    chris039's Avatar
    S3-A quality driving experience
    Worcester
    6
    MAF sensor, knock sensor....???
    ......or just a coil pack!!!!
    I recently had trouble with my S3 running rough almost misfiring, after vag-com pointing towards maf sensor and knock sensor i decided to start with the first, after replacing the mass air meter with a genuine new one i found no difference.
    Back to basics, stripped the engine covers and checked all pipe works for leaks to find nothing.
    After getting my mate to look at it with a fresh set of eyes he sugested checking coil packs, un-plugging one by one hey presto un-plugging number 3 made no difference!!!
    Lesson of the day.... use vag-com as a direction not a diagnostics.
    oh and if anyone needs a MAF sensor i have a cheap one going!!
    SiGainey's Avatar
    Sep 2003
    North Wales
    475
    Quote Originally Posted by chris039 View Post
    PM me about how much you want for the MAF sensor
    '01 AMK, completely standard except for the Ambient Lighting Pack.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,025
    Welcome to the world of diagnostics my friend
    VAGCOM is a great tool but as you have found out faults found by it aren't always true faults but the result of another fault that may not always be picked up...
    Lesson to anyone here using VAGCOM is to interpret the results and think logically about them...
    Interested to hear what made you think it was the MAF... did it throw a fault code or was the airflow readings low when you logged?
    <tuffty/>
    Welly's Avatar
    Testing dodgy Chinese gear...
    Aug 2009
    Gloucestershire
    10,680
    In fairness, a misfire will cause knock from the engine. And that MAF sensor error could have been a historic one. Did you reset them first and then drive it to see what came up?
    Homer Simpson
    Wellyboots, you are quite literally my most favourite pikey in the entire world
    Welly's Avatar
    Aug 2009
    Gloucestershire
    10,680
    At least it's fixed though!
    Homer Simpson
    chris039's Avatar
    Worcester
    6
    Hey guys been away for a while so not been on here, I did reset the codes and drove the car which kept throwing up MAF sensor faults as well as knock sensor, dissconnecting the maf meter should resort back to standard settings, however this didnt happen but i could get one readily available so thought worth a try and loads of threads on how they are tempramental made go stab in the dark and give it a try.
    Anyhows, back to the basics fixed it in a short time so im happy and i'll get rid of the MAF meter and sort a sticking hydraulic lifter.
