I have my S3 remapped with a custome map. When I drive it hard it gets thrown into limp mode.
I have swapped the n75 for a new one, still get limp mode. I logged the charge pressure (actual value) and noted I get 2530 mbar when it get thrown into limp mode.
17963 - Charge Pressure: Maximum Limit Exceeded
P1555 - 35-10 - - - Intermittent
I read that the MAP sensor is rated at 2.5bar.
Can or should the ecu be adjusted in the remap to accomodate the extra boost.
Or should I get the boost adjusted?
