S3tony
Well took her to norwich audi for the works haldex, brake fluid and everrything else. Asked them to look into the headlights as they seem to look at the floor, headlamp washer on drivers side doesnt pop up and the coolant indicater on the dis beeps at me when started from cold. well the headlamp washer needs replacing which they would do for £200 the headlights are adjusted and are much better.
the coolant problem says " Fault stored in memory with coolant sensor and thermostat" =£338.
they also found "slight gearbox oil leak from propshaft flange seal" = £215
also "air con compressor clutch noisey" =£425
and i also need new rear pads and discs in the next 2k =£250
i declined them doing it for now as i need to find out if theese are covered on my warranty i got when i bought the car. I left the garage with a very shiny clean car but a big hole in my wallet to the cost of £563.18 /ubbthreads/images/graemlins/cry.gif /ubbthreads/images/graemlins/cry.gif /ubbthreads/images/graemlins/cry.gif /ubbthreads/images/graemlins/cry.gif /ubbthreads/images/graemlins/cry.gif
sorry i went on for so long i just wish i didnt have to.. if you have got this far thanks for reading.
cheers tony
cheers tony
