AH FabricationsJMB Retrofits
Results 1 to 15 of 15
    Jun 2012
    Redhill Surrey
    635
    Add Grale1 on Facebook
    Anti roll bar bush sizing
    As above really, how can you tell the size of the bushes needed without taking of the old bush and measuring the diamaiter of it? I'm wanting to replace mine but not sure of the size.
    Simon
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Is it an aftermarket ARB?
    Jun 2012
    Redhill Surrey
    635
    No it's should be stock
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,560
    Dealer will know from your reg number or VIN number...
    <tuffty/>
    Jun 2012
    Redhill Surrey
    635
    Ok thanks tuffty
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    If its an s3 standard are 19mm front 14mm rear....i think...
    Squirrelofdoom's Avatar
    Feb 2012
    Surrey
    538
    I measured my front and it's 19mm. I've bought some Powerflex poly-bushes at 19mm to replace my old ones. Am I right in thinking I can crack off the plastic collars and directly replace the bushes with the new ones? Can I do this with the ARB still on the car or will I need to drop it out?
    S3quatt's Avatar
    Flat Oot like a ducks Foot
    Jan 2007
    Sunny Scotland
    595
    Get a vernier gauge & measure the size of the ARB. & as i recall, the bushes should be replaceable leaving the ARB on the car.
    they are held in place by a horse shoe type clamp.
    ...... Now this one's MUCH better!...
    Feb 2012
    Surrey
    538
    Cool. Did my ball joints today to try and get rid of a knocking noise. No luck, so next job is ARB bushes - good to hear they can come off with the ARB still on the car; had a quick look tonight but didn't have time to do them, bu they looked ok to do. So, let's see if the ARB bushes fix the noise, if not, then i'm stumped :S
    Cheers guys
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,511
    Quote Originally Posted by Squirrelofdoom View Post
    Cheers guys
    Knackered shocks, worn topmounts/bearing? Amongst other things that will knock.
    Feb 2012
    Surrey
    538
    only knocks under braking; and i've changed the top mounts, driveshaft, bearing, hub, lower arm bushes and checked discs and pads for uneven wear/warping. Only thing I haven't changed is I guess the bearing in the top mounts, shocks, drop links and ARB bushes
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,511
    Surprised you didn't do the bearings when the did the topmounts, since it's all coming off! Let us know how you get on anyways.
    Jun 2012
    Redhill Surrey
    635
    Im hoping to get coilovers at the end of the month, got arb bushes drop links wishbones waiting to go and track rod ends also, but there is play in my ball joint which I have waiting to go on car also has a lot of play in it, I'm hoping changing all these things on my car will. Cure the knocking and stop it pulling left once it's aligned after
    Feb 2012
    Surrey
    538
    To be honest I didn't know there were bearings there until I took it all apart, and then I didn't really know that I would need to change them :S Not a long job to replace them though, so will likely do them after the ARB bushes
    Jun 2012
    Redhill Surrey
    635
    Just done my anti roll bar bushes, a little bit of an arse ache to do, ordered 19mm ones and they came the other week, but they were to small even tho I called audi gave reg number and they said 19mm, ordered some 21mm Thursday came yesterday and just fitted, seems like a knocking has gone fingers crossed,I did notice that one of my shocks sat lower in the wheel hub, so made them the same height, so prob have to get the alignment done again, I doubt it will cure my pulling left tho
  1. Anti Roll Bar / ARB sizes on 8P front wheels drive A3s
    By c_w in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th August 2010, 13:18
  2. Anti Roll Bar Bush Kit - Info
    By Dazboss in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th August 2010, 09:46
  3. ARB Uprated Anti Roll Bar Bushes
    By *Unkle* in forum A2 forum
    Last Post: 15th October 2009, 18:28
  4. Shake, Rattle and Anti Roll bar bushes
    By Clach in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th August 2008, 21:08
  5. HELP!! 8P S3 front anti-roll bar bush HELP!!
    By jonnyc in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th November 2007, 11:14
