New logs as requested
Yarp, your map is running on the lean side for power... looks more like a std map because of it (in answer to your pm)... load value looks odd... Bill?
<tuffty/>
a couple of runs from tonight
Any info appreciated cheers
It does look lean under boost for my liking...
how is timing pull on block 020 during these runs?
what is the running fault you are trying to resolve? I missed that bit
really?
missed that then.. doh!
I cant see the images from this POS corporate network I am currently on..
Between 5700 and 6600 CFs are regularly up to and including 6s, so quite high.
LOL, what you need is some good IT gear.... :).
lol, you're right.. and I believe I am receiving said It gear and able support also, from a very good local guy we both know.. :D
corporate web filtering kills anything photobucket related.... w4nkers
See these (you owe me Gaz):
<tuffty/>
cheers tuffty going to mapping garage soon they said they will add some more fuel cos im not happy lol
should do job ryt in first place
whats the load value is it my injectors mate
cheers bill just wondering if map is ok car car not going to blow up and i keep getting limp mode when i drop it a gear and put foot down getting fault saying check dv presher drop , maximum presher exeded some days as well dont make sense
do i need to get timing changed as well tar gaz
lots of issues on there are'nt there..
all fine before remap was it?
check for leaky hoses... random stuff occurs when there are leaks...
map could also be the issue if its done this from the outset
CHECKED ALL HOSES NOTHING FOUND I AM MISSING THAT RUBBER BUNG THAT GOES UNDER THE VVT VALUE THO COULD THAT BE TO BLAME
IT JUST A BACK STREET GARAGE MAP SAID HE HAD 20 YEAR EXPERIANCE MY **** LOL
AND YE MAP WAS DONE FROM THE OUTSET BILL
no what I was asking was did these problems occur before the remap?
no they did not happen before i had it mapped bill just had a new map put on so ill put the logs on here latter see the differance
the guy that mapped car before did not add any fuel or up the torqe at all left it all standered boost was all over the place and timing was sky high see what ya think to my next logs tar gaz
i just been told and seen from the grafs of the old map he did not add anymore fuel to the map and torqe he just messed with timing and
boost new map has everything altered ill get some logs up
225
recomdos
R
7
882
30
2K
