Results 1 to 8 of 8
    Sep 2010
    Ireland
    66
    Haldex and Rear Dif
    Hi Guys,
    Just a quick question. Im replacing the rear dif and haldex unit on my s3 because its constantly locked up and my mechanic reckons a new unit is needed. So my question is... would a haldex unit and dif from a mk1 TT fit on my s3. I presume they are all the same running gear but was hoping someone could confirm this.
    Cheers,
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    yes the same unit...
    Sep 2010
    Ireland
    66
    Cheers Dave, thought they would be.
    Sep 2010
    Ireland
    66
    Would that be the same for all that gear underneath like drive shafts, suspension, brakes etc
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,544
    TT prop shaft is shorter... most Mk4 platform quattro/4-motion running gear is the same... different spring rates IIRC on certain models (especially R32/TT V6)... R32 (maybe TT V6) has thicker ARB's... V6 TT's had extra bracing from the subframes... think this may have been used on the TTQS too...
    Early Haldex controllers were different to later ones... Haldex is also shared on the Mk4 R32
    <tuffty/>
    Lemon S3's Avatar
    Alex
    Sep 2009
    Bicknacre, Essex
    1,314
    Yeh tis the same.
    I've got the complete rear end of a mk4 r32 on mine which had only covered about 30k miles at the time.
    1999 APY S3 Imola Yellow
    PS3: Broady_11
    Jul 2012
    59
    change the fluid!!fixed mine !!!
    Sep 2010
    Ireland
    66
    Thanks for all the info guys, I was going to say i tried changing the fluid and it didnt work but today just before I was going to order a new dif I was out in the car and suddenly its fixed!! Took over 600miles of driving but suddenly its like new.
    Very very happy indeed!!
  1. Haldex oil and rear diff oil help ?
    By Daniel Thomson in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th October 2011, 16:26
  2. Gearbox and Rear Dif oil
    By Avant4me in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 1st October 2010, 20:45
  3. S3 engine oil, transmission oil, haldex oil, rear dif oil and front dif oil?
    By colicabcadam in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th September 2010, 17:49
  4. MOVED: Haldex and Torsen
    By Mutley in forum Detailing
    Last Post: 7th July 2003, 15:01
  5. Need A3 1.8 T front and rear brake rotors specs
    By lwen in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th March 2003, 14:57
