Monster MotorsportBadger5
Results 1 to 9 of 9
    MrTackalakalaka's Avatar
    Jan 2012
    Truro, Cornwall
    426
    My S3 is starting to sound more like a diesel
    Hello everyone
    Noticed today that when sitting on idle my s3 seems to be making a lot of "ticking" noises you would expect to get from a Diesel engine. Can also faintly hear it inside as well.
    Mechanically the car drives and pulls perfect but just seems to sound awful when sitting still.
    Any suggestions?
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,325
    was it HOT or does it do it all the time?
    Our old A4 used to start clattering on idle when it was very hot, stop start city driving would usually do it.
    I fitted an oil pressure guage and found it was only making 8psi of oil pressure at idle once it got really hot.
    TD5 Land Rover Defender build
    s3mad_dude's Avatar
    Noggies ruuuule!
    Jan 2006
    Hampshire
    462
    The 1.8T does sound a little like a tractor on startup and when warm on tick over you can hear a clicking coming from the off side centre of the bonnet area which is the charcoal cannister. It reduces incoming smells into the cabin.
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,520
    S3's have the evap canister and the injectors are also stupidly loud aswell.
    if your oil gets too hot you'l lose pressure aswell. if you'd been hooning it that would explain it.
    Apr 2012
    Tunbridge Wells
    105
    Quote Originally Posted by MrTackalakalaka View Post
    Hello everyone
    Any suggestions?
    Believe it or not, V-Belt Tensioner is probably knackered.
    Sounds like a diesel when the engine turns over, and a sort of wobbly rattle sound at low revs...?
    If you've got these symptoms, it's probably V-Belt Tensioner related. The ticking comes from the rotation of the belt on the knackered tensioner, making it rattle. The noise will go away at higher revs as the tensioner is put under load. This diagnosis would also fit with the car still performing and driving normally.
    I have exactly this issue, spent hours and hours trying to diagnose it, then my friend comes round and points it out straight away! Anywho, I'll be fixing this in a week or so once I'm back from the USA! Parts aren't particularly expensive, I've ordered mine from my local TPS branch.
    Jan 2012
    Truro, Cornwall
    426
    Thankyou for the replies!!
    Yes it makes the noise all the time wether its cold or hot!
    I don't really hoon about in it, just like to "Cruise" haha
    It does sound like its coming from belt area, i think ill have to look into it when i next have a day off!!
    Thanks again for the replies!
    "Stick a V8 in it!"
    15,325
    a quick test would be to whip the auxiliary belt off, and see if the noise goes away!
    Jan 2012
    Truro, Cornwall
    426
    Thanks Aragorn!! I shall give that a go!!!
    Apr 2012
    Tunbridge Wells
    105
    Agreed. Best way to diagnose it.
    The tensioner itself is spring loaded, and should move, but it shouldn't have any play or wobble in it. Mine's like jelly at the moment.
    If its coming from the belt area, 99.9% sure it is the tensioner.
  1. S3 sounds like a diesel on start up!
    By mel_man in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd November 2010, 21:02
  2. A3 Quattro (petrol) sounds like a diesel on start up......
    By ayreaudi in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th May 2010, 19:04
  3. After start up noise its like squweltchy ?
    By mattyboy199 in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th December 2007, 18:38
  4. s3 sounds like a diesel!!!!
    By Jonesy in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st September 2006, 22:06
  5. 2.0 TFSI engine sounds like a diesel !!!!!
    By co55ie in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th August 2006, 22:33
