My LCD is almost unreadable, if I bought a new set of clocks from another S3, would there be an issues in using them? Such as the immobiliser or anything else?
The only way you can do this is if you know the PIN code for both your original clocks and the new clocks. If you do not have the pin code for either then you will need VAGDash to pull the pin codes. VagTacho will NOT work on the S3.
Yours pre-facelift but it works on can so vagtacho may be useless. If your clock have analog clock then is pre but I think you have digital one already. So vag commander do the job.
Yea, my clocks are digital, with no analouge clocks, so if the clocks are also digital out of the pre-facelift I could technically get hold of the clockpins of each and simply replace the clocks?
