EM TuningSky Insurance
Page 2 of 7 FirstFirst 1234567 LastLast
Results 41 to 80 of 278
Like Tree1Likes
Thread: 2.0 TFSI Coil Packs on a 1.8T
  1. #41
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,533
    i wondered what the hell was going on in westys head. coz all the covers have the holes to run the adapters/coil covers
  3. #42
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,273
    Loads of stuff in my head, most of it useless.
    I didn't realise that any cover would fit any head so I had surrendered to the fact that I would have to use a AEB cover with bolt in coils.
    Every day is a school day, as they say........ hey
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
  4. #43
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,557
    Quote Originally Posted by Westy View Post
    ...I didn't realise that any cover would fit any head so I had surrendered to the fact that I would have to use a AEB cover with bolt in coils....
    ...but happy with bolting the head from an inline engined A4 to a transverse engined S3??
    <tuffty/>
  5. #44
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,358
    For AGU and other early cars running the "dumb" bolt down coils with a seperate ICM the conversion is a no brainer. We already now the later coils with the integrated drivers are more powerful, and the TFSI ones are more powerful again, and cheaper.
    Kev, you say this like it's an easy option? Are you suggesting that you can lose the ICM and convert to tfsi coils whilst staying on ME3.8? or would you HAVE to switch to ME7x for this to work?
  6. #45
    Westy's Avatar
    Dec 2008
    17,273
    <tuffty/>
    It's froma Passat if you want to get picky
    S3 Build Thread
  7. #46
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,557
    I know Mark (Byzan A4) has done this mod.... no ECU change required as far as I know
    <tuffty/>
  8. #47
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,370
    Yeh its an easy enough swap if you can operate a soldering iron. No ECU changes required, just reroute the power feed and trigger wires from the ICMs into a later style harness.
    You can buy a harness repair kit from the dealer for about £25 and its just soldering then.
    Obviously you also need coils, be it early S3 bolt down hitachis, later push in coils, or the TFSI ones. I'd probably be going streight for some nice Red TFSI coils and the AEB/AGU version of the adaptors above so you dont have to change the rocker cover.
    TD5 Land Rover Defender build
  9. #48
    "Stick a V8 in it!"
    15,370
  10. #49
    Westy's Avatar
    Dec 2008
    17,273
    Where did you get your adapter plates from?
    S3 Build Thread
  11. #50
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,997
    You could do with a nice cover on that.
    Hide all them cables and weathered parts.
    New Car, New Thread: Scott's Akoya Silver A8
    Gone But Not Forgotten: Audrey's Build Thread
  12. #51
    "Stick a V8 in it!"
    15,370
    Its not my car, just a random pic from the thread on audizine discussing them!
    :| INA - 1.8T to 2.0T Coil Pack Adapters (TECH & FAQ) - INTRO PRICING |: - Page 14
  13. #52
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,358
    Wow, I had no idea it was that simple! I think that's something I'll definitely be doing at some point then.
    Amazing that it could be so simple that the single trigger wire for the ICM is spliced into the newer style loom and then just powers each coil seperately! I'd have thought it'd be way more complex than that!
    Any downsides?
  14. #53
    "Stick a V8 in it!"
    15,370
    Yeh its pretty simple. The ICM is just 4 big transistors in a package, it works a bit like a relay and allows a small signal from the ECU to control the large power draw that the coil uses. Basically the new coils each have an individual single channel ICM built into them. So instead of having one ICM driving all four cylinders, each coil has its own, driven directly from the ECU.
  15. #54
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,358
    That makes good sense Kev, considering the relibility issues of the standard S3/A3 coils for ME7x ecu's I'd not bother with it, but reading up, the TFSI stuff seems to be more reliable, and if the claims are to be believed, better for power.
    Based purely on reliability and consistency I'd like to change to individual coils like this, I've found the ICM seems to give strange behavior at times, having swapped mine for one from a mates car it drove totally differently, yet mine on his gave different results again.
  16. #55
    Dec 2010
    35
    Any how to guides or wiring explanation with cable colour codes for the AGU boys
    1.8T AGU
  17. #56
    Chugger
    North Devon
    2,716
    There is an electrical manual floating around on the net. All engine wiring details are there
    57 A3 2.0 TDI Sportback (140)
  18. #57
    Dec 2010
    35
    Any chance of a link as I had a quick read and flicking through vwvortex not to see much light - would appreciate it
    1.8T AGU
  19. #58
    RIP S3dave
    May 2004
    nr Glos
    7,162
    not all tfsi coils are the same.. some are slightly phatter in their diameter, making them a very tight fit
    Check out the ever Growing eBay Shop>
    http://stores.ebay.co.uk/Badger-5-LTD?_trksid=p4340.l2563
    bill@badger5.co.uk
  20. #59
    "Stick a V8 in it!"
    15,370
    Yeh, that Audizine thread seems to recommend the ones starting 06E and 07K (the full PN's are in the thread). The 06H ones from the newest models seem to crack and cause issues so best avoid those.
  21. #60
    "Stick a V8 in it!"
    15,370
    Quote Originally Posted by S3-SiB View Post
    The problem with a "how-to" is there are a few variations of colors etc. Given your rewiring your ignition system, IMO its better taken on by someone that knows how to read a wiring diagram and knows how to find each cable, and confirm its the correct one. If you cant do that, then its not something you really want to be doing yourself imo.
    I wouldnt want to provide a set of instructions, that you then follow and blow your ECU up or whatever because your car happened to be different to how the diagram says it should be.
  22. #61
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,997
    This might be a bit stupid but bear with me.
    If you put in the 2.0 coil packs, bigger spark, better burn. Does that mean you can put in bigger injectors and put in more fuel?
  23. #62
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,557
    Quote Originally Posted by scott b5 View Post
    Silly boy
    Not quite how it works mate... AFR is AFR... same amount of air, same amount of fuel but more efficient burn...
    TFSI's were designed to be lean burners for emissions, if you add more fuel to the same amount of air all you do is make it rich...
    <tuffty/>
  24. #63
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,997
    Silly boy
    <tuffty/>
    Put more air in it then?
  25. #64
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,557
    Bigger turbo
    <tuffty/>
  26. #65
    Westy's Avatar
    Dec 2008
    17,273
    Well I managed to pick up a set of 2nd hand coils that have done 15k miles for £20. Just need the adapters now.
    S3 Build Thread
  27. #66
    "Stick a V8 in it!"
    15,370
    Which PN did you get Westy?
  28. #67
    Westy's Avatar
    Dec 2008
    17,273
    I contacted the seller but he never got back to me with part numbers.
    They are apparently from a 57 plate A4 so I asked Jason.s to check for me. We think they are 07k905715f parts which are the good ones. I'll find out when they turn up.
    S3 Build Thread
  29. #68
    Westy's Avatar
    Dec 2008
    17,273
    I managed to get 4 mint A4 coil packs 2nd hand from eBay for £20 but their part number is 07K 905 715 D so I hope they'll be ok.
    S3 Build Thread
  30. #69
    May 2010
    Bedford
    2,877
    D`s are the early number. They superseeded into the F`s. If you need some F`s at some point let me know and i`ll see if i can get you some at a very cheap (for brand new originals)
    Cactus green 8L S3 - B5 TIP + Jetex, Revised 007p, R32 rear ARB, AP Coilovers, Compbrake rear arms, Full Powerflexed dogbone.
  31. #70
    Andrew@A.L.D's Avatar
    Cylinder Head Master
    Jun 2009
    Leeds
    3,468
    Just started my car up for the first time in 3 months with the Mk2 S3 coil packs and 1mm plug gap
    Even with the timing out its a hell of a lot smoother but I do have the bottom pulley that helps with that also
    Weather there is a gain in performance i'm not that bothered as its worth it just for the smoother idle
    RIP S3dave/David Marshall stickers now available
    FOR SALE
    Sparco Torino 2 sport seats, None resonated Milltek exhaust,
    Adjustable FPR from 1-5 bar, 2 sets of Unused ARP 3/8 2000 rod bolts, relentless 200 cell cat pipe, Std AGU Crankshaft. Ported & Reconditioned Cylinder head service.
  32. #71
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Jason can you get audi parts cheaper than from the stealers?
    Also glad to hear the coils good.
  33. #72
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,520
    Quote Originally Posted by Jason.s View Post
    How many can you get at this special price????
    Room for 4 more?
  34. #73
    May 2010
    Bedford
    2,877
    Dont everyone jump on it
    £99.22 inc vat for a set. £140.93 inc vat is normal dealer rate. "Very special rates" only apply to Westy for loyalty points he`s built up That price is still 30% discount near enough
  35. #74
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    I meant other car parts, need a new n75 valve and iat sensor lol.
  36. #75
    Apr 2004
    12,520
    i'm in if you can do them for that in the new year.
    Let me know mate, PM is acceptable. LOL
  37. #76
    Westy's Avatar
    Dec 2008
    17,273
    The D's should be ok but I wont find out until I've bought the adapters.
    S3 Build Thread
  38. #77
    May 2010
    Bedford
    2,877
    Just let me know when you want to do it Mark and i`ll do it
    Dani i could do some bits. Small bits i dont mind. Bigger bits i wont do as i only use the normal work post so aslong as it doesnt take the p1ss size wise i can get away with posting it for free and no one raises any issues with me using it
  39. #78
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,634
    Id be down for tht too if it's ok Jason... Anyone gt any adaptor plates? I'm in need of some coilpacks and this seems better to do then buying normal ones ey?
  40. #79
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,557
    Quote Originally Posted by Gops View Post
    There are some being developed...
    <tuffty/>
  41. #80
    May 2010
    Bedford
    2,877
    PM me when you`re wanting to do it and i`ll give you the details of the transaction
  1. A3 Coil packs
    By paddy in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th January 2012, 20:45
  2. Cheaper coil packs and better running (MarkIV TFSI coil pack)
    By docurley in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 18th August 2011, 13:59
  3. Coil packs
    By rusty s3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th November 2009, 10:13
  4. What are the best coil packs?
    By CycleSi in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th February 2008, 00:00
  5. Coil Packs?? Help
    By Add7 in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th September 2004, 21:19
