pthackeray22
hey guys, new to audi, whats the best way off going to fit a aftermarket headunit as i understamd the rear speakers are run off the built in amp? also whats the best dumpvalve to get? and a decent turbo upgrade
'decent turbo upgrade' is a little bit of an open question mate... a decent turbo upgrade could be anything from a K03s to a GT35 lol..
Budget and power expectations is a good start... but be warned it can get pricey fairly quickly especially now these engines have miles on them..
Search for the build threads by Prawn, coatsey (there are a couple of others I think) as they have done turbo upgrades on their A3's
<tuffty/>
will put some pics on tomorrow lads, ill see if i ca find on on the net whats on mine
doesn't look right to me, for a start i belive that is a blow off (or vent to air) style dump valve which doesn't work very well with the engine management on these cars, you want a diverter valve, then the diverter valve will pop into the turbo intake, the inlet on the side of the valve will connect up to where the bottom of your dv is currently, and the vac hose on top will be a straight swap
