Badger5Monster Motorsport
Results 1 to 18 of 18
    macpdm's Avatar
    Jul 2011
    Cheshire
    409
    Brake light switch
    Afternoon all
    Just bought the new green BLS from Audi and have been checking out how to remove the trim to install it. There just seems to be a flimsy bit of plastic in the way and you can actually touch the switch. Do you really have to take apart half the lower dash to get at it as there is just this bit of plastic trim in the way which just needs moving to get at it properly.
    I found this image on the VW vortex site which is the guide VW give out to install the new switch and it shows the bit of trim im talking about.
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,280
    You will find that the flimsy bit of plastic is attached to the lower trim. It's only 3 or 4 torx bolts then its off. 2 second job once it's off.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    vrbob's Avatar
    Jun 2007
    Southampton
    2,363
    Dont think you have to remove the trim under the steering wheel to change the BLS but i found it much easier to do once it was removed.
    Mods : Badger 5 Stg 2 Custom Map, FMIC, 3" DP & 200 Cell Cat, 007P, Jetex Filter & 80mm TIP & Heatshield, Complete LED Kit, Gen VW Aero Wipers, Full Powerflex Kit, R32 RARB, AP Shocks & Springs, 15mm Front & 20mm Rear Spacers, BB Uprated Actuator,
    macpdm's Avatar
    Jul 2011
    Cheshire
    409
    Thanks guys
    westy I can only see 1 torx bolt on the far right I think it was.
    Westy's Avatar
    Dec 2008
    17,280
    Quote Originally Posted by macpdm View Post
    Thanks guys
    Have a quick look through here mate:
    http://www.thewellings.co.uk/audi-sp...a3interior.pdf
    S3 Build Thread
    macpdm's Avatar
    Jul 2011
    Cheshire
    409
    Brilliant document westy thanks but unless i am being stoopid I cant see anything in it that actually shows the removal procedure for that piece of trim ?
    Westy's Avatar
    Dec 2008
    17,280
    From memory (as I had the entire dash out 2 weeks ago!) you need to remove the side plate that covers the fuse box, then there are 3 torx screws in there. Then the is one in the bottom left of the trim where it meets the centre console and one around the cubby hole under the headlight switch.
    Get your head right down in the foot well and have a good look about and you'll see them.
    S3 Build Thread
    macpdm's Avatar
    Jul 2011
    Cheshire
    409
    Quote Originally Posted by Westy View Post
    Thanks for all your help buddy I will have a good old root about tonight and then go and look how to remove the trim
    Westy's Avatar
    Dec 2008
    17,280
    Dude. 68.7 in the doc shows you.
    The 2 bits marked A are spring clips so once all the screws are out you can just pull it off!
    S3 Build Thread
    macpdm's Avatar
    Jul 2011
    Cheshire
    409
    Spot on buddy missed that and it really helped to. Well the jobs done it was easy to get the trim off and fit the switch but it could be me because it was a right ******* to get the trim back on.
    Westy's Avatar
    Dec 2008
    17,280
    Yeah the hard bit is getting those two clips back in. I find punching it helps
    S3 Build Thread
    macpdm's Avatar
    Jul 2011
    Cheshire
    409
    Yes exactly I had to use some persuasion but getting the bottom lug on the right hand side below the fuse box was also a git especially when I got it all in situ then realised the trim was not sitting between the two white guides underneath and had to joyfully pull it apart again. never mind I know what im doing now thanks again buddy for the help.
    macpdm's Avatar
    Jul 2011
    Cheshire
    409
    Well I have been driving around for a week and no esp light until today it popped up out of nowhere like the little **** it is and saying "so you think you found me did you well guess again". Well mr esp light no im not chasing you any longer you can foxtrot oscar I mean you dont apear to cause any problems you just pop up and piss me off. Thats it, end of im not spending anymore except for petrol not a penny more oh and road tax and thats it oh and insurance and that really is it oh and an MOT and servicing then that really will be it. Not a penny more
    Westy's Avatar
    Dec 2008
    17,280
    Little bugger!
    Get it scanned though mate just in case it's something else causing the issue now. These problems alway crop up around xmas time when you dont want to spend any money on the car
    S3 Build Thread
    macpdm's Avatar
    Jul 2011
    Cheshire
    409
    Little bugger!
    Cheers westy I will pop round and see the man who can but im in no hurry as the car drives lovely its just bloody irritating and so intermittant.
    Westy's Avatar
    Dec 2008
    17,280
    I know the feeling, I spent a good 6 months chasing wheel speed sensor faults when I first got the car! Turned out to be a bad sensor from Euro Car Parts. Went genuine VAG and never had a problem since.
    S3 Build Thread
    Daniel M's Avatar
    May 2012
    Middlesbrough
    53
    Really sorry to bring such an old thread back up, however I have just fitted a new BLS in my A3 TDI sport, and the brake lights still wont come on. I changed the bulbs last night too thinking it was them so I can rule the bulbs out.
    Would I have to clear the fault codes before the new switch will work as the dash lights are still on?
    On another note I took the new switch out and reset it then put it back in and the brake lights came on and stayed on so did the same again and now no lights again.
    Audi A3 TDI Sport 130
    Daniel M's Avatar
    May 2012
    Middlesbrough
    53
    Ignore that last post, just disconnected the battery for 10 mins and its cleared the faults and the lights work again.
  1. brake light switch throwing up ESP light - hard to replace?
    By Rolling Thunder in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 6th November 2011, 21:59
  2. Brake Light Switch
    By Kitchy in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th June 2010, 21:47
  3. Brake Light Switch
    By sammi in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 8th January 2010, 08:52
  4. Replies: 5
    Last Post: 20th May 2009, 14:23
  5. BRAKE LIGHT SWITCH
    By steviet in forum Parts Requests
    Last Post: 2nd January 2009, 11:36
