I'm afraid the guy is wrong Jamie, and clearly knows nothing about how brakes work.
In a single pot caliper, you have to assume it works like a 2 pot, as with a sliding caliper, the piston forces the pad into the disc, but the other side of the caliper applies an equal and opposite force on the other pad.
so, effectively, you have to consider the single 54mm piston as 2 54mm pistons.
so, using pi r^2
Standard caliper:
(pi x 27^2) x 2 = 4580 mm^2
Porsche 30/34mm caliper
(pi x 15^2) x 2 = 1413 mm^2
(pi x 17^2) x 2 = 1815mm^2
= 3228mm^2 total piston area
so, (3228/4580) x 100 = 70.5%
So, those porsche calipers he mentioned will have roughly 70% of the power of your standard S3 brakes when using the standard master cylinder.
The discs are 323mm though, so (323/312) x 100 = 103.5%. SO you get only 70% of the hydraulic power, and just a 3.5% mechanical increase in leverage from the larger discs....
Avoid!!!!!
