Chris NottAH Fabrications
Results 1 to 9 of 9
    May 2012
    Manchester
    229
    any reason why this wouldnt work? boost leak test
    I do enjoy a good bodge from time to time and as im a tight arse untill pay day and im taking a certain hot girl for a spin tonight i need to impress
    So thought i would check for a boost leak, ive bunged up the tip with a bean can, bunged up the pipe that went from the tip to the upper pcv valve jobby, and ive disconnected the wastegate from the n75, and ive plummed my footpump into the n75. I cant see any reasons why this wouldnt work but upon testing when i pump it more or less all comes out of somewhere round the turbo and none of it is making it to the throttle body, is this just plain stupid and not working or am i an absoloute genious with a boost leak?
    May 2012
    Manchester
    229
    Anyone? I keep trying but I cant feel air escapung anywhere but I can hear that its coming from the turbo, could this suggest cracked housing
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,025
    sound idea in principle but I doubt its a cracked housing... I would just man up and get a smoke test if you have reason to believe you have a leak you can't find...
    Save you money and heartache in the long run...
    <tuffty/>
    May 2012
    Manchester
    229
    that would be the easier option but if i can save money i will and while ive got a nice day to tinker on the car i may aswell give it a go and if it doesnt work i will take it for a smoke test, but its not even letting me put 5 psi in the system!
    determined to find this leak! how much is a smoke test roughly out of curiosity?
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,158
    Hope you still get some off the bird despite the boost leak
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    May 2012
    Manchester
    229
    im afraid she doesnt go for the type with a boost leak helppp haha
    May 2012
    Manchester
    229
    because ive played with the acyuator in the past i want to set it right again so ive already loosened both nuts so the wastegate moves freely on the actuator arm, how do i set this right, so i push the w/g closed and give it 2 turns of preload?
    not sure if it makes any difference but its an amk with oettinger map, thanks
    vrbob's Avatar
    Jun 2007
    Southampton
    2,285
    Saw a post by westy earlier this week and he put a video up that said you set it so that you can just fit the arm of the actuator onto the wastegate. then give it 3 full turns to set the pre load.
    Mods : Badger 5 Stg 2 Custom Map, FMIC, 3" DP & 200 Cell Cat, 007P, Jetex Filter & 80mm TIP & Heatshield, Complete LED Kit, Gen VW Aero Wipers, Full Powerflex Kit, R32 RARB, AP Shocks & Springs, 15mm Front & 20mm Rear Spacers, BB Uprated Actuator,
    May 2012
    Manchester
    229
    cheers mate, i had feeling it was 2 or 3 turns, i did just under 3. While doing all this today i cleaned my maf and put it all back togeather and it wouldnt idle so i unplugged the maf and it runs fine, guess ive nackered it by cleaning it somehow. A good excuse to get a new one i suppose! But the car now running with the maf unplugged is absoloutly no different than before i touched anything so it must of been on its way out.
  1. Any one know where to get boost leak test in Manchester
    By bainsys3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th June 2012, 01:11
  2. Could This Be My Boost Leak ?
    By A3 T in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th March 2012, 23:05
  3. Brembo brakes on eBay - any reason why not?
    By JD09 in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th February 2011, 13:59
  4. Boost leak test???????
    By malcolm30029085 in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th January 2010, 13:29
