[ QUOTE ]
j8436741 said:
yeah install i did it all as for the caps need them till i get a slave battery what do you suggest
[/ QUOTE ]
the caps will actually put more of a strain on your system, therefore voltage drop will be heavier, resulting in more chance of the amps going into clip
running 0 guage (if you havent already) to the rear would be the best thing to do
be careful if you go the split charge route as this will have an effect on what class you will be in if/when you compete - thats if you're competing in dBdrag?
best advice i can give is if you're really serious about competing build the install to the rules (number of drivers, number of amps, split charge - all these will have an effect) and also get to know someone with a termlab sensor (if possible) as this will be your best way of you knowing how loud you are and what frequency you peak at
sounds a lot to take in but its fun /ubbthreads/images/graemlins/beerchug.gif
