Sky InsuranceVolks Autos
Results 1 to 7 of 7
    IFFY_77's Avatar
    Jun 2012
    London
    68
    Clutch flywheel replacement.....Help with few Q's guys
    Ok was driving home on Friday night 2am clutch pedal hit the floor could not engage gear stuck like a sitting duck. luckily i flagged down a AA guy who towed me home after his shift for a little cash in hand.
    Ok its the slave cylinder thats needs replacing master cylinder seems ok and not leaking. car has done 113k and its on its first clutch as far as i know from history. gona b a pricey £££ been told to change the clutch and may have to change flywheel aswell more £££ depending on condition once its all off. (your thoughts on this please)
    im opting for a LUK clutch kit with concentric slave cylinder from euros
    also looking at a LUK dual mass flywheel but what is the difference between a 5 teeth and 10 teeth flywheel except the price, 10 teeth costs £120 more whats the benefit and also does any1 know what is standard amount of teeth on OEM clutch?
    this is all gona cost me a arm and leg so saying goodbuy to my downpipe n decat atm :-(.
    also will this clutch flywheel b able to handle the torque and extra power when its remapped later next year once i get the downpipe and decat.
    Whoever does not try, does not learn.
    Feb 2004
    Surrey
    193
    My car is remapped, stage 1. I had replaced my clutch, slaveand flywheel from Euro Car Parts using LUK Clutch Kit (using promo codeCLUTCH15). Ensure you get the correct flywheel, you need to verify the VINto/from number with your Chassis number. All together it cost me around £450for parts, and four weekends to do the job myself.
    Audi S3 (52) 265bhp Revo Stage 1
    IFFY_77's Avatar
    Jun 2012
    London
    68
    Thanks for reply rraghvani ill make sure its correct stuff with chassis vin number 8L1 model code cant afford to go up n down. do you know the difference between 5 teeth and 10 teeth flywheel ?
    u done the change urself sounds like a long and hard job id attempt it if i had the space and save me the labour cost aswell. didnt you need a ramp to do it or did u don it on the floor ?
    IFFY_77's Avatar
    Jun 2012
    London
    68
    Just a quick update cars is back n running like a dream my clutch feels like a 12plate car haha really light and new biting point.
    so I went for the LUK clutch kit with csc and LUK dual mass flywheel also fitted a set of ebc red stuff pads first time I'm using these.
    I had a look at old clutch it was F**ked and flywheel had a lot of play in it. I can really feel the sharpness of power and responsiveness haven't gone mental on it yet as pads need bedding in but is pulling nicely in the gears.
    Damage -parts £420 thanks to my bruva in law and labour £200 thanks to my wicked mechanic.
    Jun 2011
    London
    20
    Quote Originally Posted by IFFY_77 View Post
    Hi IFFY,
    need to get clutch replaced for my A4 and looking for a decent garage or mechanic. Do you mind giving me the details of your mechanic? Looking to buy the clutch and have it fitted.
    Del
    IFFY_77's Avatar
    Jun 2012
    London
    68
    Hi Del my mechanics based in north west london just round corner from Ace Cafe. Yaash Motorsport 0208998800, ther a good bunch of guys and work is of a good standard done correctly no shortcuts etc with good pricing. I used to go the along time ago with all my Mk2 golfs and now I'm bak with my s3 after leaving the jap scene.
    Ps .... the £200 clutch job was a favour but they will sort something put tell them iffy with S3 sent you they will look after you ..
    Jun 2011
    London
    20
    IFFY, thanks buddy really appreciate the reply! Will let you know how I get on!
    cheers
    Del
  1. A few issues I could use some help with.
    By eightrac in forum A4/S4 forum(B5 Chassis)
    Last Post: 30th October 2009, 08:04
  2. Help with a few engine warning codes please
    By VTI_EG_DAN in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th May 2009, 20:01
  3. Help with replacement wingmirrors please!
    By Libo in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 8th April 2009, 15:02
  4. Help with replacing hazard warning switch
    By Stepho in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th April 2008, 20:42
  5. help with clutch!!!!!!
    By smudgy57 in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th August 2004, 23:32
