Hi everyone, hopeing someone can chek my logs.
not sure where to start. I bought my s3 amk about 4 years ago. it came with loads of receipts and one of them was a jabbasport custom remap. I recently bit the bullet and bought vcds, awsome tool and its already paid for itself.
I've been logging blocks trying to figure out what sort of power my car has and if it has been mapped or not.
Car setup - pretty standard, has forge 007p dv, and a silicone tip, n249 delete.
Logging block 002 the top g/s i was getting was 180g/s, average was 170g/s thats flat out to 7000 in 3rd gear.
i did have boost leaks but i think ive sorted them all now since doing the n249 delete. before doing the runs i had no faults (well i had the odd few but nothing that would effect engine performance) after doing a few runs to 7000 i had 2 faults - misfire cylinder 1 and 4 - not sure if this could be related.
RUN1
RUN2
RUN1
Monday | 30 | April | 2012 | 18:20:24 | |||||||||||
8N0 906 018 J | 1.8L R4/5VT G 0004 | ||||||||||||||
Group A: | '002 | Group B: | '020 | Group C: | '115 | ||||||||||
RPM | Load | Inj. On Time | Mass Flow | Idle Stabilization | Idle Stabilization | Idle Stabilization | Idle Stabilization | RPM | Load | Absolute Pres. | Absolute Pres. | ||||
TIME | TIME | TIME | |||||||||||||
Marker | STAMP | /min | % | ms | g/s | STAMP | CF | CF | CF | CF | STAMP | /min | % | mbar | mbar |
0.89 | 760 | 18.8 | 1.7 | 2.64 | 0.02 | 0 | 0 | 0 | 0 | 0.49 | 760 | 18 | 1000 | 1010 | |
2.11 | 760 | 18.8 | 1.7 | 2.61 | 1.29 | 0 | 0 | 0 | 0 | 1.69 | 760 | 18.8 | 1000 | 1010 | |
3.42 | 760 | 18.8 | 1.7 | 2.64 | 2.6 | 0 | 0 | 0 | 0 | 3 | 760 | 18.8 | 1000 | 1010 | |
1 | 4.62 | 760 | 18.8 | 1.7 | 2.64 | 3.8 | 0 | 0 | 0 | 0 | 4.22 | 760 | 18.8 | 1000 | 1010 |
5.91 | 760 | 18.8 | 1.7 | 2.58 | 5.02 | 0 | 0 | 0 | 0 | 5.43 | 760 | 18.8 | 1000 | 1010 | |
7.13 | 760 | 18.8 | 1.7 | 2.58 | 6.33 | 0 | 0 | 0 | 0 | 6.73 | 760 | 18.8 | 1000 | 1010 | |
8.44 | 760 | 18.8 | 1.7 | 2.56 | 7.53 | 0 | 0 | 0 | 0 | 7.93 | 760 | 18.8 | 1000 | 1010 | |
7 | 23.03 | 3880 | 99.2 | 9.18 | 74.86 | 9.1 | 0 | 0 | 0 | 0 | 12.31 | 760 | 18.8 | 1000 | 1010 |
24.24 | 4360 | 169.9 | 16.32 | 148.72 | 23.42 | 0 | 0 | 0 | 0 | 23.84 | 4160 | 132.3 | 2210 | 1630 | |
25.65 | 5120 | 163.2 | 17.34 | 158.75 | 24.74 | 0 | 0 | 0 | 0 | 25.25 | 4920 | 168.4 | 2550 | 2100 | |
26.96 | 5760 | 155.6 | 16.66 | 169.94 | 26.05 | 3 | 6 | 3 | 3 | 26.54 | 5560 | 160.9 | 2530 | 1980 | |
28.16 | 6240 | 146.6 | 15.64 | 178.75 | 27.36 | 3 | 6 | 6 | 6 | 27.76 | 6080 | 149.6 | 2340 | 1890 | |
29.47 | 6680 | 144.4 | 15.3 | 180.36 | 28.58 | 5.3 | 5.3 | 5.3 | 8.3 | 29.07 | 6560 | 142.9 | 2140 | 1950 | |
30.77 | 5240 | 133.1 | 18.02 | 152.69 | 29.87 | 5.3 | 4.5 | 5.3 | 8.3 | 30.27 | 6320 | 11.3 | 1000 | 1620 | |
32.08 | 5480 | 157.1 | 16.66 | 165.61 | 31.18 | 5.3 | 4.5 | 5.3 | 8.3 | 31.68 | 5440 | 157.1 | 2380 | 2070 | |
16 | 70.4 | 2120 | 13.5 | 1.7 | 5.61 | 32.62 | 6 | 7.5 | 5.3 | 3.8 | 38.85 | 5680 | 157.1 | 2320 | 2020 |
71.71 | 2080 | 16.5 | 2.04 | 7.42 | 70.8 | 0 | 0 | 0 | 0 | 71.29 | 2120 | 13.5 | 1000 | 1020 | |
73.02 | 2080 | 21.8 | 2.38 | 8.83 | 72.11 | 0 | 0 | 0 | 0 | 72.61 | 2080 | 22.6 | 1000 | 1020 | |
74.22 | 2040 | 24.8 | 2.72 | 9.5 | 73.42 | 0 | 0 | 0 | 0 | 73.82 | 2040 | 23.3 | 1000 | 1020 | |
75.53 | 2000 | 14.3 | 1.7 | 5.58 | 74.62 | 0 | 0 | 0 | 0 | 75.13 | 1960 | 15 | 1000 | 1020 | |
76.94 | 1920 | 14.3 | 0 | 5.28 | 76.03 | 0 | 2.3 | 0 | 0 | 76.53 | 1920 | 16.5 | 1000 | 1020 | |
78.35 | 1840 | 13.5 | 0 | 5.03 | 77.44 | 0 | 0 | 0 | 0 | 77.84 | 1880 | 13.5 | 1000 | 1020 | |
79.55 | 1800 | 13.5 | 0 | 4.86 | 78.75 | 0 | 0 | 0 | 0 | 79.15 | 1800 | 13.5 | 1000 | 1020 | |
80.84 | 1720 | 13.5 | 0 | 4.67 | 79.95 | 0 | 0 | 0 | 0 | 80.35 | 1760 | 13.5 | 1000 | 1020 | |
82.17 | 1640 | 13.5 | 0 | 4.56 | 81.26 | 0 | 0 | 0 | 0 | 81.66 | 1680 | 14.3 | 1000 | 1020 | |
83.58 | 1600 | 13.5 | 2.04 | 4.36 | 82.65 | 0 | 0 | 0 | 0 | 83.07 | 1600 | 13.5 | 1000 | 1020 | |
84.88 | 1640 | 57.9 | 5.78 | 18.53 | 83.98 | 0 | 2.3 | 0 | 0 | 84.48 | 1600 | 56.4 | 1000 | 1020 | |
86.19 | 1680 | 36.8 | 3.74 | 11.25 | 85.29 | 0 | 0 | 0 | 0 | 85.79 | 1640 | 41.4 | 1000 | 1050 | |
87.6 | 1640 | 13.5 | 2.04 | 4.19 | 86.59 | 0 | 0 | 0 | 0 | 87.08 | 1640 | 16.5 | 1000 | 1040 | |
88.81 | 1600 | 17.3 | 1.7 | 4.53 | 88 | 0 | 0 | 0 | 0 | 88.41 | 1600 | 18 | 1000 | 1020 | |
90.2 | 1520 | 13.5 | 0 | 4.22 | 89.31 | 0 | 0 | 0 | 0 | 89.71 | 1560 | 13.5 | 1000 | 1020 | |
91.61 | 1360 | 15 | 1.7 | 3.89 | 90.62 | 0 | 0 | 0 | 0 | 91.11 | 1040 | 16.5 | 1000 | 1020 | |
92.81 | 1880 | 13.5 | 0 | 5.14 | 92.03 | 0 | 0 | 0 | 0 | 92.41 | 1960 | 14.3 | 1000 | 1020 | |
94.23 | 1160 | 19.5 | 1.7 | 3.97 | 93.32 | 0 | 0 | 0 | 0 | 93.74 | 1480 | 14.3 | 1000 | 1020 | |
95.64 | 840 | 25.6 | 3.06 | 5.33 | 94.73 | 0 | 0 | 0 | 0 | 95.23 | 920 | 17.3 | 1000 | 1020 | |
96.94 | 720 | 26.3 | 2.38 | 3.86 | 96.04 | 0 | 0 | 0 | 0 | 96.54 | 760 | 25.6 | 1000 | 1010 | |
98.15 | 760 | 26.3 | 2.72 | 4 | 97.34 | 0 | 0 | 0 | 0 | 97.75 | 760 | 26.3 | 1000 | 1010 | |
99.35 | 760 | 20.3 | 2.04 | 3.03 | 98.55 | 0 | 0 | 0 | 0 | 98.95 | 760 | 21.1 | 1000 | 1010 | |
100.67 | 720 | 24.8 | 1.7 | 2.28 | 99.77 | 0 | 0 | 0 | 0 | 100.27 | 800 | 42.9 | 1000 | 1010 | |
101.87 | 1240 | 51.9 | 4.76 | 12.19 | 101.07 | 0 | 2.3 | 0 | 0 | 101.47 | 1000 | 42.9 | 1000 | 1010 | |
103.19 | 2200 | 53.4 | 5.44 | 24.97 | 102.27 | 0 | 0 | 0 | 0 | 102.68 | 1800 | 51.1 | 1000 | 1030 | |
104.39 | 1880 | 14.3 | 1.7 | 4.78 | 103.59 | 0 | 0 | 0 | 0 | 103.98 | 2200 | 15 | 1000 | 1070 | |
105.8 | 1080 | 15.8 | 2.04 | 3.33 | 104.89 | 0 | 0 | 0 | 0 | 105.39 | 1200 | 15.8 | 1000 | 1030 | |
107.1 | 840 | 16.5 | 2.04 | 2.83 | 106.2 | 0 | 0 | 0 | 0 | 106.7 | 920 | 16.5 | 1000 | 1020 | |
108.41 | 760 | 18 | 1.7 | 2.69 | 107.51 | 0 | 0 | 0 | 0 | 107.91 | 760 | 18 | 1000 | 1010 | |
17 | 126.31 | 760 | 18.8 | 1.7 | 2.83 | 126.72 | 0 | 0 | 0 | 0 | 127.22 | 760 | 18.8 | 1000 | 1010 |
127.62 | 760 | 18.8 | 1.7 | 2.83 | 128.13 | 0 | 0 | 0 | 0 | 128.53 | 760 | 18.8 | 1000 | 1010 | |
128.93 | 760 | 18.8 | 2.04 | 2.81 | 129.33 | 0 | 0 | 0 | 0 | 129.73 | 760 | 18.8 | 1000 | 1010 | |
130.13 | 760 | 18.8 | 1.7 | 2.81 | 130.53 | 0 | 0 | 0 | 0 | 130.94 | 760 | 18.8 | 1000 | 1010 |
RUN2
Monday | 30 | April | 2012 | 18:25:12 | |||||||||||
Monday | 30 | April | 2012 | 18:26:55 | |||||||||||
0.89 | 3040 | 82 | 7.82 | 47.72 | 0.03 | 0 | 0 | 0 | 0 | 0.49 | 2880 | 79.7 | 1160 | 1280 | |
2.1 | 3520 | 157.1 | 14.96 | 114.64 | 1.29 | 0 | 0 | 0 | 0 | 1.69 | 3320 | 132.3 | 2460 | 1690 | |
3.51 | 4360 | 175.9 | 18.36 | 149.44 | 2.5 | 0 | 0 | 0 | 0 | 3 | 4080 | 178.9 | 2550 | 2330 | |
4.81 | 5080 | 164.7 | 17.34 | 159.86 | 3.91 | 0 | 0 | 3 | 0 | 4.31 | 4840 | 169.2 | 2550 | 2120 | |
6.14 | 5680 | 159.4 | 16.66 | 169.17 | 5.21 | 3 | 3 | 3 | 6 | 5.63 | 5480 | 157.9 | 2540 | 2140 | |
7.32 | 6200 | 146.6 | 15.3 | 177.86 | 6.52 | 2.3 | 6 | 5.3 | 6 | 6.92 | 6040 | 148.1 | 2390 | 2000 | |
8.65 | 6680 | 138.3 | 16.32 | 176.31 | 7.74 | 2.3 | 5.3 | 4.5 | 5.3 | 8.14 | 6480 | 142.9 | 2250 | 1980 | |
9.96 | 6200 | 29.3 | 10.54 | 40.47 | 9.03 | 5.3 | 5.3 | 4.5 | 4.5 | 9.45 | 6880 | 87.2 | 1000 | 2180 | |
11.35 | 5480 | 159.4 | 16.66 | 167.28 | 10.44 | 0 | 0 | 0.8 | 3.8 | 10.86 | 5360 | 162.4 | 2520 | 2210 | |
12.66 | 5720 | 154.9 | 16.32 | 174 | 11.75 | 3 | 6 | 6.8 | 6.8 | 12.26 | 5640 | 159.4 | 2380 | 2030 | |
13.86 | 5960 | 151.9 | 20.06 | 172.89 | 13.06 | 6 | 9 | 6 | 6 | 13.46 | 5880 | 153.4 | 2220 | 2040 | |
15.27 | 5720 | 12.8 | 2.04 | 12.03 | 14.37 | 6 | 8.3 | 6 | 6 | 14.87 | 5840 | 12.8 | 1000 | 1260 | |
16.49 | 5440 | 12 | 0 | 12.56 | 15.67 | 0 | 0 | 0 | 0 | 16.07 | 5600 | 12 | 1000 | 1070 | |
17.89 | 5160 | 12 | 0 | 12.22 | 16.98 | 0 | 0 | 0 | 0 | 17.38 | 5280 | 12 | 1000 | 1050 | |
19.19 | 4760 | 12.8 | 0 | 11.44 | 18.39 | 0 | 0 | 0 | 0 | 18.79 | 4960 | 12.8 | 1000 | 1040 | |
20.49 | 4520 | 12 | 0 | 10.97 | 19.61 | 0 | 0 | 0 | 0 | 20.1 | 4640 | 12 | 1000 | 1030 | |
21.72 | 4240 | 12 | 0 | 10.61 | 20.9 | 0 | 0 | 0 | 0 | 21.3 | 4360 | 12.8 | 1000 | 1030 | |
23.01 | 2600 | 12.8 | 2.04 | 6.56 | 22.21 | 0 | 0 | 0 | 0 | 22.61 | 2920 | 14.3 | 1000 | 1050 | |
24.23 | 2680 | 106.8 | 11.22 | 58.56 | 23.41 | 3 | 6 | 3.8 | 3.8 | 23.83 | 2640 | 94 | 2400 | 1230 | |
25.43 | 2760 | 133.8 | 14.62 | 74.56 | 24.63 | 3 | 4.5 | 3.8 | 3.8 | 25.03 | 2720 | 127.8 | 2450 | 1680 | |
26.65 | 2880 | 156.4 | 15.98 | 86.67 | 25.83 | 2.3 | 3 | 1.5 | 3 | 26.23 | 2840 | 151.1 | 2070 | 2040 | |
27.85 | 3000 | 142.9 | 14.28 | 81.78 | 27.04 | 4.5 | 1.5 | 0 | 2.3 | 27.45 | 3000 | 140.6 | 1920 | 1920 | |
29.25 | 3080 | 78.9 | 6.8 | 42.81 | 28.25 | 4.5 | 1.5 | 3 | 5.3 | 28.76 | 3080 | 94 | 1060 | 1370 | |
30.66 | 3120 | 71.4 | 6.46 | 41.94 | 29.65 | 3.8 | 0.8 | 2.3 | 5.3 | 30.16 | 3120 | 77.4 | 1030 | 1290 | |
31.88 | 3080 | 39.8 | 4.08 | 21.36 | 31.06 | 2.3 | 0 | 0.8 | 3 | 31.46 | 3080 | 47.4 | 1000 | 1230 | |
33.08 | 3080 | 45.1 | 4.42 | 26.53 | 32.28 | 0 | 0 | 0 | 0 | 32.68 | 3080 | 51.9 | 1000 | 1090 | |
34.48 | 3040 | 23.3 | 2.38 | 12.44 | 33.48 | 0 | 0 | 0 | 0 | 33.99 | 3080 | 27.8 | 1000 | 1070 | |
35.78 | 2960 | 12.8 | 0 | 7.86 | 34.98 | 0 | 0 | 0 | 0 | 35.38 | 3000 | 13.5 | 1000 | 1050 | |
37.09 | 2880 | 13.5 | 1.7 | 7.81 | 36.19 | 0 | 0 | 0 | 0 | 36.69 | 2880 | 13.5 | 1000 | 1040 | |
38.4 | 2800 | 14.3 | 1.7 | 7.78 | 37.51 | 0 | 0 | 0 | 0 | 38 | 2840 | 13.5 | 1000 | 1020 | |
39.81 | 2720 | 12.8 | 0 | 6.97 | 38.92 | 0 | 0 | 0 | 0 | 39.41 | 2720 | 12.8 | 1000 | 1030 | |
41.12 | 2640 | 15 | 1.7 | 8.69 | 40.21 | 0 | 0 | 0 | 0 | 40.63 | 2680 | 12.8 | 1000 | 1030 | |
42.32 | 2600 | 31.6 | 3.06 | 16.25 | 41.52 | 0 | 0 | 0 | 0 | 41.92 | 2640 | 30.8 | 1000 | 1020 | |
43.63 | 2600 | 14.3 | 1.7 | 6.75 | 42.74 | 0 | 0 | 0 | 0 | 43.23 | 2600 | 23.3 | 1000 | 1030 | |
44.95 | 2480 | 12.8 | 0 | 6.22 | 44.13 | 0 | 0 | 0 | 0 | 44.55 | 2520 | 12.8 | 1000 | 1030 | |
46.26 | 2400 | 12.8 | 0 | 5.97 | 45.44 | 0 | 0 | 0 | 0 | 45.84 | 2440 | 12.8 | 1000 | 1040 | |
47.55 | 2320 | 12.8 | 0 | 5.89 | 46.66 | 0 | 0 | 0 | 0 | 47.15 | 2360 | 12.8 | 1000 | 1040 | |
48.85 | 2160 | 12.8 | 0 | 5.53 | 47.95 | 0 | 0 | 0 | 0 | 48.37 | 2240 | 12.8 | 1000 | 1040 | |
50.07 | 2040 | 12.8 | 0 | 5.28 | 49.26 | 0 | 0 | 0 | 0 | 49.67 | 2080 | 12.8 | 1000 | 1030 | |
51.28 | 1960 | 12.8 | 0 | 5 | 50.46 | 0 | 0 | 0 | 0 | 50.87 | 1960 | 12.8 | 1000 | 1030 | |
52.58 | 1840 | 12.8 | 0 | 4.58 | 51.68 | 0 | 0 | 0 | 0 | 52.08 | 1880 | 12.8 | 1000 | 1030 | |
53.98 | 1680 | 12.8 | 0 | 4.31 | 52.98 | 0 | 0 | 0 | 0 | 53.49 | 1760 | 12.8 | 1000 | 1020 | |
55.2 | 1480 | 12.8 | 0 | 3.81 | 54.38 | 0 | 0 | 0 | 0 | 54.78 | 1520 | 12.8 | 1000 | 1020 | |
56.5 | 1000 | 13.5 | 1.36 | 3.39 | 55.7 | 0 | 0 | 0 | 0 | 56.1 | 1360 | 12.8 | 1000 | 1020 | |
57.81 | 960 | 21.8 | 2.04 | 2.61 | 56.9 | 0 | 0 | 0 | 0 | 57.31 | 800 | 24.8 | 1000 | 1020 | |
59.12 | 1560 | 14.3 | 1.7 | 4.39 | 58.22 | 0 | 0 | 0 | 0 | 58.62 | 1840 | 12.8 | 1000 | 1020 | |
60.53 | 880 | 29.3 | 2.72 | 5.22 | 59.63 | 0 |
