Chris NottSky Insurance
Results 1 to 18 of 18
    Wind Deflector Trend-setter
    Nov 2011
    Horsham
    389
    Longitudinal Acceleration Sensor
    My hopes of needing a new ABS sensor have been quashed by VAG COM telling me that I have a sporadic issue with my Longitudinal Acceleration Sensor.
    I believe Audi charge over £100 for a replacement, but am wondering if there's anywhere else I may be able to get one from?
    It's probably not even worth buying a second-hand one as I believe they've got to be programmed in via a full VAG COM unit and for it to become faulty 3-6 months later is wasted money.
    Nov 2011
    Horsham
    389
    It's for a 2000-plate pre-facelift S3, btw.
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,275
    I have bought Wheel speed sensors from Euro Car Parts before that have only lasted 3 months and I've only saved myself maybe £20.
    My advice would be to buy a genuine one. You buy cheap and you buy twice, trust me.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    Nov 2011
    Horsham
    389
    I called up Euro Car Parts and they said that they wouldn't even do me the sensor that I need and that I'd need to go to a dealer direct.
    Looks like I'm paying out >£100 then + labour.
    Westy's Avatar
    Dec 2008
    17,275
    Quote Originally Posted by Routledge View Post
    Forget labour mate. Change it yourself it's fairly straight forward. I'll try and find a guide.
    Also try getting a quote from Stoke Audi on here as it might be slightly cheaper than your local dealer and he can post it to you.
    S3 Build Thread
    Sep 2011
    59
    mine was £131 from TPS, and took 5 mins to change i did it in the carpark outside TPS actually :P
    Nov 2011
    Horsham
    389
    Ah right ok - Yeah I thought you had to have them programmed in but if it's a 5 minute job then all's well! I've been researching it all day and have found where they are located (I believe by your left knee on pre-facelift on the passenger footwell up front).
    Sep 2011
    59
    Remove the Glove box (a few bolts) take off the dash end panel (open passenger door) it pulls off. remove the multiple torx/bolts and the inner panel will come off, can get at the sensor then, i found it easier to remove it with the bracket then change it and put it back. then after that first time i started it the light never came back on. happy days
    Aug 2011
    140
    Well what about the sensor under the steering wheel?
    Dec 2010
    surrey
    15
    ive got one of these in the workshop, PM me for details
    Sep 2011
    59
    Quote Originally Posted by s3matty View Post
    the lateral sensor you mean? if you mean longitudinal sensor then some i believe are under the steering colomn but mine a facelift was still on the passenger side.
    Nov 2011
    Horsham
    389
    PM Sent
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,783
    Facelift ones are under the steering wheel which makes life a bit easier. Mine had a bent bracket so wasn't sitting completely flat. Worth noting there's a calibration feature in vagcom for them also.
    Handling mods++. HTA3582 stroker soon-ish. Hiding parts from the mrs since 2011. Build thread
    Sep 2011
    59
    Quote Originally Posted by Sam_ View Post
    Mine is a facelift and it was behind the glovebox...
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,783
    Very odd - everywhere I've read (and mine) has both sensors under the steering wheel. Is yours an 01?
    Westy's Avatar
    Dec 2008
    17,275
    There are 2 sensors I think one is under the glove box and one under the steering wheel. Logitude and latitude sensors???
    S3 Build Thread
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,783
    I thought this originally then was told that on facelift there's a "dual sensor" (yaw and latitude) and then a longitudinal sensor (G200).
    Nov 2011
    Horsham
    389
    All sorted. Getting one bought and fitted all-in for £50.00 on Saturday.
  1. Longitudinal Acceleration Sensor HELP!
    By matboh s3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st November 2010, 18:40
  2. where is the longitudinal acceleration sensor?!
    By superkarl in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th September 2010, 15:10
  3. Can someone tell me where the Longitudinal Acceleration Sensor lives?
    By AudiS3-Turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th August 2010, 16:14
  4. Longitudinal Acceleration Sensor (G251)
    By MarkyB in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th April 2007, 22:51
  5. HELP ABS Longitudinal acceleration SENSOR replacement
    By ritmark in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th April 2005, 22:38
