EM TuningBadger5
    Sep 2011
    tiverton
    337
    Add egesford on Facebook
    concert stereo replacement
    i have a 2001 tdi 110 with a concert audio system, im not sure if its the bose one or not, but it has the active speakers.
    Whats the easiest way to fit an aftermarket stereo as is been a right arse ache tryin to find a wiring kit or another solution, cheers
    Jun 2003
    World of my own
    9,813
    Easiest option is to fit a Blaupunkt or Becker unit, as they use the same non standard connectors, so no wiring adapters are needed.
    All Audi's have at least rear active speakers, so you need to check whether you have active fronts, see if there is a brown speaker harness plugged into the HU. If there is then you have non Bose with active rears and if you don't then you have full Bose.
    Other than that then you will need a PC9-410 adapter to allow feeding the pre-outs from the new HU to the Bose or rear amp.
    You will also need an ISO antenna amp adapter and a fascia plate
    Alex Turner
    beanoir's Avatar
    Sharpest Tongue in the West
    Jan 2007
    51 Degrees North
    2,173
    I'd quite like a Becker in mine, but they stopped making headunits sometime ago and there is a huge premium on decent second hand ones driven primarily by Porsche owners wanting OEM headunit replacements.
    Porsche Cayman S |Jeep Grand Cherokee|1988 Ford Fiesta XR2
    www.essexdriversclub.com
    Danman1's Avatar
    Thorough noob
    Sep 2011
    West Midlands
    338
    Egesford, if you do replace your head unit i'd happily buy your old OEM one off you, pm me if your interested.
    Dan
  1. Whats the best replacement for a concert stereo in an A3?
    By calumA3 in forum In-Car Entertainment
    Last Post: 5th June 2011, 12:50
  2. Replies: 12
    Last Post: 9th January 2011, 12:42
  3. Concert stereo????
    By Higgsy in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 22nd November 2010, 20:36
  4. Replacement button on Concert stereo
    By MrTea in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th February 2009, 10:23
  5. concert stereo
    By s4mark in forum A4/S4 forum(B5 Chassis)
    Last Post: 30th October 2007, 18:23
