Hi All,
I fitted my shiny new Forge 007P DV today - I took my time installing it and as usual I proceeded in standard fashion to bash and graze my knuckles, nail and fingers whilst trying to remove the standard one-time use Audi hose clips - argh! Anyway all is installed and I'm very happy with it
One thing I noticed was two hoses which are split around the hose clips. I have managed to push the hose connections on more securely and the clamp now covers the split in the blue picture. This weird three pronged hose - can somebody tell me what the part number is and also what is the purpose of it?
The second hose that is split is more serious, the hose connects to the bottom of the wired three pronged hose mentioned above. I managed to re-fit the hose and I put some duck tape over the split as a temporary fix which you can see in the green part of the picture. The reason my attention was brought to it is because of the amount of the black greasy oily grit that seems to have sprayed out of the split and covered the lower half of the top of the rocker cover. Anyway, can somebody tell me the part number of this hose also? It connects to the base of the weird three pronged hose mentioned above and disappears into the depths of the engine - I'm not sure what it connects to.
Also, on a side note, what is the flat, circular object that is partly in the top right corner of my blue square?
Many thanks!
Many thanks!
