JMB RetrofitsAH Fabrications
Results 1 to 20 of 20
    Jan 2011
    47
    1.8T running fault.. Getting REALLY annoying now!
    I've got a running issue with my 1.8T A3.
    It idles fine after having a coilpack replaced, and pulls very well until around 4-5.5K where it judders. I thought I had it narrowed down to MAF or N75 valve, however having checked the MAF by unplugging it, there was no difference, so I replaced the N75.
    It's still exactly the same - pulls to redline in first and second and then in third will get to 4-5.5K and the judder is back..
    I'm guessing there's either a split hose somewhere which I have missed or perhaps I need another coilpack? I wouldn;t have thought it was that though as idle is perfect.
    Any other ideas???
    Baz
    Alex C's Avatar
    Lizard, Cornwall
    2,602
    could be coilpack causing misfire when engine is under increased load? so you wouldnt notice it when idleing or low gears...
    Alex S3 AMK
    Bilstein B8s, H&R Springs, Neuspeed ARBs, Genuine 18" BBS LMs & LCR Brembos
    colicabcadam
    normally when one coil goes, it puts pressure on the others, so you have 1 good coil pack and 3 weaker ones.... now the 3 weaker ones are putting pressure on the newer one.....
    change the other 3 asap
    Jan 2011
    47
    Yeah Im thinking this is going to be the case.. was advised just to replace the dodgy coil, but looks like im gonna have to shell out for the lot.
    Other advise has been to double check hoses including intercooler outlet pipe as main culprit..
    Alex C's Avatar
    Lizard, Cornwall
    2,602
    Have you checked if audi will replace them free of charge??
    Audi Recall ( all petrol engines)
    Alex S3 AMK
    S3KO4's Avatar
    Aug 2009
    London
    850
    You say it made no difference with unpluged maf! there must an issue with the maf then I would have thought. I have replaced one coil since last year I don't think it has affected the rest, why would it? if I am convinced then I might change mine as well.
    S3-8L REVO stage 2, Milltek, 3" DP & custom 3" decat, RS2 spark plugs, 4 bar FPR, Green-Cotton uprated upper/lower boost hose & TIP, Front Zimmerman & Ferrodo. LCR spliter. boost gauge, smoothed AB. Aero blades, H&R 5mm spacers. Best time 14.03sec, 0-62 in 5.7sec. 207gs @ 25psi , polished inlet mani. VAGCOM 805.1
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Are you sure its the engine and not the car? 3rd gear 4-5k revs you will be knocking on a bit, maybe wheel balancing....
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    Have you checked the plugs? make sure they are gapped correctly
    Jan 2011
    47
    So today I fitted the other 3 coilpacks as that was the most common suggestion..
    Also checked again for boost leaks, especially around the pancake pipes. I'm pretty sure there's no hoses loose, and cant see or feel any splits.
    I have noticed a slight 'dump valve' noise on let off when the window is down.. the car has standard airbox so should I hear this? Again would prob point towards a leak but where from!?
    I really don't want to pay out for anything else that's not going to solve the problem - fuel filter, coilpacks & N75 have set me back enough so far..
    I guess only option now is to scan it again..
    Jan 2011
    47
    I had a Bailey DV30 and K&N filter sat at home so thought i'd fit them to see if it helps with breathing. Still holding back at around 5k in 3/4/5th but does seem a bit better..
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    Have you checked your plugs?
    beachbuggy's Avatar
    Surrey
    1,745
    Sounds to me like the car is under fuelling when on boost. Either the FPR is faulty or you have a split in the pipe that goes to the FPR and thus when on boost the fuel pressure isn't rising to meet the increase in PSI.
    The engine is really only put under load in 3rd + gears and so 1st and 2nd the problem wont really be an issue.
    Check the pipe work to the FPR to see if it's got any splits.
    JamJay's Avatar
    Oct 2010
    Reigate, Surrey
    190
    Have you scanned the car (or did I miss that)? If there car is running too hot i.e. the EGT's are too high then the car will dump fuel to cool it and cause you a judder. That'll be easy to spot with a scan though, the car will throw a fault from the EGT sensor.
    Check the PCV pipes under the inlet manifold, ofter over looked but often the cause of many hesitation or judder.
    You only really appreciate how retarded people are in this world when you log on to a forum and recoil in disgrace over their spelling. How are any of you actually employed?!
    Jan 2011
    47
    AND THE WINNER IS....
    sandip
    With the correct answer of spark plugs!! Finally, the car's running great and now has a whole host of items replaced which didn't need doing!
    Only fault that came up with scanning was MAF - however that would've been from when it was unplugged.
    Cheers all for suggestions..
    Apr 2010
    Widnes Cheshire
    404
    Glad you got it sorted.
    Well done sandip, by the way what time did you get to Awsome last saturday? I arrived at 9 and left at 10:15.
    DC
    His: 2001 1.8T AUM. Hibiscus Red Pearl Effect - Hers: 2002 1.8T AUM. Metalic Silver.
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Great, interesting about the plugs were they old? or not gapped correctly?
    Jan 2011
    47
    plugs were old.. will take a pic if i get chance, but tips had worn..
    May 2011
    67
    yeah mine has the same issue i think how much are the plugs?
    More red letters than a man in debt
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    Quote Originally Posted by DenCar View Post
    DC
    I got there a bit late lol around 11:30ish i think
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    Quote Originally Posted by s30000t View Post
    BKR6e's are £8 - £12 for a set. Ideally change these every 6-8k along with the oil
