1840 13.5 1.7 4.78 8.45 1.023 0.945 8.75 1840 46.6 990 990
    9.05 1880 74.4 7.48 31.97 9.35 0.953 0.969 9.64 2080 93.2 2030 1160
    9.96 2160 100.8 9.18 45.25 10.25 0.969 0.961 10.56 2400 121.1 2370 1440
    10.86 2520 130.1 11.9 66.19 11.16 0.953 0.953 11.47 2800 155.6 2370 1840
    11.77 2960 174.4 16.32 106.83 12.07 0.953 0.938 12.37 3320 191.7 2310 2390
    12.67 3480 188.7 19.04 127.64 12.97 0.875 0.883 13.28 3880 191.7 2310 2310
    13.58 4040 191.7 19.38 153.69 13.88 0.86 0.86 14.18 4440 191.7 2370 2330
    14.48 4600 191.7 20.4 173.36 14.78 0.844 0.836 15.09 4960 191.7 2340 2290
    15.39 5160 191.7 20.06 185.61 15.69 0.813 0.813 15.99 5480 186.5 2370 2170
    16.29 5640 183.5 19.38 194.89 16.6 0.805 0.805 16.9 5920 178.2 2340 2100
    17.2 6080 172.9 18.36 199.94 17.5 0.797 0.805 17.8 6320 162.4 2280 2080
    18.11 6440 168.4 18.02 202.22 18.4 0.758 0.86 18.72 6440 11.3 990 1410
    From what I gather (not being particularly clued up) all looks fairly healthy with a 202g/s reading and healthy fuelling. However, as I knew I would, I'm wanting more power so am looking at my options. To go stage 2 and see good figures I figure I need:
    Wellycooler (but would want to keep fogs) ~ £220
    3" downpipe ~ £260
    V3 mani ???? ~ £260
    But if all that is being done I should probably stick a second hand gearbox on there with clutch and flywheel at ~ £750
    Question is - is it worth it!? I would have to be paying someone to do the work for me (nowhere to work and not got all necessary tools or expertise). Labour on all of that would be a lot of money I would imagine (anyone got any rough guesses)? I would then have to think about mapping to make much of a difference. Am I really going to get that much better performance? I would mainly like to increase bhp / torque earlier in the revs and I know stage 2 will help, but will it really make it that much better to drive?
    All thoughts appreciated, and sorry for such a long post.
    Cheers,
    Dan
    2001 AMK S3 in Goodwood Green
    sam4191's Avatar
    If In doubt, Flat out!
    Feb 2009
    Highcliffe, Dorset
    399
    Tidy looking car mate! I noticed a nice difference with the 3" Dp sport cat. As for labour costs, I would have thought you are looking at about the same amount again. Especially for the Mani. I'm not doing mine, unless I need the Head, or Turbo off, as it is an 8 hour job in the book. With the mods in my sig, I am seeing 222g/s everytime and it is day and night from standard!
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,612
    Is it worth it depends on you and how long you intend to keep the car? Cars cost money, that's a fact! If you have the disposable income to do the above, and plan to keep the car for a while, then it's worth every penny as far as I'm concerned, as you get the enjoyment factor of it all. Don't forget to uprate the brakes to handle the extra power whilst you are at it!
    My own S3 is at a power level I'm comfortable with, given that I hardly use it(AmD stage1 map and B5 V1.1TIP). For the past 12 months though, I've been tidying up the handling of my S3 to make use of the power I already have. I've got the handling to almost where I want it now... I'd like a bit more power now, but it's silly money for an extra 20-30bhp, so unless I get bored of the car's current power output, it's either staying as it is or I'm getting a faster car with 300bhp minimum next!
    The Doctor's Avatar
    Jul 2009
    Planet Earth
    1,197
    Agree with JoJo on this one. At the end of the day it comes down to disposable ££ and how long you want to keep the car.
    Personally, mine's a daily driver and I'm content with the power from the Stage 1 map & Badger 5 TIP. I've got some Bilstein B5 shocks to fit in the spring (will also fit adjustable rear tie bars & replace the suspension bushes and possibly the ARBs at the same time) but apart from that I don't think I'll do much else to it. The price of more power becomes ever more steep per additional BHP and I'd rather just invest in a more powerful car in the first place. Having said that, I love the car and given the condition it's in I can't see myself getting rid of it for some time yet.
    Key thing you haven't mentioned is the engine internals, which you'll need to upgrade if you're wanting to increase power further.
    Feb 2012
    Rutland
    132
    Hi all,
    Agree with all of the above and have thought about just buying a quicker car, but then all I'd really want is an 8P S3 and don't want / can't afford to chuck £10k at it and watch it depreciate!
    Having had a good think I reckon all I will end up doing is fit a 3" DP (I'm assuming this can be mated to standard exhaust) and a front mount intercooler. Imay then get it mapped again to take advantage of extra flow. With regards to internals, I know it's a risk not getting rods fitted, but it's a lot of money. I'm hoping a well mapped stage 2 should help preserve things.
    If I was going down altering internals I would definitely be looking at complete change to a bigger turbo....
    Jojo - do you have an FMIC?
    Thanks for your thoughts.
    The Doctor's Avatar
    Jul 2009
    Planet Earth
    1,197
    JoJo doesn't have a FMIC. But he does have a loose rear end. On his S3 I mean.
    Feb 2012
    Rutland
    132
    I shan't comment!
    Doctor just realised you are only about 40 mins from me, and I'm heading up to Nottingham tomorrow
    The Doctor's Avatar
    Jul 2009
    Planet Earth
    1,197
    Yeah, I noticed you're in Rutland. I work at Waltham-on-the-Wolds and am occasionally down your way either for work or for a quick blast round the reservoir on the mountain bike. Don't see many other S3 8Ls round here though for some reason.
    Feb 2012
    Rutland
    132
    Ah! Think I saw your car a week or so ago as I go through Waltham fairly often (am based in Melton fairly often for work). Out of interest, have you got a good recommended garage you use?
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,612
    Quote Originally Posted by The Doctor View Post
    Lol! Love it Paul!! As mentioned, no FMIC, I have one in the kitchen, just never got round to fitting it! For the amount of use my car gets, it's never bothered me not having one. As for the loose rear end, it take a talented driver to control it!
    The Doctor's Avatar
    Jul 2009
    Planet Earth
    1,197
    Quote Originally Posted by dancuz View Post
    May well have been me - usually passing through Waltham at 8ish in the morning and half 5ish in the evening. Rarely come across another S3 around here though.
    I use C&R Enterprises in Nottingham for all of the servicing work - highly recommended. I try to do anything myself that needs doing in between services (e.g. sump/pick-up, catch can installation, Badger TIP, Haldex oil & filter etc), but always get C&R to give it the annual once-over, and do anything that's beyond my capability on axle stands in the driveway with the kids running about!
    Got a set of Bilstein B8s to fit in the spring, together with new top mounts, so may be asking you for some advice when the time comes.
    Feb 2012
    Rutland
    132
    I replaced shocks and top mounts myself a couple of months back over a weekend. Not the most fun job in the world but happy to help. Catch can is still on my "to do" list
    Feb 2012
    Rutland
    132
    It's started....... 3" Relentless DP and sports cat are on the way from Sam B. Next up is FMIC. Will probably fit the intercooler myself, but don't fancy the hassle of the downpipe particularly!
  1. change AGU to AUQ (180PS) Is it worth doing?
    By tennisguy in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st May 2004, 09:53
  2. www.superchips.co.uk - worth 300 quid or not?
    By manikm in forum A4/S4 forum(B5 Chassis)
    Last Post: 7th May 2004, 15:51
  3. Audi Alloys (What are they Worth? )
    By Wish in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd April 2004, 16:05
  4. whats this S3 worth......
    By ooooaudi in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th March 2003, 18:10
